FORUMS General Gear Talk Camera Vs. Camera
Thread started 23 Dec 2017 (Saturday) 08:59
Prev/next
7D vs 70D
chiefdeck
Joined Jan 2017
Dec 23, 2017 08:59 |  #1
Which would be a better camera the 7d or 70d for shooting birds and is my Tamron SP 150-600mm F/5-6. compatible with both
MalVeauX
"Looks rough and well used"
MalVeauX's Avatar
Joined Feb 2013
Florida
Dec 23, 2017 09:46 |  #2
I'd do 7D, for the buffer and speed, for pure birds in flight.
If you're just doing big slow birds and birds that are perched, then the 70D would be totally fine.
The Tamron lens is fine with both. Both have MFA. The 70D has more modern MFA (both min & max side).
Very best,
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Dec 23, 2017 12:37 |  #3
70D is perfectly capable for BIF...even if they're not just big slow birds...it's only 1 extra fps as far as burst
it's got slightly higher/better ISO, and more mp in case you need to crop a bit more...
i'd go 70D, but i don't think you can go wrong with either choice, they're both more than capable
Andre or Dre
gear list
Instagram (external link)
my 366 for 2016 (external link)
RPCrowe
RPCrowe's Avatar
Joined Nov 2005
San Diego County, California, USA
Dec 23, 2017 13:29 |  #4
If you can swing the extra cash... The 7D2 is a top-notch action (of all types) camera... It's quite a bit better than the 7D or 70D. The 80D is pretty decent also...
chiefdeck
Joined Jan 2017
Dec 23, 2017 16:43 as a reply to RPCrowe's post |  #5
Really looking at the 80D, just to make sure my Tamron is compatible?
MalVeauX
MalVeauX's Avatar
Joined Feb 2013
Florida
Dec 23, 2017 16:44 |  #6
chiefdeck wrote in post #18524919 (external link)
It is. Every Canon from the 1D mark II and later era will work with it.
Very best,
pbm77
pbm77's Avatar
Dec 23, 2017 17:25 |  #7
I use the 7D/tamron 150-600 for most of my bird photos. And while it works ok, it's also often frustrating because of various focus problems.
Here are some of my pictures including BIF with the combo https://500px.com/pete​rbruusmadsen (external link)
Peter
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Dec 23, 2017 19:30 |  #8
have you checked out canon's refurbished sale going on now...there are some deals on the 80D and 7DII:
https://shop.usa.canon​.com ...&pageView:grid&page​Size:& (external link)
Andre or Dre
gear list
Bassat
"I am still in my underwear."
Bassat's Avatar
Joined Oct 2015
Bourbon, Indiana - USA
Dec 23, 2017 21:06 |  #9
I had both bodies. Of these two, I'd take the original 7D every time. Eight FPS for the 7D. IIRC, the 70D was a bit under 7 FPS. AF is a draw, maybe a slight edge to the 70D. Unless you're shooting birds at f/1.2, the AF differences won't matter. F/4 to f/5.6 covers a lot of AF sloppiness. The advantage of the 7D is processing speed and buffer depth. That said, the 70D will perform beyond it specs with faster SD cards (150 mb/s). Most Canon cameras outperform their specs.
Tom
ksbal
ksbal's Avatar
N.E. Kansas
Dec 28, 2017 12:28 |  #10
Buffer is the question and the answer. All mentioned can do it, 80D is really nice, 7D2 will have a much better buffer, for burst shooting. Depends on what you are going for.
YN622 English User Guide/Manual by Clive
https://drive.google.c​om ...Ig0gMMzZFaDVlZ1VNTE​0/view (external link)
Snydremark
Myth-informed
Gallery: 40 photos
Issaquah, WA USA
Dec 28, 2017 21:49 |  #11
My top rec's would be: 7DII > 80D > 70D > 7D if you're just getting into it:
https://www.dpreview.c​om ...70d&products=canon_​eos80d (external link)
  • 7DII gives you the highest ISO performance, best AF system, highest FPS (10, but configurable between High, Normal and Silent shooting), newest image processor (x2), larger buffer and most available AF points (65)
  • 80D gives you a tie for second highest ISO performance and reports to handle higher ISOs slightly better than the 7DII, tie for lowest FPS (7), newest image processor, DPAF if you use Live View for focusing, decent AF system and second most AF points (45)
  • 70D is the other tie for second highest ISO, ties for lowest FPS (7), second oldest image processor, similar AF module to the 7D, DPAF if using Live View
  • 7D gives you the second fastest FPS (8), lowest ISO, oldest image processor, lowest resolution
Depending on your lens lineup, budget, etc, you might also choose to throw a used 1D IV into the list of considerations. After shooting the 7D/7DII birding for the better part of the last decade, that is still one I would consider strongly if I didn't have the 7DII dialed in already. Beefier build, stupid fast AF, slightly lower crop factor and customizable as all hell.
- Eric S.: My Birds/Wildlife (external link) (7D MkII, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS)
Bassat
Bassat's Avatar
Joined Oct 2015
Post has been edited 25 days ago by Bassat.
Dec 29, 2017 12:47 |  #12
Snydremark wrote in post #18528392 (external link)
I had the 70D, and still have the 80D. No way you can call their respective high-ISO performance the same. The 70D is clean enough (my standards) to shoot JPG at 3200, and 6400 needs to be shot raw and PP'd, 12800 is barely usable. The 80D is quite usable at ISO 16000, and in decent light, I'll use 12800 while shooting JPG. The 70D doesn't even come close to that.
EDIT:
I checked out the link, and I believe I found the source of my disagreement with your claim. Both the 70D and 80D are capable of ISO 25,600; the setting is available on the dial. I find that meaningless. Canon could put ISO 7 billion on its P&S, that doesn't mean it is useful. The 70D is barely usable (even by my standards) at ISO 12,800. The 80D is quite usable at ISO 16000. I don't have direct comparison photos, but I'd call the 80D at 16000 just a tad worse than the 70D at 6400. I'm happy calling that 1.5 stops. The cameras may have the same settings on the dial; they do not turn in the same performance.
Tom
ebiggs
ebiggs's Avatar
Joined Oct 2012
Spring Hill, KS
Post has been edited 24 days ago by ebiggs.
Dec 30, 2017 10:42 |  #13
chiefdeck wrote in post #18524572 (external link)
If you are taking the camera out in the boonies, the 7D all the way. It is way better built. It works well with the big Tammy.
G1x, EOS 1Dx, EOS 1D Mk IV, ef 8-15mm f4L,
ef 16-35mm f2.8L II, ef 24-70mm f2.8L II, ef 70-200mm f/2.8L IS II,
Sigma 150-600mm f5-6.3 DG OS HSM Sport
*** PS 6, ACR 9.3, Lightroom 6.5 ***
435 views & 0 likes for this thread
7D vs 70D
made in Finland
by Pekka Saarinen
Spent 0.00099 for 4 database queries.
PAGE COMPLETED IN 0.04s
Latest registered member is wshooter
445 guests, 303 members online
