FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 10 Dec 2017 (Sunday) 23:47
Prev/next
6TB Seagate USB3
DagoImaging
DagoImaging's Avatar
Joined Nov 2012
Dec 10, 2017 23:47 |  #1
Costco has these for $120 if anyone needs additional storage or backup.
It's called a Backup Plus Hub.
I picked one up to backup my Drobo.
Sony a6300/ 16-70/4 / 70-200/4 G / Sony HVL-60M
silvrr
silvrr's Avatar
Chicago,IL
Dec 11, 2017 11:55 |  #2
FYI for non costco members, Amazon has the same price.
https://www.amazon.com ...8-4&keywords=6tb+externa​l (external link)
Canon 6D l 24-70 f/4L l 100L l 430EX l 430EX II l Kenko Extension Tubes l Sigma 50 Art
flickr (external link) FeedBack
Angmo
looks like I picked a bad week to give up halucinagens
Angmo's Avatar
Joined Dec 2015
AZ-USA
Dec 23, 2017 17:09 |  #3
DagoImaging wrote in post #18515151 (external link)
I’ve heard of reliability issues with these.
Wonder how Much Newegg.com sells them For
Nikons, Rolleiflexes, Elinchroms
silvrr
silvrr's Avatar
Chicago,IL
Dec 24, 2017 13:20 |  #4
Angmo wrote in post #18524939 (external link)
Problem is most people don't find out what drive is actually inside. These externals often have different drive models in them, hard to track a failure/issue if you can't target the specific drive. Also, the large drives have had issues when they are new, 6TB drives have been around for awhile now.
Looks like everyone has the same deal until Wednesday
https://www.newegg.com ...aspx?Item=N82E16822​179032 (external link)
Angmo
Angmo's Avatar
Joined Dec 2015
AZ-USA
Dec 24, 2017 13:45 |  #5
silvrr wrote in post #18525520 (external link)
Yep. I always look at the product codes and only buy server class drives. No desktop drives for me! It’s not that much more of a cost and well worth it.
Cham_001
Cham_001's Avatar
based between Ruse, Bulgaria & Recife-Brazil
Jan 05, 2018 03:39 as a reply to Angmo's post |  #6
6TB external hard-drive for $120.00 - WOW a real bargain! :eek:
(Based on the comments above the reliability is questionable). :rolleyes:
Can you recommend reliable 'server-quality' external hard-drives say around the 4TB mark? ?
"... with a clear perspective - the confusion is clearer ..."
Bodies: Canon 6D ii - (anxiously awaiting my New Year present! )
Lenses: 70-200mm f/2.8L IS II USM, 100mm L IS USM f/2.8 macro & 50mm f/1.8 ii
Flashes: 580ex II x 4, MT24 macro flash, 3 x ELC Pro HD 500
Accessories: Pkt Wiz TT5 x 4, MiniTT1, Sekonic L-758DR
Angmo
Angmo's Avatar
Joined Dec 2015
AZ-USA
Post has been edited 10 days ago by Angmo.
Jan 05, 2018 09:32 |  #7
Cham_001 wrote in post #18533839 (external link)
The Western Digital Gold line is quite nice. Capacities from like 1 TB to 12 TB. Search for “Server class hard drives” for real hard drives. Otherwise those “OK only” desktops show up. I’ve had WD drives for over 10 years. They work.
You can get em from the usual amazon and other suspects.
https://www.wdc.com ...ard-drive.html#WD6002FRYZ (external link)
I prefer reliability over desktop drives. And triple backups weekly/incremental and monthly. And recoverable from bare metal.
Cham_001
Cham_001's Avatar
Jan 06, 2018 18:56 |  #8
Angmo wrote in post #18533954 (external link)
Thanks AngMo, :-)
The 6GB / 128MB cache looks reasonably priced at circa. $250.00.
Just need an external case to house it in with a USB 3.0 / Firewire interface - will look around for one!
Archibald
You must be quackers!
Archibald's Avatar
Calgary
Jan 06, 2018 19:07 |  #9
I buy the cheapest brand-name drives I can find for backups. They log about 2 hours of use per month, pretty light duty. Never had one fail on me. And if one fails, no problem, older files are backed up in quadruplicate.
Pentax Spotmatic F with 28/3.5, 50/1.4, 50/1.8, 135/3.5; Canon digital gear
C&C always welcome.
Picture editing OK
Angmo
Angmo's Avatar
Joined Dec 2015
AZ-USA
Jan 06, 2018 19:57 |  #10
Archibald wrote in post #18535172 (external link)
Like google does/did. Huge arrays of cheap drives.
I just go with quality period. Both valid choices.
Tareq
"I am very lazy, a normal consumer"
Tareq's Avatar
Ajman - UAE
Jan 06, 2018 20:18 |  #11
I have Seagate 8TB Backup plus hub for Mac, the white one, and i keep it connected to my Mac computer only, but i use it for something else not photography, but it helped me a lot to free spaces on another hard drives such as 2-4GB ones so i can use them again for either photography or anything else, later i will buy one more but the black one and keep it for Windows, so this will make me to manage and archive my all files better, and maybe more drives to free so i can use it them again for anything else, i just got into Astrophotography and the files i get are really huge, so need HDD for that definitely more than photography which i have a long break from.
Galleries:
http://hamrani.deviant​art.com/gallery/external link
Facebookexternal link
eelnoraa
Jan 08, 2018 13:16 |  #12
For backup (cold storage for sequential access data), cache size makes zero difference.
As for WD Gold, it is actually called "enterprise" grade drive. The reason it is so expansive has a lot to do with the qualifying procedure to meeting Enterprise requirement. Sure it is higher quality, most importantly more consistent. But for an average backup usage, ie. power on once in a while for incremental change data. Number of "cycles" on this usage is most likely "1". The requirement for both power on time and cycles are extremely low. Even the lowest end drive will do just fine. In this case, the only advantage of enterprise grade drive is the consistency, in a sense that chance you are getting a lemon is much much lower with the Gold. Then again, for this particular usage, you should either notice the lemon on your first power on. And if it function OK for the first time, most likely it will last for the minimal stress this drive will encounter throughout the life.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
Angmo
Angmo's Avatar
Joined Dec 2015
AZ-USA
Jan 09, 2018 00:34 |  #13
eelnoraa wrote in post #18536404 (external link)
Ive also used GRCs utilities to do surface test and refresh. Trust but verify...
alex66
Joined Feb 2006
Jan 09, 2018 05:12 |  #14
I am a big fan of many multiple back ups, tend to replace main photo drive each year and then move drives down the back up chain and get a USB drive on alternate years. There are 4 copies of all photos in the home plus a copy on Amazons servers (free with Prime) plus spare copies at my dad's house and in the car. The last two tend to be done monthly one mid one start of month. I lost two disks a few years ago they had the same files on them, thankfully the third drive at fathers covered it so I became even more obsessive (OK far too) over backing up. I do but better quality drives and swap between makers as well.
Stuff
Feed Your Head
546 views & 4 likes for this thread
6TB Seagate USB3
made in Finland
by Pekka Saarinen
Spent 0.00165 for 4 database queries.
PAGE COMPLETED IN 0.05s
Latest registered member is marywilliams
815 guests, 323 members online
