Thread started 28 Dec 2017 (Thursday) 01:49
Prev/next
thanks for fix for wobbly stud - light problems
owenegan
Joined Dec 2015
Dec 28, 2017 01:49 |  #1
So, my Godox AD600 and all my Bowens S-mount adapters technically fit on my Matthews C-stand's stud, but it was a wobbly fit. Thanks to someone here, I learned that what I needed was (rather un-intuitively) a "Kupo Baby 5/8" Receiver to Stud Adapter for Elinchrom Heads" to make the connection a solid one.
So I got one and it worked perfectly and now I'm happy, and I wanted to say thanks to whoever it was that posted the info - I don't know who it was, as my attempt to locate the original post failed. Never in a million years would I have figured out that was the name of the thingy I needed.
Also, in general, I really appreciate all the graciously-offered expertise and advice you folks provide on this forum. I now return to my default lurk-and-learn mode.
Owen.
silvermesa1
Joined Aug 2013
Columbia, Mo. USA
Dec 28, 2017 05:14 |  #2
I think this is what you are referring to? Thank you for the tip!
https://www.bhphotovid​eo.com ...chrom.html#customer​Review (external link)
OceanRipple*
Joined Dec 2014
Post has been edited 19 days ago by OceanRipple*.
Dec 28, 2017 07:22 |  #3
Kupo's drawing:
It's good, in allowing for the non-standard Eli, Godox & Jinbei (etc) receivers, but IMO it's not perfect in suspension - say under a Drop Down Pin. As usual, it depends on the exact dimensions of the attached receiver.
RicoTudor
RicoTudor's Avatar
Joined Jul 2014
Chicago, IL
Dec 28, 2017 15:20 |  #4
I wish MSE would provide such engineering specs. The problem area solved by Kupo is measured at 3mm which is some abortion of a standard pushed by Manfrotto. The Hollywood baby pin is much taller, and is supported by the lighting majors including Profoto.
Canon, Nikon, Contax, Leica, Sony, Profoto.
Lotto
Lotto's Avatar
Southern California
Dec 29, 2017 04:03 |  #5
I think I first saw that Kupo adapter on Scott/Shom Photography's video link.
I don't have problem with long handle Godox receivers, like the ones on AD600 or the extension head, but shorter ones on the S Bracket and AD-B2 have issues mounting on the baby pin. Instead of buying few of the Kupo adapters, I want to find DIY solutions on the pins.
For straight standing C stands, I found that a small piece of automotive vacuum hose sandwiched between the baby pin and receivers is sufficient enough (BTW, I learned that from someone else). But the rubber hose does not stay on the pin well once the light is removed. The more secure mod is to wrap a piece of steel tubing around the neck area of the baby pin. There were more effort on cutting and grinding, but it was a fun project.
IMAGE: https://farm5.staticflickr.com/4647/38658360524_dc0d341ce8_o.jpg
IMAGE: https://farm5.staticflickr.com/4682/38658360064_8646c146ab_o.jpg
5D, 24-105L, 70-200L IS, 85mm Art, Godox
OceanRipple*
Joined Dec 2014
Dec 29, 2017 05:07 |  #6
Lotto wrote in post #18528514 (external link)
I like those! And the set screw goes in the slot/missing section.
Do you have any tips for forming your collars back to fitting tightly?
My two options shown here, have worked quite well (lower left, white and one from upper right, black):
Left ­ Handed ­ Brisket
That's my line!
Left Handed Brisket's Avatar
Joined Jun 2011
The Uwharrie Mts, NC
Dec 29, 2017 08:18 |  #7
http://photography-on-the.net .../showthread.php?t=1​489790
Original thread, I think.
Go to your user control panel and you will see all your threads and posts listed.
PSA: The above post may contain sarcasm, reply at your own risk | Formerly he's gone before apostrophe-gate | Not in gear database: Canon 70-210 3.5-4.5, Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Lotto
Lotto's Avatar
Southern California
Dec 30, 2017 02:18 |  #8
OceanRipple* wrote in post #18528527 (external link)
thumbnailHosted photo: posted by OceanRipple* in
./showthread.php?p=185​28527&i=i133243437
forum: Flash and Studio Lighting
Nice mods!
For bending the collar, I wrap it with few layers of towel/cloth to reduce the markings, use a Channellock to crimp down one side at a time, and small section at a time.
OceanRipple*
Joined Dec 2014
Dec 30, 2017 05:32 as a reply to Lotto's post |  #9
Tx for that detail.
987 views & 2 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00086 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is jqualmann
992 guests, 536 members online
