Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EF and EF-S Lenses > Lens Sample Photo Archive
Reply
Thread Tools Display Modes
Old 18th of March 2006 (Sat)   #1
yb98
yb98's Avatar
Default Canon EF 50mm f/1.8 II + Kenko Tubes
I received yesterday the kenko tubes and made today some tests with the 50 mm 1.8 to have an idea about the magnification factor and the minimal focus distance that these tubes can gives. Here are the results.
Yacine.
50mm Alone
Minimal Focus Distance : 36 cm
50mm with 12 mm Tube
Minimal Focus Distance : 14 cm
50mm with 20 mm Tube
Minimal Focus Distance : 10,5 cm
50mm with 12+20 mm Tubes
Minimal Focus Distance : 7.5 cm
50mm with 36 mm Tube
Minimal Focus Distance : 7 cm
50mm with 12+36 mm Tubes
Minimal Focus Distance : 5.5 cm
50mm with 20+36 mm Tubes
Minimal Focus Distance : 5 cm
50mm with 12+20+36 mm Tubes
Minimal Focus Distance : 4 cm
Gallery
yb98 is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #2
rudgej
Couch-potato photographer
Default Re: Kenko Tubes + 50 mm 1.8 Tests (8 pics)
This is a very useful series of shots Yacine, and is great for giving people an idea of what is possible.
rudgej is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #3
gugu
gugu's Avatar
Very usefull post!
Thanks.
Are you sure that the focus distance for the 50mm f/1.8 is 36cm?
Mine says 45cm.
Canon 350D + OPTEKA BGRXT grip
Canon EF-S 18-55mm f/3.5-5.6 Kit Lens
Canon
EF 28-135mm f/3.5-5.6 IS USM
Canon EF 70-300mm f/4-5.6 IS USM
Canon EF 50mm f/1.8 MK II
Canon 580EX
Lowepro Orion Trekker II
gugu is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #4
RichardtheSane
RichardtheSane's Avatar
Originally Posted by gugu
Very usefull post!
Thanks.
Mine says 45cm.
Maybe this is referring to the MK1 version.
On my Mk1 45cm is the first mark, but the focus mechanism allows focussing slightly closer than that.
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
RichardtheSane is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #5
yb98
yb98's Avatar
Very usefull post!
Thanks.
Mine says 45cm.
I have a doubt now... may be It was 46 instead of 36 then, I will check again
Gallery
Old 18th of March 2006 (Sat)   #6
yb98
yb98's Avatar
Well I checked again and I confirm, it's 36 cm.
Gallery
Old 18th of March 2006 (Sat)   #7
gugu
gugu's Avatar
Did you measure?
If you did, where did you measure from?
The front element of the lens?
Maybe 45cm that is writen on the lens is the distance from the sensor.
Canon
Canon 580EX
Old 18th of March 2006 (Sat)   #8
yb98
yb98's Avatar
I measure from the front of the lens.
Gallery
Old 18th of March 2006 (Sat)   #9
Jayson_Ang
Jayson_Ang's Avatar
very useful post ...
geez ... i'm gonna think twice whether should i get an extension tube for insect shots ...
the distance's too close, will scare the insect away
Canon EOS 350D :: EF-S 18-55mm :: EF 75-300mm
Jayson_Ang is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #10
Jon
Moderator
Slayer of Trolls
Jon's Avatar
Distance on the scale usually measures from the film plane. So 36 cm from the front of the lens would be about right.
Jon
EOS, PowerShot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Marketplace Changes *** IMPORTANT! ***
Jon is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #11
Bob_A
Bob_A's Avatar
And for anyone reading this thread, the "film plane" is indicated on the camera body by the marking just to the left of the viewfinder and to the right of the mode dial (looks like the greek letter phi).
Bob
D700, G9, 20D, Elan II and a bunch o stuff
Bob_A is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #12
Lotto
Lotto's Avatar
Very impressive. Thanks for sharing.
5D, 24-70L, 70-200L IS, 50 f1.4, 100 Macro, 580 & 430EX
Lotto is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #13
Jon
Moderator
Slayer of Trolls
Jon's Avatar
As discussed at length, and with varying degrees of seriousness, here.
Jon
Old 18th of March 2006 (Sat)   #14
Mike Bell
Mike Bell's Avatar
That's where long focal length Macro lenses come into their own. You can get better magnification with a Sigma 150mm macro at a distance of 20cm than Yb98 got at 5cm. Costs much more than a few tubes of course!
Mike
Canon 5D Mk2, 1D Mk2N, EF 16-35 f2.8 L MkII, EF 24-105 L, TS-E 24 L, EF 28 f1.8, EF 50 f1.4, EF 85 f1.8, EF 135 f2 L, EF 70-200 f2.8 IS L, EF 100-400 IS L. Sigma 150 EX DG APO Macro. Speedlites 580EX2 & 430 EX. Lee filters. Access to Canon 350D, EF-S 17-85, EF-S 60.
Visit my Flickr galleries
Mike Bell is offline   Reply With Quote
Old 18th of March 2006 (Sat)   #15
ejwebb
ejwebb's Avatar
Thanks for the post - very interesting! You don't have a 70-200 you can do this with do you?
ej
Current gear: Canon 20D, 70-300 IS, 85 1.8, 550EX; Tamron 17-50; Vivitar 283's; Bogen tripod w/ ballhead; Kenko tubes; Canon A590IS
Former gear: Canon 300D, 24-105 IS L, 70-200 L, 28 1.8, 50 1.4, 28-105, 70-210, 50 1.8, 28 2.8, 18-55, G3, A40; Sigma 50-500, Tamron 28-75, Tokina 12-24.
ejwebb is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
50mm 1.4 w/Kenko Extension Tubes magnification jclaveria Macro 5 1st of May 2007 (Tue) 06:36
WTB: 50mm 1.8 and Kenko tubes Andrew Pratt Classifieds: Buy 0 18th of April 2007 (Wed) 16:23
Kenko tubes for 50mm 1.4? Beccaboo Canon EF and EF-S Lenses 4 7th of March 2007 (Wed) 12:06
Kenko tubes for my 50mm 1.4? Saturation Canon EF and EF-S Lenses 3 24th of January 2007 (Wed) 22:12
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
