FORUMS Photography Talk by Genre Astronomy & Celestial Talk
Thread started 22 Sep 2017 (Friday) 08:19
Prev/next
How to check a used 14mm 2.8 before buying?
kaitlyn2004
Sep 22, 2017 08:19 |  #1
I don't normally buy used lenses, and especially one that is known for such variety in QC... but that could happen buying new anyway too.
So how do I actually check the lens to make sure it's "good enough" - what benchmarks would I use?
I recall hearing about uneven focusing across the frame and the distortion (but not sure if the distortion differs across copies?)
Many thanks! This lens looks harder to buy than I thought...
New Zealand Travel Photography (external link)
My Instagram (external link)
MalVeauX
"Looks rough and well used"
MalVeauX's Avatar
Joined Feb 2013
Florida
Post has been edited 4 months ago by MalVeauX.
Sep 22, 2017 08:31 |  #2
I don't think you'd be able to tell on an LCD on the camera, especially stopped down.
You'd really need to pixel peep on a monitor to see it most likely.
Maybe wide open (F2.8) and minimum focus distance and then compare corners on LCD at highest magnification?
Very best,
kaitlyn2004
Sep 22, 2017 08:52 |  #3
MalVeauX wrote in post #18457763 (external link)
Very best,
Hmm, could also ask them to send me a sample shot... just of a wall with detail on it? To check evenness throughout frame?
MalVeauX
MalVeauX's Avatar
Joined Feb 2013
Florida
Sep 22, 2017 08:53 |  #4
kaitlyn2004 wrote in post #18457779 (external link)
Brick wall or tree foliage at F2.8 and F16 should show something if there's something. Just don't misjudge distortion for out of focus.
Very best,
01Ryan10
Joined Aug 2012
OC, California
Sep 27, 2017 14:08 |  #5
I'd suggest to just buy the Rokinon variety 14mm 2.8 brand new from reputable store. Return for new if needed.
http://RyanLunaPhotogr​aphy.com (external link)
IG: @01ryanluna10 (external link)
kaitlyn2004
Sep 27, 2017 20:34 |  #6
01Ryan10 wrote in post #18461584 (external link)
Why do you recommend the more-expensive rokinon if they're all just rebadges? What's the difference in buying the namebrand?
01Ryan10
Joined Aug 2012
OC, California
Sep 27, 2017 20:40 |  #7
kaitlyn2004 wrote in post #18461812 (external link)
I mean...buy any name, just make it new.
Left ­ Handed ­ Brisket
That's my line!
Left Handed Brisket's Avatar
Joined Jun 2011
The Uwharrie Mts, NC
Sep 27, 2017 20:53 |  #8
Brick wall, make sure you are set up parallel and about 8-10 feet away. Check each corner as compared to the middle.
Checking on the screen was plenty for me to see trouble in a potential purchase so I declined. It was craingslist/in person though.
PSA: The above post may contain sarcasm, reply at your own risk | Formerly he's gone before apostrophe-gate | Not in gear database: Canon 70-210 3.5-4.5, Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
AdamT
Joined Jan 2013
Dec 30, 2017 23:12 |  #9
You could see a lack of sharpness in the corners on the screen!? Can this lens be that bad sometimes?
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 100mm f/2.8L Macro IS USM, EF 50mm f/1.8 II |
Celestron
Texas USA
Dec 31, 2017 09:02 |  #10
At the corners of an image check for coma and try finding reviews and see if the lens is tack sharp or known for soft images . Yes a brick wall is good . Ask for an unedited image in RAW so corners can be checked up close .
RDKirk
Adorama says I'm "packed."
RDKirk's Avatar
Joined May 2004
USA
Jan 03, 2018 19:37 |  #11
Look at the lens very closely--even using a magnifying glass-- for any signs of impact. Look carefully around the focusing ring for any misalignment. Look through it, hold it up to the light, angle it to your eye, for any signs of scratching or fogging or fungus. Twist the focusing ring off the camera and listen and feel carefully for any rubbing. Put it on a camera, focus at different distances and listen to the motor carefully. Watch it as it focuses for any hitches.
Smell it--yes, smell it.
568 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00117 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is hub21
983 guests, 451 members online
