Thread started 30 Dec 2017 (Saturday) 11:35
Prev/next
Lightroom + PS Workflow Help
maranelloboy05
maranelloboy05's Avatar
Arlington, VA
Dec 30, 2017 11:35 |  #1
Hi all, wondering if someone can help me with some workflow issues I'm running into between LR and PS. I used to shoot mainly automotive where I basically exclusively used LR and I'm now shooting a lot more fashion/beauty photography. This switch has caused me to rely more heavily on PS and I'm running into some issues. At present my workflow is below:
1. Edit RAW in LR
2. Edit In PS - Spot Healing, Background Tweak, Liquify Tweaks
3. Save to LR
The issue I'm running into is that I can no longer make any adjustments once I'm back in LR without losing all of my Photoshop tweaks. I believe this is how these features are supposed to work, but not sure if there's a better way to do things. Should I do my PS work first and then do RAW edits to the TIFF that comes back into LR? How much of that RAW editing is preserved in that TIFF. Anyone have a better way to do things?
I have a hard time imagining it'd be that hard for Adobe to be able to preserve the adjustments in LR and PS through the process, but there's got to be a way they did it this way.
Thanks!
Chris Schlumpf Photography (external link)
Instagram (external link)
5D Classic - 24-85mm - 50mm - 100mm
Alveric
Alveric's Avatar
Canada
Post has been edited 22 days ago by Alveric.
Dec 30, 2017 12:31 |  #2
You need to work on the TIFF that comes back from PS.
When I used to use LR, I did notice that some LR adjustments, like lens profile corrections, sometimes did not carry over to PS, and I had to apply them again to the returning TIFF. You might want to check if this is still an issue.
FWIW, I'd do as much as I can in LR before sending the file over to PS, so that what you do in PS are final adjustments, and the TIFF that is sent back is only accessed by LR for the purposes of indexing, keywording, and JPEG output, not further edits.
BigAl007
Repps cum Bastwick, Gt Yarmouth, Norfolk, UK.
Dec 30, 2017 12:36 |  #3
When you open the image into Ps the image is changed from linear RAW sensel values, to RGB pixels values, with things like the white balance and curves baked in. So you should always do all of the exposure and colour corrections, as well as any other adjustments you need from the RAW data before you send the image for editing in any other program, or even Lr plug ins like the Nik collection. In all of these situations you stop working with RAW data.
Once you have converted to RGB there is no way that you can go back to the RAW data in Lr and make changes that will affect the RGB version. The only option you have if you really need to make a change to the RAW in Lr is to start over with a new RGB conversion.
If you do find that you need to make changes at the RAW level in your images you do have the option of opening it in Ps as a Smart Object. If you edit as a SO it embeds a full copy of the RAW in the resulting file, allowing you to open the RAW data in ACR to make your adjustments there. This tends to have a significant effect on the file size for your resultant TIFF/PSD. You will also need to maintain all of your layers too. It is possible I suppose to reduce the image to merge all of the additional layers, just leaving that layer, and the original SO layer at the bottom. Doing this though I would expect would make saving the SO pointless, as changing the SO layer will normally need additional changes in other specific layers.
If you are not too worried about storage space then working in 16 bit, and using ProPhotoRGB, is going to allow you to use the editing tools that are available for working with RGB images in Lr to work at their optimum. Lr will convert the image to 16 bit ProPhotoRGB internally during editing anyway, so this minimises any potential conversion errors. This is what I do, but I'm not doing that much in Ps, probably only 3% of my images end up in Ps.
One thing that I do often do to images that I have round tripped to Ps is my monochrome conversion. I do it this way for two reasons, using a VC is a simple way to have both versions. The other is that the Lr/ACR channel mixing offers the most channels, and I just like the way it looks better afterwards. I actually even prefer it over Silver efex.
Alan
My Flickr (external link)
digital ­ paradise
digital paradise's Avatar
Dec 30, 2017 13:06 |  #4
I export into PS using ProPhoto RGB. When done I press save. I immediately flag the original CS2 and hide it under the new TIFF. Now the CR2 is out of my way.
When done all my editing I choose Edit - Select Flagged Photos. Then Edit - Invert Selection. Now the flagged CR2 files are not selected and won't export.
There was another thread on the TIFF files are pretty big. I only do this about 10% of the time so I don't mind a few bigger flies. After export you can always delete the TIFFS and archive the Jpegs as Team Speed I believe suggested on that thread.
Image Editing OK
maranelloboy05
Arlington, VA
Dec 30, 2017 13:15 |  #5
Thanks guys, basically confirms what I'm doing is the best way. I just tend to "finish" an image and then want to go back and continue tweaking, sounds like there's just no way to do that, which is fine.
digital ­ paradise
Post has been edited 21 days ago by digital paradise.
Dec 30, 2017 13:29 |  #6
Another thing you can do is use PS only. Open the RAW file as a smart object and you can go back and tweak in ACR anytime you want to. The only issue is your edits aren't catalogued like they are in LR. I also think outside using a 3rd party sharpener for output sharpening LR does a better job than PS.
Image Editing OK
Damo77
Damo77's Avatar
Brisbane, Australia
Dec 30, 2017 14:31 |  #7
Examining the complexities of an ACR workflow (external link)
The Bridge challenge (external link)
Damien
Website (external link) | Facebook (external link)
BigAl007
Post has been edited 20 days ago by BigAl007.
