Thread started 02 Nov 2017 (Thursday) 17:11
Prev/next
as close as i can get for subject (exposure meter)
Ltdave
Joined Apr 2012
the farthest point east in michigan
Post has been last edited 2 months ago by Ltdave. 2 edits done in total.
Nov 02, 2017 17:11 |  #1
i used to use and still have a Gossen Luna Pro meter...
nothing super fancy and it didnt have a "flash" function (that was the Luna Pro F) but it worked really well for me...
since it used 1.35v Mercury batteries that have been discontinued for some time (and im not sold on the new "suitable substitute" what is a good standard type, easy to use, similarly functioned meter?
i usually see people mention the Sekonic meters (there seems to be quite a few of them!) but i was wondering if there were others that people like...
ive got an old Weston meter but i cant read the numbers on the scale anymore (bad eyesight and extremely small type size)...
bobbyz
Bay Area, CA
Nov 03, 2017 16:40 |  #2
L358 used preferably with the radio module in case you using PW triggers.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
F2Bthere
F2Bthere's Avatar
Joined Oct 2015
Nov 03, 2017 17:39 |  #3
I used the Gossen with flash meter for many years and it runs off a standard 9v battery. I have always been quite happy with it.
I got a good deal on a Sekonic which included a built-in spot meter. The added functionality was the only reason I upgraded.
The Gossen is still a great meter. The Gossen has a superior interface which is simple, intuitive and fast to run. The Sekonic isn't bad (and has boatloads more features), but it takes a bit more focus to learn.
So, if you just want flash and a better battery, I would hunt up a used Gossen meter of slightly more modern design.
If the spot meter would serve you well, I recommend Sekonic. The Seconic can also compare readings, be programmed for your camera, trigger radios if they are pocket wizard or Elinchrom, etc.
C&C always welcomed...
On my images, of course, and on my words as well--as long as it's constructive :).
https://www.instagram.​com/storyinpictures_co​m/ (external link)
Ltdave
Joined Apr 2012
Nov 03, 2017 23:22 |  #4
right now, im just running some 600ex-rt speedlites and the Canon controller...
im going to do some looking for the 9v Gossen meter. it sounds like it might be just the ticket...
thanks
Bassat
"I am still in my underwear."
Bassat's Avatar
Joined Oct 2015
Bourbon, Indiana - USA
Nov 04, 2017 00:24 |  #5
I had some Yashica cameras that used 1.35v Hg batteries. I remember some 'air' batteries that worked adequately as replacements. Giant PITA, though. The batteries had a 'tab' that covered the air holes until you were ready to use the battery. Every time you wanted to stop shooting for any period, you had to remove the battery and put the 'tab' back on. They'd discharge in a day or two if you didn't.
The correctly 'sized' (alkaline/NiCad/NiMH/w​hatever batteries never worked well. The meter was always way off with those.
Tom
2,279 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00087 for 4 database queries.
PAGE COMPLETED IN 0.01s
Latest registered member is FlemmingT
825 guests, 330 members online
