FORUMS General Gear Talk DIY & Customizing
Thread started 21 Oct 2017 (Saturday) 09:51
Photobooth Camera Models?
werds
"Yes, Sire. You'll shut your trap!"
Gallery: 12 photos
Joined Mar 2014
Oct 21, 2017 09:51 |  #1
I know that you can setup a photobooth with practically anything with a camera lens but I want to continue using a DSLR of some variety if possible. Currently I am using a Nikon D5300, and the one thing that bothers me is how long between start of picture and end of picture it takes for each shot to be done. Because of the sounds associated with the shutter it seems to throw people in the booth off.
Does anyone have suggestions for DSLR models (not necessarily Nikon) that do not suffer from lag so much when in photobooth operation?
Gear: Nikon D750, Nikon D7200, Sigma 17-50 2.8 OS, Sigma 50-150 2.8 OS HSM EX , Nikon 70-200 2.8 VR1, Tamron 24-70 2.8 VC, Tamron 70-200 2.8 VC, Tamron 28-300mm Di VC PZD, Tamron 16-300mm VC PZD, Tamron 150-600 VC, Nikon AF-S 50mm 1.8, Nikon SB-900
POTN Seller Feedback (and other)
pat.kane
Oct 21, 2017 19:48 |  #2
I'm not following what you're stating as I wouldn't expect any lag on a dSLR unless the camera is trying to focus. If you've not set manual focus, I'd suggest starting there. Good luck.
1Dx, 5D3 and some L glass (gear list / feedback)
http://MaxPreps.DMVpix​.com (external link)
http://www.DMVpix.com (external link)
iAMB
Oct 23, 2017 13:44 |  #3
Are you are not using a flash? The flash will eliminate the need to be below 1/100th of a second. Any longer than that and you have too long of time for people moving as they pose. Set aperture at f/11-16 to keep everyone in focus.
Canon 6D Mk I
24-70mm F/4L , 70-200mm F/4L , 50mm 1.8 I , Rokinon 14mm F/2.8 & 35mm F/1.4
"I'm so far behind, it looks like I'm winning"
-Adam
Chet
For $20, I'll be your friend.
Gallery: 125 photos
Oct 23, 2017 14:12 |  #4
I use a Canon xti with an older Elinchrom power unit and 3 flash heads. I modified a tattoo gun foot switch as my shutter release for a self contained setup that goes over well. I've tried Canon Speedlites, but the recycle time always kills the deal and 30% of the shots go directly in the trash bin. Any way Using the Canon 16-40 lens ths is what I usually get as out put. This year I'm also using a 1d3 as well. They can be had for cheap now a days and they are tanks.
Though most low buck camera's with a couple decent flashes will do the trick.
IMAGE: https://photos.smugmug.com/photos/i-vqVZLJ9/0/1c5a4524/X2/i-vqVZLJ9-X2.jpg
IMAGE: https://photos.smugmug.com/photos/i-4DPdbwB/0/c4ed4ba1/X2/i-4DPdbwB-X2.jpg
IMAGE: https://photos.smugmug.com/photos/i-LNNcM2c/0/91823e97/L/i-LNNcM2c-L.jpg
Canon flash when they work.
IMAGE: https://photos.smugmug.com/photos/i-b3fMhRP/0/c0b7667a/L/i-b3fMhRP-L.jpg
Canon when some flashes don't recycle in time or batteries are exhausted.
IMAGE: https://photos.smugmug.com/photos/i-BB349L8/0/1cbc4c65/L/i-BB349L8-L.jpg
Curator of the Bob's Pickle Emporium experience. -As always, One location to serve you better!
~Feel good today and donate to this great forum~ LINK
My Gear List
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Nov 01, 2017 21:54 |  #5
werds wrote in post #18477498 (external link)
Either your camera is broken (unlikely) or you are doing something wrong. There is no reason why any DSLR would lag in proper use (as in proper settings and sufficient light). Changing camera won't make any difference when the issue is caused by user error.
So what settings are you using on the camera and what lighting are you using?
Dan Marchant
bigVinnie
Jan 26, 2018 10:54 |  #6
The lag the OP may be referring to is the lag between switching from live view to taking the photo.
The lag is directly related to the speed of the shutter. The higher the FPS rating of the camera the less lag.
My hands down favorite camera for booths is the 40d. At 8fps is switches fairly quickly. It also has a function to turn off exposure preview in live view. A must have for most photobooth software.
Act1 Photo Booths (external link)
999 views & 0 likes for this thread
Latest registered member is johnowens
735 guests, 427 members online