Dec 30, 2017 20:39 |  #8
Damo I was using Bridge for two or three years before I made the move to Lr, and even though I pretty much use Lr for all of my image viewing needs, I still use Bridge quite a bit, especially when working with Adobe products other than Lr/Ps. Now that I have a system that can keep up with it I even auto write to xmp from Lr, so that I have my Lr edits always visible in Bridge.
One of the main reasons that I moved to Lr was for the advanced DAM tools. With now over 55000 images in my library I had got to the point where I could no longer easily find many of my images. My main photographic interest is aviation, and I will shoot multiple airshows at the same location. OK so I could save the images in a folder structure by location and date. But I also want to have all of my images saved by manufacturer and type. Or do I want to save them in a structure by operator? The simple answer when using Lr is to save the files in a simple dated folder structure, and do all of the other sorting in the DAM application.
I comprehensively keyword all of the images, which admittedly can take a while, but most good DAM programs have methods to help make it easier. Then in Lr I use the Smart Collection features to create a pseudo file system that allows me to group a single physical copy of an image into multiple locations, based on a multitude of information about the image, pulled from the EXIF and other metadata. The fact that the program is using a database to hold this information makes it just as quick to navigate this filesystem like hierarchy as a user as it does to navigate folders in Bridge. Of course I can also do the same directly in the folder structure too should I chose to. Lr has normal collections too, to which you manually add images, Until I moved to using Lr CC, with it's integration with Lr mobile, which allows me to easily share Lr smart previews with my mobile devices, and even the web page app, I didn't really make any use of normal collections.
I know Bridge has collections too, but it was I think only recently that it introduced Smart Collections. SC's in Bridge might be useful when dealing with a few hundred images in a couple of different folders, but it seems to fall down when you want to apply it across your entire image collection. I tried running an SC to look for one manufacturers name across my then 50K library. I know that if I had several SC's that the time it takes to collate the metadata would be the same as for just the one, but when it takes the system over 24 hours to parse all of the images in my photo library, it's scalability is still not that useful. The problem with the Bridge approach is that it literally has to traverse the file system and open either the image file itself, or the associated xmp file, depending on the file type, and then find a read the relevant data from the file. After that it has to close the file and move to the next one and repeat. It has to do this for every file, every time it needs to update. I can't perceive the length of time the DB search takes each time I click into a new SC in Lr, I certainly do notice it trawling the file system for over 24 hrs.
The other thing that was starting to become an issue for me with my Bridge only approach was managing the numbers of different versions of the same image, when saved as multiple files. I would have a CRW at the time I changed, and now CR2's too, a master PSD usually, and then maybe a couple of JPEG files, depending on what needs I had for output, web sized files, as well as files prepared for printing. Printing at home is very cost inefficient here in the UK, and I use a very good lab now that can provide me with an A3 print for about half the cost that I can print an A4 for at home. Thats based just on the cost of the paper and ink, you still have to buy the printer too. So as part of my processing flow I will often prepare the image for printing as part of the normal workflow, and then do a batch export when I'm going to send a print job to the lab.
This can leave you with lots of different versions of the image, all taking up storage space. The Lr Virtual Copy system is great for this, several different versions of the one image, from a single copy of the file. AS well as the print thing, I also have a liking for monochrome, having started with black and white film back around 1974/75 or so. For things that can be done using ACR the VC approach is great, and as far as I can see would be really simple for Adobe to add VC's to Bridge. All it would take, as far as I can see, is for Adobe to allow multiple xmp files for each image file. You would simply append the copy name to the end of the image file name to get the filename for each of the xmp copies. This would be a brilliant addition to Bridge, since it would also allow me to see each of the VC's that I have generated while using Lr, since at the moment in Bridge all I can see is the master copy of any image.
I know that for a lot of working professional photographers, shooting weddings and other general commercial work the level of DAM that is necessary is much much lower than mine. As long as the customer can tell you the date they got married for weddings finding the correct folder of images is easy. It is much the same for many other commercial situations, where you are generally producing one off batches of images, that you may well never have to access again after delivery to the client, even though you may well archive them all anyway. For that sort of use I think Bridge is probably all that you will ever really need.
There is one other thing that I notice about Bridge, no export tools. There is no way to go directly from a CR2 or a TIFF/PSD file to a resized JPEG file with applied output sharpening. You could send a batch of RAW files to ACR, or go via the Image Processor in Ps for RGB images, but it relies on having a current paid up subscription. This is actually one of the great things about Lr, even if you are running it in free mode without a subscription, you still have full access to everything other than the develop and map modules. So you can still export your images, either via the export dialogue, or in the Print, Book, Web, or Slideshow modules. I think the only export option you lose when using Lr in the free mode is the Edit in option from the right click menu. So potentially much better functionality than for Bridge without a subscription for access to Ps. Actually Lr still lets you import new images to the library, and apply the full range of metadata changes, except drag and drop geolocation. It is even possible to do basic edits via the quick edit tools in the Library module, you can also use quick edit commands on video, which you can't open in the Develop module, so you can adjust video WB and exposure etc. It does limit you to applying only one preset, as it first resets the image before applying a new preset. All of this without a subscription.
Remember that Bridge is now free, no need for a paid sub for any of the Adobe CC suite products.
Alan
maranelloboy05
Arlington, VA
Jan 01, 2018 09:42 |  #9
I used Bridge well before LR was a thing, but it just never felt that polished. I think I'll just need to stick with my current workflow and really keep in mind any changes I make may need to have me stepping backwards.
628 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00085 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is Steffan DK
964 guests, 486 members online
