FORUMS Canon Cameras, Lenses & Accessories Canon G-series Digital Cameras
Thread started 21 Jul 2017 (Friday) 22:35
Prev/next
Canon DPP ver 4 is not able to work with my Canon G12.CR2s
kezug
N.W. Indiana
Jul 21, 2017 22:35 |  #1
Ok, I use DPP ver 4 for my RAWs from my Canon 70D.
However, I am unable to deal with the RAWs taken from my Canon G12.
What do I need to do so that I can continue to use ver 4 for my 70D AND edit my images from the G12?
Camera's: 70D, G12 | Len's: 18-135mm IS STM, 55-250mm IS STM, 50mm f/1.8 II | Photos:flickr (external link)
gjl711
They have pills for that now you know.
gjl711's Avatar
Deep in the heart of Texas
Jul 21, 2017 22:41 |  #2
It doesn't look like DPP 4 supports the G12. If you look on Canons support page it looks like you need DPP 3.15.0
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
John ­ from ­ PA
Joined May 2003
Southeast Pennsylvania
Jul 22, 2017 20:20 |  #3
gjl711 wrote in post #18408111 (external link)
True, you can download 3.15.0 from https://www.usa.canon.​com ...g12?tab=drivers_dow​nloads (external link).
Note that both versions can be resident on the same computer so the 4.x can handle the 70D and the 3.15.0 the G12.
kezug
N.W. Indiana
Aug 04, 2017 07:12 |  #4
I took the link above, but it is just an updater. I need to have the original CD. Problem for me is that I cleaned my office up about 6 months ago and trashed a lot of CDs as I was tired of them taking up space in my drawer...I figured I could always just down load it, but NO! Canon site does not provide the original CD,even if I have the serial number from my camera body.
I have a G12, G15 and 70D in the household. All purchased by Canon or Canon resellers (Best Buy and Adorama).
After several Canon support emails (which were actually very quick turn arounds) they were unable to help other than to say I could "purchase" the software from their online store! Purchase! I already did purchase it...why am I unable to locate this software easily?
I am in a predicament because the next time I need to reformat my OS hard drive and reinstall the OS and software, I am screwed again!
Am I missing something obvious here? I just want a version of DPP that will allow me to edit my RAWs from my G12...why is that so difficult </end of rant>
Ramon-uk
Aug 04, 2017 09:53 as a reply to kezug's post |  #5
Go to the 70D downloads page here:
https://www.usa.canon.​com ...QH8HIC0L88RB0AMD0F1​Q42K25 (external link)
and download the first item, Digital solution disk software, that contains DPP 3.14, then you can update it.
kezug
N.W. Indiana
Aug 04, 2017 16:18 |  #6
Ramon-uk wrote in post #18419108 (external link)
When I go to the link you specify above, this are the software options I get. I do not see Digital Solution disk software, nor do I see DPP 3.14. I must be doing something wrong...please advise:
John ­ from ­ PA
Joined May 2003
Post has been edited 5 months ago by John from PA.
Aug 04, 2017 16:26 |  #7
Do you see on your attached image where it says Windows 10 (x64) next to operating system? Change that to Windows 7 (x64) and then you should be able to do the download and install. There isn't any guarantee it will install and run but it won't hurt to give it a try. If it won't run/install I suggest you go to http://www.northlight-images.co.uk ...mera-software-without-cd/ (external link) where there is a detailed procedure to "fake" out the Canon software.
kezug
N.W. Indiana
Aug 04, 2017 16:27 |  #8
OMG! I had to change the Operating System from Windows 10(x64)(Detected) to Windows 8.1. I was then able to see/download and install the software you suggested!
THANK YOU!!! Canon support could not give me this type of information!!!
John ­ from ­ PA
Joined May 2003
Aug 04, 2017 16:46 as a reply to kezug's post |  #9
I note on the Canon Japan website that you may have to change to "desktop mode" to have it run properly. If you are using a desktop with Win 10 you are likely in that mode. If you are using a laptop follow the directions at https://www.asus.com/u​s/support/FAQ/1013056/ (external link) to switch to desktop mode.
kezug
N.W. Indiana
Aug 04, 2017 16:52 |  #10
John from PA wrote in post #18419412 (external link)
Thanks...so far no issues running it normally, but I will now know what to do if any issues....Thanks again fellow POTN friends!
John ­ from ­ PA
Joined May 2003
Aug 04, 2017 17:15 |  #11
kezug wrote in post #18419420 (external link)
If you downloaded the Digital Solution disk and installed from that you can now do the "updater" versions and get something newer/better. Just verify compatibility with the G12 and the operating system. And note as I said above you can still have the latest and greatest 4.xx on the same PC for your 70D. I personally find 4.x to be quite nice as compared to 3.x.
kezug
N.W. Indiana
Aug 04, 2017 20:51 |  #12
John from PA wrote in post #18419435 (external link)
Thanks! Yes...I have latest DPP 4 for my 70D needs, but I needed the older version to be able to deal with the RAWs from my G12...when I am in the DPP 4.0 I am unable to view/handle the RAWs from G12.
CarloY
Joined Sep 2009
Oct 03, 2017 07:12 |  #13
kezug wrote in post #18419533 (external link)
I wonder if it is possible to get Canon's Raw Codec 1.11.0 or similar to work with later versions of DPP 4.x ? Or is codec 1.11 only for 32-bit win?
Some various info/links. (use official Canon site for any Downloads)
https://techjourney.ne​t ...-vista-7-8-free-download/ (external link)
http://support-th.canon-asia.com ...nts/TH/EN/020053180​2.html (external link)
Digital Photo Professional 4.7.1 for Windows
Last Updated : 23-Aug-2017
Issue Number : 0200531802
Says supports 70D and... G12.
Good luck.
G9's... enthusiast and hobby clicker... toying w/ Canon 2x Tele & Raynox .7x Wide.
3,637 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00101 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is samiam
832 guests, 336 members online
