FORUMS General Gear Talk Camera Bags, Backpacks & Cases
Thread started 31 Jul 2017 (Monday) 12:18
Prev/next
HOLDFAST Money Maker in combination with Peak Design anchor link!
Dj ­ R
Dj R's Avatar
Philaburbia
Post has been last edited 9 days ago by Dj R. 3 edits done in total.
Jul 31, 2017 12:18 |  #1
this is a must see for anyone with a money maker or person who would like to shoot two bodies at the same time.
original videos removed
and the major update is not on video!
enjoy
Here is how I carry two bodies at once with the Money Maker and then easily and quickly switch into hand strap and/or shoulder/sling strap in seconds.
Great for event/pro shooters
https://www.youtube.co​m ...5SlL&disable_polyme​r=true (external link)
And it all - along with a speed light - fits in this Domke F3X
Flash is in the inside left pocket
Two bodies in main chamber, both A7riii
lenses are attached, both hoods are reversed:
35 1.4 attached
85 1.4 gm attached
Batis 25 is in the inside right pocket
Money Maker dual camera strap, leather, is in the outside right pocket
Shoulder strap (sling) is inside the front pocket
Batteries, memory, snacks are all inside the outside left pocket
Happy New Year!
BAG Reviews, master list!
Sony A7RIII x2, 12-24 G f4, Batis 25 f2 Distagon, 35 f1.4 Distagon ZA, 50 f1.4 Planar ZA, 55 f1.8 Sonnar ZA, 85 f1.4 GM
mystik610
mystik610's Avatar
Joined Jan 2012
Houston, TX
Jul 31, 2017 21:27 |  #2
Hehe interestingly I'm doing something similar....I'm doing what the vid maker used to do and attached the anchor links to the moneymaker slider. But it seems like it would work better if I removed the money maker slider completely like he did.
There are horror stories of cameras falling off of the moneymaker clip. The peak design anchor links are solid as an attachment point and are really easy to attach and remove
focalpointsphoto.com (external link) - flickr (external link) - Instagram (external link)
α7ʀII - RX1ʀII - α7ʀIII
Zeiss Loxia 21 - Canon 24-70 2.8LII - Sony/Zeiss 35 f1.4 ZA - Sony 50 1.8 - Sony 85GM - Sigma 135 f1.8 ART
Dj ­ R
Dj R's Avatar
Philaburbia
Aug 01, 2017 07:31 |  #3
mystik610 wrote in post #18415902 (external link)
thumbnailHosted photo: posted by mystik610 in
./showthread.php?p=184​15902&i=i45391406
forum: Camera Bags, Backpacks & Cases
Greetings, from the video maker!
mystik610
mystik610's Avatar
Joined Jan 2012
Houston, TX
Aug 01, 2017 07:45 |  #4
Dj R wrote in post #18416173 (external link)
Ah nice! Thanks for the vid then! I actually went and did what you did and removed the holdfast slider. It's a lot lighter and more minimalistic now.
Dj ­ R
Dj R's Avatar
Philaburbia
Post has been edited 5 months ago by Dj R.
Aug 01, 2017 08:27 as a reply to mystik610's post |  #5
I know right??!!
Easier to stow the strap too!!!!!
Why are you not using a split key ring though???
mystik610
mystik610's Avatar
Joined Jan 2012
Houston, TX
Aug 01, 2017 08:40 |  #6
Dj R wrote in post #18416207 (external link)
I know right??!!
Only because I'm ok with the anchor links, though they need to be inspected regularly for wear.
I do need to get split key rings though, as to your point in the video, they add some length. I like to use the moneymaker in conjunction with the capture clips to stabilize the camera when I'm moving around and not actively shooting. The cameras swing around too much on these harnesses. But yeah the cameras don't sit low enough to easily mount to the capture while on the moneymaker. I need about about an inch more of length.
Dj ­ R
Dj R's Avatar
Philaburbia
Aug 01, 2017 21:52 |  #7
mystik610 wrote in post #18416213 (external link)
I would remove that extra peak design part, that you have attached to the MM clip, in this pic that you posted. just use a key ring.
In your case, look for a LONG oval shaped key ring! do your homework on them, titanium vs. whatever else is out there.
cheers
Dj ­ R
Dj R's Avatar
Philaburbia
Aug 10, 2017 21:16 |  #8
any update? mystik610?
Dj ­ R
Dj R's Avatar
Philaburbia
Aug 25, 2017 17:20 |  #9
VERY excited to show you the final copy of my weekly update video on my Holdfast Money Maker & Peak Design Integration Project. It's done. I finally took out the hack saw and cut off the Holdfast clips. There is nothing wrong with them or their design. I just prefer to use the Peak Design clips b/c it makes it easier for ME to move around from hand strap to tripod to single strap to dual strap. Love my Money Maker!
There is also a bonus, which is actually first. It includes a quick look at the Peak Design Sling bag and how I can get the Money Maker into this bag, along with two D750 and two pro primes!
https://youtu.be/6dAgK​BsC-rw (external link)
mystik610
mystik610's Avatar
Joined Jan 2012
Houston, TX
Sep 12, 2017 08:53 |  #10
I'm going to add the sliders back onto the harness. I put this to use for the first time this weekend and realized that the sliders are designed the way they are so you can pull the camera away from your body while shooting without obstruction. I had issues shooting without the sliders....for the camera on my left side, I had to unmount it to shoot.
Dj ­ R
Dj R's Avatar
Philaburbia
Sep 12, 2017 12:29 |  #11
mystik610 wrote in post #18450174 (external link)
pls watch the video I posted in #9 here
Dj ­ R
Dj R's Avatar
Philaburbia
Post has been edited 9 days ago by Dj R.
Jan 06, 2018 17:11 |  #12
new video links posted in original post
major update
35 1.4 attached
85 1.4 gm attached
Happy New Year!
1,334 views & 2 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00087 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is H1L2J3
921 guests, 421 members online
