Thread started 05 Dec 2017 (Tuesday) 15:10
Hair light... snoot or gridded softbox
Gallery: 20 photos
Joined Apr 2012
Dec 05, 2017 15:10 |  #1
picked up a low cost stand and boom...
want to try and incorporate hair lights into my shooting...
do you usually snoot your strobe or speedlite or shoot into a gridded softbox?
Left ­ Handed ­ Brisket
That's my line!
Joined Jun 2011
Post edited 3 months ago by Left Handed Brisket. (3 edits in all)
Dec 05, 2017 16:16 |  #2
speedlight/snoot is obviously hard light and makes a smallish highlight. With just one person it can be well controlled and not bleed into other parts where it would be unwanted, with more people this gets progressively harder.
I also keep in mind how much wrap i want around the head so a larger source would be better.
have to consider the background as well. so yeah, both, but probably more often with a small gridded softbox
PSA: The above post may contain sarcasm, reply at your own risk | Formerly he's gone before apostrophe-gate | Not in gear database: Canon 70-210 3.5-4.5, Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Joined Dec 2014
Dec 05, 2017 17:15 |  #3
Weight becomes a consideration too - assuming that there will be times when you require the maximum offset from the stand.
A Speedlite with a built-in Rx is handy. The lightest weight small softbox I've come across is Roundflash's 'Flash Dish'. It's easy to clip on 2 or more 2mm black Corex Barn doors with a small Bulldog clip each to the rim.
Just one option.
Gallery: 13 photos
Dec 05, 2017 17:21 |  #4
A flash head with standard reflector and grid is ideal. A soft box with grid spreads light much more and weighs more as well. (external link) (external link)
Dec 05, 2017 23:56 |  #5
I use a strip box, a softbox can also work. Gives you more room and also handles more than one subject. Gridded hot shoe flash weights less but how do you point at someone head? I rather use modeling lights of strobe in cases like these, makes it easier IMHO.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
Gallery: 70 photos
Joined Mar 2014
Post edited 3 months ago by ThreeHounds. (2 edits in all)
Dec 06, 2017 20:35 as a reply to  @ bobbyz's post |  #6
If I'm doing a true hairlight, just high lighting the hair only, I usually use my AD600 extension head with a standard 7 or 8" reflector with a grid on a boom arm.
If I'm doing a rim light, it's usually a 15x55 strip box with a grid on one of my monolights.
Edit: meant as post to thread, not reply to BobbyZ
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | 105 f/3.5 Zenzanon | Tamron SP90 f/2.8 Di Macro VC USM
looks like I picked a bad week to give up halucinagens
Gallery: 20 photos
Joined Dec 2015
Dec 10, 2017 13:11 |  #7
FYI... Buying a low cost stand and boom generally means you need to invest in a stronger, safer, heavier and more costly stand and boom...
You can find a better used one than a new cheap one.
Nikons, Rolleiflexes, Elinchroms, Billinghams
2,382 views & 1 like for this thread
version 2.0 /
Latest registered member is henryyow
879 guests, 364 members online
Simultaneous users record so far is 6430, that happened on Dec 03, 2017 Digital Photography Forums is the website for photographers and all who love great photos, camera and post processing techniques, gear talk, discussion and sharing. Professionals, hobbyists, newbies and those who don't even own a camera -- all are welcome regardless of skill, favourite brand, gear, gender or age. Registering and usage is free.
