Thread started 13 Sep 2017 (Wednesday) 20:52
Prev/next
color-matching 2 monitors
ncjohn
Asheville NC
Sep 13, 2017 20:52 |  #1
I've read many times that you can't get 2 monitors to match (color, brightness, etc) so I was wondering what's the usual work-around? Do you calibrate one, then eye-ball the other until they're close?
I just got an Asus PB238Q to go with my ViewSonic VP2365wb, and I'm still in the fooling-around-with-it stage. When I calibrate them both, the difference is atrocious, but I can manually adjust the VS until it's very close to the calibrated Asus. I'm tempted to stick with that, but I know I won't :-); there's still too much fooling around to do before settling on a setting.
davesrose
Title Fairy still hasn't visited me!
Atlanta, GA
Sep 13, 2017 22:17 |  #2
I believe if you try to manually change the color of two monitors, you'll never be satisfied! Based on your perception at the time, they may start to look close. Then with other light conditions and times, you'll start seeing deferences. IMO, it's totally worth it to invest in a calibration system. It consists of a sensor that might monitor ambient light, but will go flush with the surface of your monitor and configure it to be consistent. The overall color temp will be the same across all monitors.
Canon 5D mk III , 7D mk II
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
Damo77
Damo77's Avatar
Brisbane, Australia
Sep 14, 2017 03:24 |  #3
Don't use them both for editing. Edit on the one that calibrates best, and use the other one for panels, email, etc.
Damien
Website (external link) | Facebook (external link)
kirkt
Philadelphia, PA USA
Post has been last edited 4 months ago by kirkt. 3 edits done in total.
Sep 14, 2017 07:42 |  #4
Why can't you achieve this, at least within the limitations of the two display devices? This is what color management is all about. Using the proper hardware and software makes this possible. That said, trying to make an incapable display match a very capable display is probably unrealistic unless you calibrate and profile to the lowest common denominator.
kirk
Kirk
images: http://kirkt.smugmug.c​omexternal link
Hen3Ry
Hen3Ry's Avatar
Aptos, CA, USA
Post has been edited 4 months ago by Hen3Ry.
Sep 14, 2017 10:31 |  #5
I have two monitors - one (NEC Multisync LCD30WQXI1) has spec of 97.5% Adobe RGB, and the other (Dell UltraSharp UP2716D) claims 100% AdobeRGB.
I can't see the difference between them, even with an image spanning both.
Je n'avais pas besoin de cette hypothèse-là.
ebiggs
ebiggs's Avatar
Joined Oct 2012
Spring Hill, KS
Sep 14, 2017 10:45 |  #6
I use two monitors. I have for years. I think it helps if they are the same brand and model. Mine are and I can't see or tell if there is a difference in them.
G1x, EOS 1Dx, EOS 1D Mk IV, ef 8-15mm f4L,
ef 16-35mm f2.8L II, ef 24-70mm f2.8L II, ef 70-200mm f/2.8L IS II,
Sigma 150-600mm f5-6.3 DG OS HSM Sport
*** PS 6, ACR 9.3, Lightroom 6.5 ***
ncjohn
Asheville NC
Sep 14, 2017 16:32 |  #7
Well, I'm very surprised and pleased that you guys are able to get your monitors to match; I've just read so many times that it's impossible.
And I found out why mine looked so different when I calibrated the new Asus: I've always calibrated the Viewsonic to 5000k and I realized I accidentally calibrated the Asus to 6500. (But then when I tried to calibrate the Asus to 5000 I ran into a problem. But that needs a new thread of its own.)
Thanks for the replies.
Hen3Ry
Hen3Ry's Avatar
Aptos, CA, USA
Sep 14, 2017 19:35 |  #8
ncjohn wrote in post #18452410 (external link)
Well, not to rag on you or anything, but I doubt that Photoshop or Adobe RGB was on the minds of the designers of either of those monitors. I'm not surprised that at 5000 they look different. You might try them at a more normal 6500.
John ­ from ­ PA
Joined May 2003
Southeast Pennsylvania
Sep 14, 2017 19:57 |  #9
Two monitors can be made to match; more than you wanted to know can be found at https://photo.stackexc​hange.com ...d-i-set-my-lcd-monitor-to (external link). The software recommend in the response is pricy but a lot of what you want to do can be accomplished by using the procedures at http://www.lagom.nl/lc​d-test/ (external link). The test images there can be saved to a stick and taken to a store for test purposes.
ncjohn
Asheville NC
Sep 18, 2017 11:47 |  #10
John from PA wrote in post #18452551 (external link)
Wish I'd seen this sooner; I didn't get notified that this thread had more responses. Thanks for the links, I'll definitely take a look.
5,211 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00089 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is Oldkasilof
886 guests, 481 members online
