FORUMS Photography Talk by Genre Weddings & Other Family Events Talk
Thread started 22 Nov 2017 (Wednesday) 00:02
Prev/next
Widest Angle You Use ... Aperture ... The Reason ?
mdvaden
mdvaden's Avatar
Beaverton, Oregon
Post has been last edited 1 month ago by mdvaden. 2 edits done in total.
Nov 22, 2017 00:02 |  #1
1. What's the widest angle lens you incorporate for your wedding photography? (and aperture)
2. Why not any wider than that lens? (cost, weight, style, etc.)
3. What is the reason you chose that particular lens?
4. Is there another wide angle lens you would rather own?
5. Do you use it for most weddings, some weddings, or just a few?
6. All auto-focus? Or do you shoot manual focus wide angle?
Presently, the widest prime I own is 35mm 1.8 and the widest zoom 16-35mm f/4 ... haven't used the latter for weddings yet, but have used 24-70mm f/2.8 ...... considering 14mm to 24mm maybe.
vadenphotography.comexternal link . . . and . . . Coast Redwoods Main Pageexternal link
Wilt
Wilt's Avatar
Belmont, CA
Post has been last edited 1 month ago by Wilt. 3 edits done in total.
Nov 22, 2017 00:33 |  #2
I have found that when you use wider than an Angle of View of about 74 degrees (28mm lens on 135/FF), you can run too much risk of being too close to human subjects, which results in induced perspective distortion. 28mm is safe, but 24mm exposes you to the risk of induced perspective distortion. This remains true in 645 format cameras, with 45mm FL being safe enough, but 40mm FL is again at risk of induced perspective distortion with human subjects close to camera.
Here is a post showing induced perspective distortion...
http://photography-on-the.net ...showthread.php?p=18​491933
...The near hand is 'bigger' than the far hand, the near person is 'bigger' than the far person, so shooting a large group at an oblique angle is more 'dangerous' for induced perspective distortion with too WA than a longer FL, and why the back row of a group appears smaller than the front row.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
mdvaden
mdvaden's Avatar
Beaverton, Oregon
Post has been edited 1 month ago by mdvaden.
Nov 22, 2017 00:51 |  #3
Wilt wrote in post #18501588 (external link)
The example showed a couple of subjects.
How about a group of 8 to 20 or more people at some distance? Do you enjoy the safety of 24mm or 28mm for that size of group too?
I've shot about 40 people side-by-side (not a wedding) using the 24-70mm, but stood back about 50 feet away to add a little context.
Wilt
Wilt's Avatar
Belmont, CA
Nov 22, 2017 11:02 |  #4
mdvaden wrote in post #18501594 (external link)
The PRINCIPLES are identical whether you have 1 or 10 or 20 people...with the wider the angle FL:
  • The closer body part is emphasized with much greater size than the body part which is farther away
  • The person is emphasized with much greater size than the person who is farther away
...and the degree of size exaggeration is greater with the closer distance between lens and subject.
So, YES 24mm is indeed 'safe' ... when you are not a few feet away from the closest person, but standing back!
The effect is 'induced perspective distortion' caused by (too close) DISTANCE...the wider angle lens simply makes it far too easy to be standing much too close!
mdvaden
mdvaden's Avatar
Beaverton, Oregon
Nov 22, 2017 16:06 |  #5
Wilt wrote in post #18501861 (external link)
As a rule, that does not correlate at all with many photos I've taken with people. That's one reason I decided to post this thread and see what various people prefer. And for weddings, it can involve anywhere from one person to a large group of people.
I will use the image below to explain why what you suggested does not apply for many of the photos I've taken. The image below was taken at 26mm with a Canon 16-35mm f/4 ... there is near zero distortion to the woman in the image.
if 30 people were lined-up in the center third of this same scene, there would still be nearly no distortion to any of the subjects.
I have photographed several people at this same tree, or in similar settings, at 12mm, 14mm, 26mm and 45mm. The wider angle, the less distortion I get with the people. And curvature, etc., is mostly the perimeter of the scene.
This is different from many weddings, but it's a good example to cover why ultra wide angle can work without distortion to people. In my case, I shoot crop sensor M5, but also a Canon 5DS with images 5600 x 8600 pixels. I can use wide angle, and crop rather large images from images as one extra option.
The red dress is the other sister. Shot at 16mm, and she looks proportionally the same to when I've used 85mm from different angles and distances. I could place a couple or group in that scene too, with normal looking humans.
