Thread started 03 Sep 2017 (Sunday) 19:52
Prev/next
Micro adjust lenses
James ­ Crockett
James Crockett's Avatar
Joined May 2017
Sep 03, 2017 19:52 |  #1
How do you micro adjust lenses? Thanks
Bassat
"I am still in my underwear."
Bassat's Avatar
Joined Oct 2015
Bourbon, Indiana - USA
Sep 03, 2017 19:54 |  #2
You don't. You micro adjust how your camera responds to a particular (or all) lenses. The camera has to be capable of the feature.
Tom
James ­ Crockett
Joined May 2017
Sep 03, 2017 19:58 as a reply to Bassat's post |  #3
That's what I'm trying to learn. Thanks!
TooManyShots
NYC
Post has been edited 5 months ago by TooManyShots.
Sep 03, 2017 20:25 |  #4
Is my quick way and very efficient...even to properly calibrate my Sigma 18-35 art lens. With the way I do it, I use shot samples from LiveView AF. The AF under LiveView is generally more accurate than using your viewfinder. I would test the lens under 3 shooting distances....near the lens' min focusing distance, middle range distance from 5ft to 15ft (depending on your lens and some lens would focus to infinity after 6 ft). Check your focusing distance scale on your lens. Long telephoto lens would have a great middle distance range...something like 15ft to 30ft. The last distance to be tested is at infinity.
I used to use a printed out chart but find it too small. Now, I use a large box with some very bright words and letters on it. For a standard zoom or shorter focal length lens, I would put this box at 6 ft. I would use the LiveView AF to determine if the shooting distance is actually at 6ft. Just look at the distance scale on the lens. Then, I take a shot under the LiveView AF. The shot is going to be sharp. And test the lens at wide open all the way. And the focusing distance scale should be lined up at "6." Or not, move your tripod with camera if needed. Now, pay attention where the vertical bar positions on the focusing scale. It could be slightly in front of the number "6." Or in the middle of it. Just behind it. Then, you switch to viewfinder AF. Now, look at again where the bar positions now. If the position moves in front of the "6," the lens is front focusing. If at the back of the "6," the lens is back focusing. See, you don't need test shots to see if the lens is front focusing or back focusing this way.
To correct front focusing, set the MA value to a + setting. Try +2, +4, +6 until the vertical bar (in your focusing distance scale on the lens) positions the same way as in under the LiveView AF. Easy, right??? Do the same with back focusing using - value. Hopefully, now, this MA value would also fix your focusing issue at the near end of the lens min focusing distance, and at infinity. You have to run the same test under the lens's near min focusing distance. For infinity testing, I would use something like a car or a house across the street.
One Imaging Photographyexternal link and my Flickrexternal link
Facebookexternal link
gjl711
They have pills for that now you know.
gjl711's Avatar
Deep in the heart of Texas
Sep 03, 2017 20:33 |  #5
There are many different methods and it's really up to you as to which method you like. Have a look at this page (external link) for lots of info. Scroll down to the "The better DIY approach" for the easiest method requiring no $$.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
RhodyPhotos
Joined Jun 2014
providence, ri
Sep 03, 2017 22:46 |  #6
Which camera do you have? Some camera models provide this feature, others don't.
James ­ Crockett
Joined May 2017
Sep 06, 2017 16:38 |  #7
I'm using the 5dmark ii. Thanks everybody! love this forum.
1,603 views & 0 likes for this thread
Micro adjust lenses
made in Finland
by Pekka Saarinen
Spent 0.00089 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is trashtrev
916 guests, 483 members online
