Thread started 03 Jan 2018 (Wednesday) 13:27
Prev/next
Godox Xt32 question
smaeda
smaeda's Avatar
Joined Aug 2012
Shawnee, KS
Jan 03, 2018 13:27 |  #1
There is something I noticed about the Godox Xt32 trigger that wasn't there with the X1 trigger. The power adjustments and test fire button only works if the trigger is mounted to the hotshoe of the camera body. This really isn't an issue since the trigger will always be mounted while taking photos, but I found it a bit odd since you can control and test fire the flashes with the X1 trigger while it's not mounted to the camera body. Anyone know anything about this?
https://instagram.com/​shintarodesign (external link)
www.shintarodesign.com (external link)
https://www.facebook.c​om/shintarodesign (external link)
5Diii, 70-200mm f2.8 L, 35mm f2 IS, 100mm f2.8 L,
agv8or
agv8or's Avatar
Midwest
Post has been edited 12 days ago by agv8or.
Jan 03, 2018 14:56 |  #2
smaeda wrote in post #18532579 (external link)
Put fresh batteries in your XT32 and flash units. Make sure you have plenty of distance (at least 3-4 feet) between the XT32 and the flash units.
Which flash units are you using and what is their current firmware? Firmware in the XT32?
Rand
Gear
smaeda
smaeda's Avatar
Joined Aug 2012
Shawnee, KS
Jan 03, 2018 15:14 |  #3
Tried it on the TT600 speedlight. Both sets of eneloop batteries used were fresh off the charger so no issues there. Haven't checked if there is a newer firmware yet though. Does your xt32 controls work disconnected from the hotshoe?
smaeda
smaeda's Avatar
Joined Aug 2012
Shawnee, KS
Jan 03, 2018 15:20 |  #4
http://www.godox.com/C​N/Downloads.html (external link)
Looks like there aren't any firmware update options for the XT32 nor the TT600.
agv8or
agv8or's Avatar
Midwest
Jan 03, 2018 15:56 |  #5
smaeda wrote in post #18532664 (external link)
I use XT32 and FP R2T32's "off camera" for metering and adjusting flash power with Godox AD360II's, CL 360X, AD600B's, FP Xplor 600TTL, V860II, FP Zoom Li-ion R2 TTL, TT685's, and FP eVOLV200 R2's with no issues other than having a low battery one time in an Xplor600 where it would not trigger remotely.
I have some TT600's somewhere that I'll try to locate and test. Then I'll edit this post with my findings unless you or someone else figures something out in the interim.
EDIT: Amazingly found and tested 2 TT600's and had no issue with triggering and adjusting flash power with both an XT32 and FP R2T32 "off camera". Make sure that the TT600 is in Radio Slave configuration with the red light blinking on the front of the flash. Make sure you have the XT32 and TT600 on the same channel and the proper Group set when adjusting flash power.
Rand
Gear
smaeda
smaeda's Avatar
Joined Aug 2012
Shawnee, KS
Jan 03, 2018 16:08 as a reply to agv8or's post |  #6
If you have time to test the TT600 plus XT32 combo, that will be much appreciated. Unfortunately I don't have any other Godox brand lights on hand to test. Thanks!
262 views & 0 likes for this thread
Godox Xt32 question
made in Finland
by Pekka Saarinen
Spent 0.00094 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is marywilliams
819 guests, 316 members online
