FORUMS Photo Sharing & Visual Enjoyment Sports
Thread started 09 Dec 2017 (Saturday) 21:59
Basketball Green Screens
rjharris
Gallery: 68 photos
Dec 09, 2017 21:59 |  #1
Here's a couple pictures from Malakoff, boys and girls basketball team. 3 light setup on a green screen.
sfinkernagel
Dec 28, 2017 08:59 |  #2
Good work!
Care to share more of your lighting and process? You have done a nice job of eliminating spill, and I'm curious about your workflow for multiple teams- how do you process to separate the subject and add the backgrounds?
rjharris
Gallery: 68 photos
Dec 28, 2017 09:08 |  #3
Here's the BTS shot of my set up. I shoot at F8 or higher so the edges of the model is pretty sharp. Then I select the green with the quick selection tool, invert the selection and then contract it by 1 or 2 pixels before I make my mask. Then I go into refine edge (can't remember what they call it now) and use the refine edge tool, smooth 1 pixel contrast slider to 10 and shift edge to either -15 or 20 depending on the hair I have to mess with. Then after I get the mask pretty much how I want it I place my images on the background. If there's any contamination spill I select the image (not the mask) and then paint with a brush set to color blend mode at 30% opacity sampling as close to the original color as I need so I sample several times. That usually does the trick. If I have enough room I seldom need to do that except for blonde hair.
sfinkernagel
Dec 28, 2017 09:12 |  #4
Your models stand near that gizmo on the floor? It looks like that would put them just in front of the lights on each side, correct?
rjharris
Gallery: 68 photos
Dec 28, 2017 09:14 |  #5
Yes, that's my starting point for each model. It's just about at the front of the side soft boxes. If I can stand them there it gets me pretty close then if I need to I can fine tune it. That is actually just a reflector from one of my 360's.
sfinkernagel
Dec 28, 2017 09:16 |  #6
Makes sense. Thank you for sharing!
530 views & 3 likes for this thread
version 2.0 /
Latest registered member is Emme16
760 guests, 416 members online