IMAGE: http://photos.imageevent.com/mdvaden/redwoods2/huge/GF_Ari_Cnvs_Sample.jpg
IMAGE: http://photos.imageevent.com/mdvaden/redwoods2/giant/LOST_Ver_3_1200.jpg
Wilt
Wilt's Avatar
Belmont, CA
Post has been last edited 1 month ago by Wilt. 2 edits done in total.
Nov 22, 2017 16:15 |  #6
mdvaden wrote in post #18502173 (external link)
The person in this photo is NOT TOO CLOSE...I estimate she is 1/6 of the frame height, and for her to be captured at that size puts her at 33' away (assuming she is 5'5" tall). I emphasize that it is PROXIMITY to the lens which induces perspective distortion.
Try this experiment:
  1. position your two hands 6" in front of another, with thumbs pointing up
  2. move your pair of hands at arm's length away and note the relative size of the two thumbs to each other
  3. now move your pair of hands so that the closest thumb is only inches away from your eye, and note the relative size of the two thumbs to each other
...and in situation 3 the closest thumb can appear to be twice as wide as the farther thumb! 'Perspective distortion' induced with NO FOCAL LENGTH involved!
Getting back to your picture, the woman at 33' looks totally normal, but if she is only 5' away she is twice as large as someone who is 10' away.
DaviSto
... sorry. I got carried away!
DaviSto's Avatar
Joined Nov 2016
Abuja Nigeria
Post has been edited 1 month ago by DaviSto.
Nov 22, 2017 16:20 |  #7
As we all seem to have to keep reminding one another, perspective (and therefore perspective induced distortion) are all about the distance between the camera and the subject and, assuming a moderately well-behaved lens, about nothing else apart from this.
Comment and (constructive) criticism always welcome.
mdvaden
mdvaden's Avatar
Beaverton, Oregon
Post has been last edited 1 month ago by mdvaden. 3 edits done in total.
Nov 22, 2017 20:12 |  #8
Wilt wrote in post #18502177 (external link)
Wouldn't need an experiment.
I used 11mm about 5 years ago with a model's bare toes in the foreground, and it made them look like fingers surgically attached. So well-aware of proximity.
What I'm looking for are photographer's answers to the 6 questions in the OP ... and experiment can't answer that, and I'm reading to see what people use or don't.
It's virtually the holiday now, but maybe a few more will chime-in in the days ahead.
memoriesoftomorrow
Joined Nov 2010
Nov 26, 2017 20:21 |  #9
12mm. Environmental portraits.
14mm. Astro wedding photography
16-35. Have two in the bag and use regularly at 16mm.
Peter
Wilt
Wilt's Avatar
Belmont, CA
Nov 27, 2017 09:44 |  #10
memoriesoftomorrow wrote in post #18504780 (external link)
It would be good to mention if this is on 4/3 format or on APS-C or on FF body
tim
Light Bringer
tim's Avatar
Wellington, New Zealand
Nov 27, 2017 12:12 |  #11
Nikon 16 - 35 F4 VR, shot at F4, on full frame. Good lens, lets me get the whole wedding party in small churches and get some fun creative shots, and I didn't need the much more expensive 12-24. I use it at all weddings. AF.
memoriesoftomorrow
Joined Nov 2010
Nov 28, 2017 01:35 |  #12
Wilt wrote in post #18505073 (external link)
Full frame
Peter
Tigerkn
CA
Post has been edited 1 month ago by Tigerkn.
Dec 01, 2017 16:51 as a reply to memoriesoftomorrow's post |  #13
Tokina 16-28 f/2.8
16mm is plenty wide :) - Price is great.
Neck to neck with L lens from many reviews and only 1/3 in price.
16-35mm f/2.8L III or Canon EF 11-24mm f/4L (only if this isn't $2,700)
Wedding only - The whole wedding Guests group (when the 24-70 can't cover at 24mm).
Mostly use on the dance floor toward the end of the night. See sample from link below (toward the end of the blog post)
http://www.photoquests​tudio.com ...-photographer-daniela-ben (external link)
Auto-focus
Website (external link) | Facebook (external link) | Instagram (external link) | Gears (external link)
mdvaden
mdvaden's Avatar
Beaverton, Oregon
Dec 10, 2017 10:19 |  #14
Tigerkn wrote in post #18508414 (external link)
Tokina 16-28 f/2.8
Auto-focus
Thanks for the reply ...
In the dance floor photos, is the effect with lights from the movement of lens, or people moving light sticks? It looks good as an effect.
Tigerkn
CA
Dec 10, 2017 14:09 as a reply to mdvaden's post |  #15
The effect with lights from the movement of lens. Thank you mdvaden!
3,172 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00122 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is hub21
910 guests, 450 members online
