FORUMS Photo Sharing & Visual Enjoyment Weddings & Other Family Events
Thread started 18 Oct 2017 (Wednesday) 09:15
Graduation photo shoot
anitaw2
Joined Jun 2015
Oct 18, 2017 09:15 |  #1
My daughter and her friends are graduating next June. They would like me to shoot them with their Grad gowns (red) this weekend. Did anyone here ever do a photo shoot of grads, I would love to have some ideas. I'm planning to take them on a walking trail with the fall leaves, lake, bridge and so on... any examples would help.
Anita W.
david.g.photo84
Joined Sep 2017
Oct 18, 2017 17:48 |  #2
I'm not a pro and just getting back into photography, but I never liked the look of posed walking shots. How about using a zoom lens and not being super close and just let them interact with each other as they normally do. I'm sure they would appreciate the fact that you are not right on them and hearing every word they are saying and you will get a lot of great unposed pictures. You can also try searching flickr for "graduation" for some ideas. Just my .02.
Micro5797
Gallery: 15 photos
Joined Dec 2013
Oct 18, 2017 20:39 |  #3
By ideas, do you mean poses?
With social media and Pinterest and kids being into all of this. I would assume that they will come up with a ton of ideas. A quick Pinterest or google search will find a lot of ideas.
One idea is to have them throw leaves into the air (or people on the sides throwing some over head as well). 1/320s will give a little motion blur to the leaves.
While on the trail, have a couple kneel (or almost) down in the front with others standing behind.
For most poses, keep them close like you would a family shoot.
The cliche pose is to have everyone jump in the air, if all girls possible hand holding while jumping.
Throwing hats in the air.
Siting on boulders or stumps.
Choose your time of day, I love evening back lighting, but with a group you have to be careful of hot spots on the sides of their faces. you may want an assistant with a scrim/diffuser. I prefer OCF.
Canon 70D | 70-200mm f2.8 MK1 | 85mm f1.8 | 50mm f1.8 | Tamron 17-50mm f2.8 non vc| Nissin Di866 II
anitaw2
Joined Jun 2015
Oct 19, 2017 08:42 |  #4
Thanks for all the ideas. I went on Pinerest and found a lot of good poses. We are going tonight at 4:30 so the sun will be setting at around 6pm so it will give me a bit of time.
Anita W.
Micro5797
Gallery: 15 photos
Joined Dec 2013
Oct 21, 2017 20:59 |  #5
Anxiously awaiting some samples from the session.
anitaw2
Joined Jun 2015
Nov 09, 2017 09:50 |  #6
Here are a couple. As per someone's suggestion, I was wanting the 135mm look so I bought a 85mm f1.8, but I find it's isn't focusing correctly. I often get very soft images, does this happen with this lens or is it the photographer??
Anita W.
jcolman
Gallery: 12 photos
Nov 09, 2017 10:12 |  #7
If you have to shoot in full sunlight, try to add some fill light either by using a reflector or off camera flash,
IMAGE: https://i.imgur.com/NjVrC09.jpg
I prefer to place my subjects in the shade and then add a bit of off camera flash to make them "pop". Be sure to use some sort of diffusion like a soft box or umbrella if you want smooth light.
IMAGE: https://i.imgur.com/wUfxiYM.jpg
www.jimcolmanphotograp​hy.com (external link)
Micro5797
Gallery: 15 photos
Joined Dec 2013
Nov 09, 2017 17:24 |  #8
anitaw2 wrote in post #18492603 (external link)
The second one seems sharp, the first a little soft.
I would look into micro focus adjustment. The lens may need to be calibrated to the camera body. If you have a local place that sells lens, they probably do this for about $25. You can do it your self, but it can take a while to learn it and be confident your first time.
One way to tell if this is an issue is when you look at a soft image, look at teh ground or wall next to the people and see if it is in focus in front of the person (front focusing) or behind the person (back focusing).
The 85/F1.8 is a great lens, but keep in mind that it is prone to producing CA (Chromatic aberration). In your first image, look at the green outline on the tree and the magenta on the railing. This is easy to fix. In Lightroom, under lens correction, tick remove CA. Sometimes you may have to use the eye dropper or adjust the amount to fine tune.
Looks like they had a great time, thanks for sharing the images!
anitaw2
Joined Jun 2015
Nov 10, 2017 10:40 |  #9
it's funny mention the front focusing. I had just bought this lens used and was trying it out. I noticed it was front focusing and did micro adj. in-camera. I think it's a bit better now. As for CA, I have Lightroom 4, I dont' think I can fix that in this version but I could be wrong. If the 85mm a good lens. I got it because I love the look of the 135mm but with a 7D, that would be too tight.
Anita W.
Micro5797
Gallery: 15 photos
Joined Dec 2013
Nov 10, 2017 13:02 |  #10
anitaw2 wrote in post #18493373 (external link)
A quick google says that LR4 has CA removal.
"Scroll down to the Lens Corrections panel, and click on "Color". Then check the "Remove Chromatic Aberration" checkbox."
Yes, 135 would be pretty tight, though i often use a 70-200 on a cropped body @ 200mm for individuals.
rjharris
Gallery: 68 photos
Nov 13, 2017 21:19 |  #11
I like these types of look for graduation gowns. I'm not a great big fan of them having the full gown on as it really distracts from the lady themselves. For what it's worth, the blonde in the bottom photo just won a national championship with her D III college in volleyball over the weekend.
mdvaden
Gallery: 21 photos
Nov 19, 2017 01:30 |  #12
thumbnail
Hosted photo: posted by anitaw2 in
./showthread.php?p=184​92603&i=i24704147
forum: Weddings & Other Family Events
thumbnail
./showthread.php?p=184​92603&i=i192828103
I like all of these photos.
About the lens question, I had that 85mm 1.8 years ago and would never consider going back to it again. It's more practical than the 135mm, but the 135mm is amazing and one of the best lenses I've ever used to nailing focus. I didn't have problems with that 85 for focusing, but didn't care for the way it rendered images compared to other lenses.
I prefer the newer Tamron 85mm too.
But if all I had was the 85mm 1.8, I'd be okay with it if that's what was available.
vadenphotography.com (external link) . . . and . . . Coast Redwoods Main Page (external link)
JessicaJones215
Joined Sep 2017
Nov 19, 2017 16:16 |  #13
Some good ideas in here too
http://photography-on-the.net …/showthread.php​?t=1275976
1,557 views & 8 likes for this thread
version 2.0 /
Latest registered member is heytex
820 guests, 470 members online
