FORUMS Photography Talk by Genre Transportation Talk
Thread started 16 Jul 2017 (Sunday) 13:44
Prev/next
Airport - Aircraft landing photos
azpilot10
1 post
Joined Jul 2017
Jul 16, 2017 13:44 |  #1
Hello.
First. I searched the forums to make sure this questions is not a duplicate so if it has been asked before please forward a link
Second. thank you for such a cool group.
I run a small company that provides tours by private aircraft. attendees will be in private aircraft and we tour mexico or central america. During the tours I like to get ahead of the group and photo the landing of other small aircraft as they land. My issue is normally the approach and touchdown is a LONG ways away..
Can i get some suggestions to a good camera rig/setup and lens suggestions? I would say in most cases we are a half mile away from the aircraft as they touch down. Of course money is not unlimited.. and portability is always a concern. I like to keep the expensive gear hidden along the route so smaller the better.
During the tours we also take a lot of photos of normal things.. Currently i use several go pros and it works ok.
My skill set regarding photography is amateur at best. so simple is best.
Photos are from Rio Dulce Guatemala - My dad giving a thumbs up.
Thank you in advance.
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Post has been last edited 7 months ago by PhotosGuy with reason 'typo'. 2 edits done in total.
Jul 16, 2017 14:19 |  #2
Motorsports is for competition events, so I've moved your thread to Transportation Talk.
Re: "My issue is normally the approach and touchdown is a LONG ways away... I would say in most cases we are a half mile away from the aircraft as they touch down." Sorry, but you're going to have to find a way to cut that distance down, especially with small passenger aircraft. And expense goes up & portability goes down as the distance goes up even if you buy used equipment
Maybe a point & shoot camera with a long optical zoom would be best, but I don't have any experience with them. Maybe someone else can help.
New Image Size Limits: Image must not exceed 1280 pixels on any side.
BigAl007
Repps cum Bastwick, Gt Yarmouth, Norfolk, UK.
Jul 17, 2017 02:57 |  #3
I don't know if one of the superzoom bridge cameras is going to work for you, because the autofocus can be quite slow with these cameras, as can the time from squeezing the shutter button to the point that the shot is actually taken. This delay is often accompanied by the viewfinder/screen blacking out or freezing. You will need to find one of these cameras with at least a 900mm equivalent optical focal length. Digital zoom will not work for this.
When it comes to this if you go with a DSLR then you will be fine with any of the APS-C bodies. If considering Canon that would be any of the current Rebel series cameras upwards. When dealing with aircraft they are pretty predictable, so you don't need super advanced AF systems to track them. That is the "good" news, since they are the cheaper bodies in the range.
When it comes to lenses though if you are really limited to around 880 yards for light aircraft then you will need to be shooting with a lens that will allow you to have a focal length of 600mm. This focal length, along with some potentially serious cropping will allow you to get the images you want. I shoot airshows here in the UK at the sorts of distances you are talking about, using a lens of 600mm, and an APS-C, and I often need to make a 1.5× crop. Probably the best lens for this use is the Sigma 150-600 C, the lens I use, which is the cheapest option with Mode 2 optical image stabilisation that allows the operation of the lens stabilisation while panning. The Tamron 150-600 G1, which is the same price as the Sigma here in the UK, but I think a bit cheaper in the US doesn't have a panning mode of it's VC system, so if it detects panning it disables the stabilisation.
The big drawback of these lenses is the size, weight, and cost. The Sigma is £800 here in the UK and I think about $1000 in the US. As far as costs go there is another Sigma option, the 150-600 S and the Tamron G2 version, both of which are about $1000 more expansive. In the general scheme of things these lenses are actually very cheap, since the closest Canon lens is the 600mm f/4 L IS, which is a $12000 lens! Even the Sigma 150-600 C, which is IIRC the lightest of the 150-600 options is a big heavy lens weighing something like 3-4 Kg. It is also over 100mm in diameter. It is not possible to get a lens of this focal length into a smaller package.
Even with a suitable camera and lens you will still need quite a bit of practice to get good shots of the aircraft. One issue you will be dealing with is that for aircraft with propellers you really need to limit the shutter speed to at most 1/200s to get an acceptable amount of prop blur in the image. Landings are the worst for this, since you are usually at or close to minimum revs. It is much better if you could shoot at speeds of 1/1000s or faster, but those sorts of shutter speeds, most would say that on an APS-C camera you should shoot at that speed as a minimum when hand holding because of camera shake. Although good for sharp images it will also freeze the prop dead, and shots like that are very off putting and unnatural looking, especially to pilots or others involved in aviation.
All I can say really is like Frank suggests is get closer. If you can get within say 300 yards or so of the runway then you will be able to move down to a smaller lighter lens, like the new Sigma 100-400, which is much smaller and lighter than the previously mentioned lenses. But htis is still relative, since none of these lenses are small or compact. The laws of optics just will not allow for small lenses in these focal lengths.
Alan
My Flickr (external link)
2,184 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00091 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is gkefalas
834 guests, 325 members online
