Thread started 23 Dec 2017 (Saturday) 09:51
looking for a good tutorial to how denoise images without destroing texture
mantra
Post edited 4 months ago by mantra. (2 edits in all)
Dec 23, 2017 09:51 |  #1
Hi
i shoot always raw with my canon 5d mk3
well i'm looking for a good tutorial to denoise my noisy images without destroing the texture
i used lightroom classic cc, and photoshop cc ,i have these denoiser nik (included define pro ) and noiseware
i was watching a video http://www.lensworkonl​ine.com …%20ISO,%20Low%2​0Noise.mp4 (external link) and i read a tutorial about take several shots to get the best results
well , i don't take several photos outside i thinking about process them for hdr
may i ask you which skill/technique do you use to denoise your image without loosing texture?
thanks
happy holidays
canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
3 analogic Hasselblad and 2 anologic Mamiya
kirkt
Post edited 4 months ago by kirkt.
Dec 23, 2017 10:58 |  #2
The video to which you linked describes increasing signal-to-noise ratio (SNR) by pixel averaging. Astrophotographers routinely use this technique, and other techniques like bias and dark frame subtraction, to boost SNR.
For image averaging, the percent reduction in the original random noise goes as:
1/SQRT(n)
where "n" is the number of images used in the averaging operation. So, for example, if you use 4 images, it will reduce the original random noise to 50% of the original.
Using this technique requires that the noise is random, and does not have a pattern. There are obvious limitations to this technique, the same as most computational techniques - camera shake, object motion, ghosting, alignment, etc. all will cause this technique to fail.
FWIW, the DxO ONE camera shoots a raw format the call "SuperRAW" where the camera takes four exposures in rapid succession and creates a single raw file out of the result. This format can be read by DxO software and provides an additional level of noise reduction.
The most useful noise reduction technique depends upon the shooting situation and the exposure parameters that you need to keep fixed to achieve your exposure. As long as your noise is random, there are several solutions out there, each with their strengths and limitations - most of them have trials that you can use to see the results and figure out if the specific tool fits into your workflow.
Ironically, once fairly strong noise reduction is applied you might find that you get a more pleasing image by adding some "grain" back into the image. Adding grain, or noise, sometimes improves the appearance of the image by effectively increasing the image's accutance.
I use Neat Image, when necessary, on RGB images. On raw files, DxO's PRIME noise reduction seems to preserve the most detail in a raw file, but YMMV.
If you want to experiment with image averaging for noise reduction, try some astrophotography software - Franzen Denoise permits the user to also feed it a set of images to average as well as a dark and a bias frame.
In the end, decreasing noise is best accomplished by achieving the best possible exposure. You can also experiment with the in-camera noise reduction function 9should your camera have one) and see if you get better results from the camera's NR than post-processing software.
kirk
Kirk
mantra
Dec 23, 2017 11:25 |  #3
kirkt wrote in post #18524662 (external link)
kirk
Hi Kirk
i have taken several photos about wooden statues made by a famous craftsman
sadly i had not my gear and i had to use not my camera and my lenses
i tried to use find edges (to create a mask to avoid noise on the texture i use it often to sharp an image )& noiseware but with ugly results
thanks
digital ­ paradise
Gallery: 10 photos
Dec 23, 2017 14:39 |  #4
Can you show a couple of samples. I just use LR but I'm careful with the Detail sliders and I use the masking slider quite a bit to prevent sharpening of visible noise. Is it both colour and luminance?
Image Editing OK
agedbriar
Post edited 4 months ago by agedbriar.
Dec 23, 2017 17:01 |  #5
I can't help you obtain a better noise reduction, but I suggest that if you use your own copy of Noiseware for images taken with a borrowed camera, you check the "Turn off self-learning for this image" option.
MCAsan
Joined Jun 2010
Dec 23, 2017 17:05 |  #6
Don't use noise reduction globally. Use it as local adjustment applied via brush, radial filter, graduated mask, luminosity range mask or color range mask.
digital ­ paradise
Gallery: 10 photos
Dec 23, 2017 17:59 |  #7
https://www.youtube.co​m/watch?v=KkrYXOszvfI (external link)
Image Editing OK
digital ­ paradise
Gallery: 10 photos
Dec 23, 2017 18:21 |  #8
This one gets to what you need quicker.
https://www.youtube.co​m/watch?v=ZPX82LMJMiI (external link)
Image Editing OK
Bassat
"I am still in my underwear."
Joined Oct 2015
Post edited 4 months ago by Bassat.
Dec 23, 2017 18:54 |  #9
Read POTN member TeamSpeed's primers on 'getting the most' from 7D and other cameras. Just reading his stuff took me from being happy with my 60D at 1600, to ecstatic with it at 6400. I've moved on from the 60D, but his techniques are still valid on 6D and 80D. I'll see if I can find some links.
Here is one: http://photography-on-the.net …read.php?t=1079​217&page=1
The techniques in this thread really got me going on shooting raw and processing my photos. I work mostly in LR6, but use NoiseWare every once in a while. If you spend some time developing a 'feel' for getting the most out each photo, you'll spend little time doing this, and it opens up the entire ISO range your camera is capable of. I have no fear of using my 80D at ISO 16000, or my 6D at ISO 25600. Some of that is certainly my tolerance level.
Tom,
Film gear: Elan 7NE / Elan 7 / EOS T2
Yashica FX-D (x2) & FX-3 Super 2000 / DSB 28mm f/2.8 / 50mm ML f/2 / 135mm ML f/2.8 / Sigma Zoom-gamma II 21-35mm f/3.4.2 / Yashica ML 28-85mm f/3.5-4.5 / Tokina 70-210mm ML f/4.
mantra
Dec 24, 2017 00:59 |  #10
agedbriar wrote in post #18524932 (external link)
hi
there is no such option in noiseware 5 ,i haven't it
thanks
hi
thanks for the links ,is acr/lightroom denoiser so good
i see you suggest to use it , i think to edit in photoshop
thanks
MCAsan wrote in post #18524935 (external link)
hi
yes ,it what i want to do
Bassat wrote in post #18525008 (external link)
hi
i will try to search other tutotorials
digital paradise wrote in post #18524932 (external link)
II'm careful with the Detail sliders and I use the masking slider quite a bit to prevent sharpening of visible noise. Is it both colour and luminance?
hi
the noise is mosly in the lumincance
instead i thinking to use some techniques like slip frequency ,or luminocity mask or other
i will try to upload some photos
thanks
MCAsan
Joined Jun 2010
Dec 24, 2017 08:50 |  #11
Blake does a good job of showing luminosity and color range masking that are now in Lr and ACR. You can use them to select a specific luminosity range or color range (such as a dark blue night sky) to which you can apply noise reduction.
https://www.youtube.co​m/watch?v=jy6fGUCSQtc (external link)
agedbriar
Dec 25, 2017 06:49 |  #12
mantra wrote in post #18525184 (external link)
hi
thanks
Not the same as in my older version, but I'd bet there is something equivalent in that drop-box down there:
mantra
Dec 28, 2017 01:43 as a reply to  @ agedbriar's post |  #13
hi
but the plugin is 32bit only
i have the new one v5 , there is no such option
thanks
2,738 views & 7 likes for this thread
version 2.0 /
Latest registered member is Jeepmbr
764 guests, 446 members online
