Thread started 21 Dec 2017 (Thursday) 17:31
AD200 new firmware update
Lotto
Dec 21, 2017 17:31 |  #1
With wireless ID..
http://www.godox.com/E​N/Download.html (external link)
5D, 24-105L, 70-200L IS, 85mm Art, Godox
LGabrielPhoto
Joined Oct 2017
Dec 21, 2017 20:57 |  #2
OK I searching but cant find out what is wireless ID for a flash?
Nogo
I could have been worse....
Gallery: 15 photos
Joined Dec 2013
Post edited 4 months ago by Nogo. (3 edits in all)
Dec 21, 2017 21:07 |  #3
LGabrielPhoto wrote in post #18523739 (external link)
It is just a code that identifies the transmitter to the flash that is sent whenever the transmitter sends a signal to the flash. It enables two or more flashes from different users to use the same channel where the proper transmitters only trigger the proper receivers. It does not eliminate interference totally but it will eliminate almost 100% of flashes caused by interference from other units on the same channel.
The units can still interfere with each other if the signals are sent simultaneous. Two mixed signals may cause the flashes not to fire at all. The code is mainly there to stop someone else's transmitter from operating your flash, either changing the settings or firing the flash. In most cases just changing the channel number will be enough. The addition of codes is mainly for an event where many photographers may be present and the photographer wants more protection from false flashes than just using different channels will provide.
Philip
Does the TF actually know about the soda cans and PVC pipe from 30 years ago?
Lotto
Dec 21, 2017 22:41 |  #4
Right. In simple terms--with the Tx and Rx on the same channel, now we can set addition ID, like Tx with ID "05", all Rxs also need to set to 05 to communicate.
jay125
Nothing about me is regular.
Gallery: 97 photos
Post edited 4 months ago by jay125.
Dec 21, 2017 22:52 |  #5
From what I am finding out, you will need the xPro to utilize the ID, since the X1-T doesn't (yet?) have that available.
It's pretty easy to set up with my xPro. I used the ID's previously on my Phottix system. An added layer of protection from someone triggering your flash. I'm glad it made it to the AD200's.
feedback
inkista
Dec 22, 2017 01:09 |  #6
It's basically so that you don't have to pay for PocketWizard custom IDs (external link) any more, if you're going to shoot at the Olympics. :)
As everyone else has explained, it's a way of turning 32 radio channels into 3168 "virtual" channels (code 00= ID codes off, so it's 32 RF channels x 99 ID codes), so if someone else nearby is using the same Godox triggers on the same channel, the chances of them popping your lights goes way down. :)
But, as has also been noted, you have to have (at this time) an XPro transmitter, and firmware-upgradeable Godox X strobes to use the feature. I can use ID codes with my XPro-C and my TT685C, but not my TT600 speedlights (the same would hold for V850II speedlights), since they don't have any firmware upgrade capability. To work, the ID code capability has to be on both sides of the RF signal: both the transmitter and the receivers.
The TT685, V860II, AD360II, AD600/AD600M firmware updates went out on the 1st of December.
No idea if the TT350 mini-flashes are going to get an update for this, too. They haven't received updates for any of the fixes that have gone out on the X1T units.
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
mmmfotografie
hanging up-side-down in a cave
Joined Jul 2013
Dec 22, 2017 04:40 |  #7
With PocketWizard you get a personal id for PW equipment. On the Olympics you are the only one with that personal id.
This is not the the case with the id that Godox uses. it is free but you ate not the only one to be able to use that id.
steve67
Joined Dec 2012
Jan 01, 2018 15:06 |  #8
So what type of cable goes from the computer(USB) to the AD200?
Thank you
5DMark4/ 24-105 F4/16-35mm F4 50mm f1.8 II/ 70-200mm f2.8L IS II USM
dmward
Gallery: 28 photos
Jan 01, 2018 15:14 |  #9
steve67 wrote in post #18531077 (external link)
Thank you
USB with micro B end for light.
Make sure its a cable intended for data transfer.
steve67
Joined Dec 2012
Jan 01, 2018 15:26 as a reply to  @ dmward's post |  #10
Thank you
inkista
Jan 01, 2018 16:33 |  #11
dmward wrote in post #18531085 (external link)
To elaborate a little farther, use the micro USB port near the power switch on the AD200; not the USB A port under the rubber cover; that's for plugging in an FTR16 receiver if you want to use the older 433 MHz triggering system.
steve67
Joined Dec 2012
Jan 01, 2018 17:51 as a reply to  @ inkista's post |  #12
Thanks for the heads up, completely missed that port.
2,032 views & 2 likes for this thread
version 2.0 /
Latest registered member is woleary
689 guests, 415 members online
