Thread started 25 May 2017 (Thursday) 11:31
Prev/next
10x ND filter for 11-24 f/4 L
dougsturgess
Joined Jul 2002
Post has been edited 8 months ago by dougsturgess.
May 25, 2017 11:31 |  #1
Does anyone know of a way to take long exposures during the day with this lens using a special filter? Are there any ND filters for this lens?
Does anyone have any experience with this: https://fotodioxpro.co​m/products/wpxlcore-ca1124 (external link)
Thanks.
Doug Sturgess
www.sturgessart.comexternal link
doug-sturgess.artistwebsite​s.com
Charlie
Guess What! I'm Pregnant!
May 25, 2017 12:31 |  #2
dougsturgess wrote in post #18362787 (external link)
Thanks.
IMO, for something that wide, you'de be better off with a rear filter. I think that lens has a gel slot, you should look into cutting out some gels.
the problem has to do with the way the light enters in at a steep angle on the edges. Rear filter would solve those issues. I have a front filter for my voigtlander 10mm, and it's barely usable for a 3 stop filter. 6 and 10 is unusable
Sony A7rii/A7riii - FE 12-24/4 - FE 24-240 - FE 28/2 - FE 35/2.8 - CV 35/1.7 - FE 50/1.8 - FE 85/1.8 - EF 135/1.8 Art - F 600/5.6 - CZ 35-70, 100-300 - Astro Rok 14/2.8, 24/1.4 - Tamron 28-75 f2.8, 70-200 f2.8 VC
dougsturgess
Joined Jul 2002
May 25, 2017 13:11 as a reply to Charlie's post |  #3
I decided on this system after reading the great reviews. I do want something to protect the lens so I bought the UV MRC lens and the 10x stop filter for the XL system. Can't wait to get some creative ultra wide angle shots with this lens!
Doug Sturgess
Charlie
May 25, 2017 13:17 |  #4
dougsturgess wrote in post #18362847 (external link)
Thank you for your response. Out of what material do you make a filter that can provide stops for long exposure?
I use haida ND filters, 100mm squares.. for the 11-24 front, you'de need something much larger like 150mm squares.
you can buy them most camera shops.
dougsturgess
Joined Jul 2002
May 25, 2017 13:21 as a reply to Charlie's post |  #5
what do you think about these? https://www.edmundopti​cs.com ...q-neutral-density-filter/ (external link)
Doug Sturgess
mcoren
mcoren's Avatar
Joined Mar 2015
Northern Virginia, USA
Post has been edited 8 months ago by mcoren.
May 25, 2017 21:50 |  #6
dougsturgess wrote in post #18362854 (external link)
Edmund makes quality stuff for optics labs. Those are wratten film filters. I don't think they have the rigidity for a front holder, but you could cut them to size for the rear filter slot.
Edit: The filters in that link are 3-stop filters. Which is fine, but the title of this thread is 10x filters which I read to mean you want a 10-stop filter.
Canon EOS 70D | Canon EF 50mm f/1.8 II, EF-S 18-135mm f/3.5-5.6 IS STM | Sigma 17-70mm f/2.8-4 DC Macro OS HSM, 100-400mm F5-6.3 DG OS HSM | Canon Speedlite 430EX II
Charlie
May 25, 2017 22:35 |  #7
these will not work, way too small for that lens. Best getting a kit like in the original post, just be aware of the severe vignetting which you may encounter with a strong ND. The 11-24 is an unconventional lens which takes unconventional filters.
filmuser
Joined Jul 2016
May 26, 2017 08:55 |  #8
SW150 Mark II Filter System
(150mm Filters)
The SW150 Mark II Filter Holder has been designed specifically to fit ultra-wideangle lenses.
The design of the SW150 Mark II has been adapted from its predecessor and is now not only compatible with LEE’s range of SW150 neutral density graduated and standard filters, but also the new SW150 polariser and Little, Big & Super Stoppers.
Due to the size of the front element of ultra-wideangle lenses, these filters are larger than those in the standard 100mm range.
rcjd
rcjd's Avatar
Sweden
Jan 03, 2018 23:44 |  #9
Thanks.
I’m curious, you bought the system and dors it work well? Any vignetting issues?
Canon ­ Bob
Poitou-Charentes, France
Jan 04, 2018 03:02 |  #10
Aurora-Aperture now make rear mount glass ND's for Canon lenses which take rear filters.... http://aurora-aperture.com ...-mount-format-filter-set/ (external link)
1Dx2 (2), 5DSR, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF24-70/4 EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
rcjd
rcjd's Avatar
Sweden
Jan 04, 2018 06:58 |  #11
Canon Bob wrote in post #18533031 (external link)
Thanks, for the swift and life saving-answer!! I'll definitely look into Aurora's rear filter set.
Canon ­ Bob
Jan 04, 2018 07:30 |  #12
rcjd wrote in post #18533094 (external link)
They are the result of a Kickstarter (crowd funding) project. I received mine last month so I'm not in a position to criticise or praise but they appear well made and the holders are simple to install (also simple to revert to the Canon original holder). A quick test of a white subject lit with 5600k leds shows little or no colourcast although sunlight might behave differently.
Bob
rcjd
rcjd's Avatar
Sweden
Jan 04, 2018 07:40 |  #13
Canon Bob wrote in post #18533107 (external link)
Bob
Thanks, very helpful. A heavy price tag, but if it delivers it might be worth it. Please let me know once you post images taken with the filter applied!
Canon ­ Bob
Jan 04, 2018 10:49 as a reply to rcjd's post |  #14
It's been grey and stormy for the past 10 days but I'll endevour to test them as soon as possible and drop you a PM to alert you.
Bob
rcjd
rcjd's Avatar
Sweden
Jan 04, 2018 13:58 as a reply to Canon Bob's post |  #15
Thanks!
1,925 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00107 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is piggitou
981 guests, 511 members online
