Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 17th of March 2006 (Fri)   #1
Arnie1
Default Flash techniques for receptions
We all loath hotshoe flash....but sometimes theres just no other options.
Whats your preffered method of keeping it subtle, reducing harsh shadows and keeping relatively easy to shoot?.
Arnie.
Arnie1 is offline   Reply With Quote
Old 17th of March 2006 (Fri)   #2
PineCone
PineCone's Avatar
Default Re: Flash techniques for receptions
to achieve this i normally bounce the flash up... otherwise i direct the flash upward and bring out the diffuser that comes with the flash (attached) and set to lowest f/stop
PineCone is offline   Reply With Quote
Old 17th of March 2006 (Fri)   #3
Wedding Shooter
Wedding Shooter's Avatar
Bounce with Lightsphere and expose for the background.
Chris
Wedding Shooter is offline   Reply With Quote
Old 17th of March 2006 (Fri)   #4
DaveG
Arnie.
I'd use a bracket so whatever shadows fall, will be behind the subjects. Then I'd use a relatively high ISO since none of these shots are likely to end up bigger than 4x6. That way I can use a larger aperture and drag the shutter. Then my flash is just acting like a fill light.
That technique won't work if the room is really dark - you can't use available light if there isn't any. And there are certain shots at the reception that must be very sharp. But for small candid shots this should work well and look very natural.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
DaveG is offline   Reply With Quote
Old 17th of March 2006 (Fri)   #5
BLINN
BLINN's Avatar
I tend to use a pocket bouncer sometimes with or with out a bracket.
MBCL Photography
Michael Blinn
Your Eye's the Limit
http://mbclphotography.com
BLINN is offline   Reply With Quote
Old 17th of March 2006 (Fri)   #6
kawter2
kawter2's Avatar
im usually at around iso 1250 or 1600 and shoot 2.8 1/30-40th with the omni bounce (that is if there is something to bounce off of.. if not. it is just direct flash
Wedding Blog
Eric J. Weddings
kawter2 is offline   Reply With Quote
Old 17th of March 2006 (Fri)   #7
jamiewexler
jamiewexler's Avatar
I also shoot at ISO 800-1600 with a flip-it diffuser positioned to best take advantage of the light. If there's a nice ceiling/wall to bounce from, the flipit is bent back to just throw a little light forward. If there's nothing to bounce from, the flipit is angled forward to send more light. I also use a bracket on one body.
jamiewexler is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #8
DAVIDJAY
DAVIDJAY's Avatar
Another fun thing you can do is use Pocket Wizards for some off camera directional lighting and it can make for some really nice shots!
Here's a shot I took using a quantum setup but now I just use a 550 because those have more than enough power.
I've also just figured out a fun way to stick my flash to the wall using these little suction cup things that car photographers use!
Cheers,
DJ
www.davidjay.com
DAVIDJAY is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #9
PIXI_666
PIXI_666's Avatar
For someone who hasn't got a bracket just yet, i don't loath hotshoe i just work with what i have!
"Capturing, Creating & Preserving your memories"
Adelle Cousins Photography
www.adellecousins.com.au
info@adellecousins.com.au
PIXI_666 is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #10
llaamaboy
llaamaboy's Avatar
I used a slave normally set to go off 1 stop brighter making the on camera stobe the fill light. It would be hand held by an assistant who was trained to bring in light giving camera something called "short" lighting. Taller assistants were perferred.
Llaamaboy
llaamaboy is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #11
Phil V
My favourites are; bare flash bounced wall or ceiling (try bouncing the light from wall behind you), lightsphere bounced off ceiling, bare flash bounced off reflector behind me (assistant holds reflector).
I'm definitely going to try some slaved flash for effect, I love Davids shot above and I've also been inspired by some rim-lit dancing shots.
Always try to keep as much of the ambient as possible, and when trying to show movement use 2nd curtain sync.
Phil V is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #12
Arnie1
Cheers,
DJ
Cool shot.
I have 2 550's and need to get practicing with this technique....any advice?
Cheers
Arnie
Old 18th of March 2006 (Sat)   #13
NGrinerPhoto
bouncing monolightgs off the ceiling triggered by pocketwizards (filling the room with light)
NGrinerPhoto is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #14
llaamaboy
llaamaboy's Avatar
Be aware of bounce light in colorful rooms. Many cultures have different (read bright colors) mind sets for room colors and as your light bounces off said surfaces, the wall color changes the flesh tone (slighty).
I would almost suggest a small "soft box" to pass the stobe light through a translucent material. Again ... this is a personal creative choice we get to make, but I always liked light passed through tanslucence rather than bounced. The quality (nature) of the light approached that of the north window light.
Run some tests and make up your decisions on the best lighting for the job in front of you. Knowing more than one way to affect light is always a good thing. One very important aspect of photogrpahy is light, how its affected and how your medium records it. What I am trying to figure out now (remember 99% of my work has been film/print based) is how the digi camera records the scene so I will be able to see the scene as the camera does. A really good test for that is to go outside noon and photograph shadows. Take your result and look at the final product while you are looking at the same scene. The difference between what you see in front of you and what you see on your final presentation (Print?) might surprise you.
I do ramble...
Llaamaboy
5D, 24-105L,
180mm f/3.5L Macro
6 MP Pentax Optio WPi
"We know that communication is a problem, but the company is not going to discuss it with the employees." (Switching supervisor, AT&T Long Lines Division)
Old 20th of March 2006 (Mon)   #15
bpuppy
bpuppy's Avatar
Tv mode ... ISO 1600 ... 1/15 or even 1/10 with rear curtain sync and let things blur. If I want to minimize blur, I just raise the shutter speed.
I bounce when I can.
bpuppy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
receptions with flash jjmucker Weddings and Other Family Events 42 25th of April 2007 (Wed) 20:32
techniques for better on-camera flash jrsforums Small Flash and Studio Lighting 5 25th of January 2006 (Wed) 21:48
Fill Flash Techniques rsmith6621ab Canon EOS Digital Cameras 2 9th of January 2005 (Sun) 06:19
Flash techniques jimsolt General Photography Talk 4 17th of December 2004 (Fri) 19:05
off camera flash, techniques? sGu General Photography Talk 18 18th of October 2004 (Mon) 16:12
