FORUMS Photography Talk by Genre Weddings & Other Family Events Talk
Thread started 13 Dec 2017 (Wednesday) 13:24
Prev/next
Wedding Ring shots (Close up Filter?)
natewarden777
natewarden777's Avatar
Joined Feb 2014
Winston Salem, NC
Dec 13, 2017 13:24 |  #1
We just sold our Canon 85mm 1.8 (which we used with a Sony closeup filter to do Macro-like ring shots).
We're considering the following 2 options as it's replacement:
Sigma 85mm Art w/ Close up Filter (Vivitar x1-x4 set)
Tamron 70-200 VC w/ Close up filter (Canon version)
The Canon 550 filter fits the Tamron, but the 85mm is lighter and sharper.
Which would you guys choose? Would the zoom feature make much of a difference?
Thanks!
6D (x3) l 35A l 50L l 50 1.4 EX Sigma l 85A l 70-200VC l 580EX II (x2)
FEEDBACK
Wilt
Wilt's Avatar
Belmont, CA
Post has been edited 1 month ago by Wilt.
Dec 13, 2017 14:32 |  #2
natewarden777 wrote in post #18517067 (external link)
Thanks!
I would choose an extension tube! Closeup filters are made for lenses that cannot be detached from the body.
With a ring about 25mm in diameter (mean size, between a woman's ring and a man's ring) you can fit two rings onto your 36mm wide frame at 1/2 size on the sensor, if using a 31mm tube
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
Colin ­ Glover
Joined Aug 2012
Southport nr Liverpool United Kingdom
Dec 13, 2017 17:23 |  #3
Polaroid do a set of four 58mm filters that's rated 4* by Amateur Photographer magazine. I had a set and lost them (zip on my bag was left open). 2x, 4x and 6x are sharp, but the 10x was a tad (only just) soft. That was both AP and my conclusion. Cheap as chips, annd well worth the cash.
Canon EOS 70D, Canon EOS 600D, EF-S 18-55 ii, EF 55-200 USM ii, EF-S 75-300 iii, Tamron 28-80, Sigma 70-210. Pentax 50mm, Pentax 135mm, EF-S 55-250, Raynox Macro adapter, Neewer filters (CPL, UV, FLD & ND4), Fuji HS20 EXR (30X zoom ) & cable release, Yongnuo 560 iii & Luxon 9800A manual flashguns for the Fuji, Hama Star 63 tripod, Hongdek RC-6 remote control, Velbon DF 40 www.point-n-shoot.co.uk website.
Wilt
Wilt's Avatar
Belmont, CA
Post has been last edited 1 month ago by Wilt. 4 edits done in total.
Dec 13, 2017 18:54 |  #4
Colin Glover wrote in post #18517238 (external link)
The conventional wisdom is that if you have to use close-up filters, find yourself a close-up filter with TWO-ELEMENT optics, not the simply one-lens optics found in almost all commercially available filters. Both Canon and Nikon have offered a two-element close-up filter. The Canon ones come in 52mm, 58mm, and 77mm filter sizes.
From http://www.peachpit.co​m ...es/article.aspx?p=1​804858 (external link):
"Double-element close-up lenses. Sometimes called dual-element or achromatic close-up lenses, these lenses have two elements; the second corrects the aberrations of the first. They're more expensive than the single-element version, and not as readily available, but their image quality is excellent. I use a Canon 500D double-element close-up lens with my 85 mm lens, and I can't see a difference in image quality between a photo taken with that combination and one taken with a true macro lens.
Canon makes two double-element close-up lenses—the 250D (+4 diopter) and the 500D (+2 diopter). Nikon made the 3T, 4T, 5T, and 6T double-element lenses, but they've been discontinued (sometimes you can find them on eBay). Schneider also makes double-element close-up lenses, but at a price. Olympus makes the MCON 35, which appears to be discontinued but is still available on eBay."
...and as used products from retailers such as Adorama
https://www.adorama.co​m ...c0yWicv48GBBoCc-8QAvD_BwE (external link)
Double-element accessory attaches to front of lens, and the Canon 500D changes closest focusing distance from infinity to 500mm (approx. 19.7") from front of lens.
tim
Light Bringer
tim's Avatar
Wellington, New Zealand
Dec 14, 2017 12:28 |  #5
Macro lenses are awesome for this, and some portraits, but expensive. Otherwise I use extension tubes.
natewarden777
Joined Feb 2014
Winston Salem, NC
Dec 14, 2017 13:16 as a reply to tim's post |  #6
Which extension tube set are you all using?
Do extension tubes degrade image quality less than close up filters?
FEEDBACK
Colin ­ Glover
Joined Aug 2012
Dec 14, 2017 17:13 |  #7
AFAIK, tubes don't have glass in them to degrade image quality, but as you are in effect varying the length between the rear element and the sensor, I can't say 100% that quality wont suffer. Maybe someone who knows a bit more can clarify or dimiss what I'm saying.
umphotography
grabbing their Johnson
umphotography's Avatar
Gig Harbor, Washington
Dec 20, 2017 09:28 |  #8
Just save yourself a lot of aggrivation and go buy a Macro and work it into your routine
This is straight off the camera with a 100L
Macros are a no brainer for wedding photogs
Canon has the 100Ls on sale right now. My 8 yrs old sigma broke and fell apart so I went out Friday and got a new one. Ring shots are a snap with macros. The beauty of the canon L is you can leave it in the Full position at the switches and it doubles as a 100MM F/2.8 prime. It works very well.
Mike
www.umphotography.comexternal link
Facebookexternal link
1,140 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00088 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is hub21
902 guests, 444 members online
