FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 08 Jan 2018 (Monday) 23:28
RAID 5 v RAID 10
NCHANT
Joined Jul 2012
Jan 08, 2018 23:28 |  #1
Hey guys,
I currently have a QNAP TS-451 NAS with 4x4tb drives running in RAID 10, so around 8tb of usable space. I'm considering reformatting and going RAID 5 so I can boost the space to around 12tb, has anyone else done this or is using RAID 5?
6D | 600D | A6000 | 10-22mm ƒ3.5-4.5 USM | 24-105mm ƒ4L USM | TM 35mm ƒ1.8 VC | 40mm ƒ2.8 STM | 50mm ƒ1.8 | 85mm ƒ1.8 | 135mm ƒ2L | 200mm ƒ2.8L II | 55-250 ƒ4.5-5.6 II | Sy 24mm ƒ1.4 | Sy XP 14mm ƒ2.4
Flickr (external link) | Facebook (external link)
mike_d
Jan 08, 2018 23:33 |  #2
I'm running Synology's version of RAID 5 on my 5 bay NAS. Yes, you get more space since only one drive's capacity is lost to redundancy, but you also get less redundancy. It's always a tradeoff. What's your tolerance for losing the array?
NCHANT
Joined Jul 2012
Jan 08, 2018 23:55 |  #3
mike_d wrote in post #18536806 (external link)
It's hard to say really, I just want to simplify how I store my photos. I'm currently doing a spring clean and eliminating all the clutter, then will compile all my images off my external drives and into one big catalog on the NAS. Then use the spare external drives to make backups of the most important shoots – weddings, workshops etc.
tim
Light Bringer
Jan 10, 2018 01:46 |  #4
I assume you've read a number of articles (external link) on RAID5 vs RAID10? RAID10 is going to be safer and easier to recover.
What is your reason for using RAID? I use what's effectively a RAID mirror to protect against data loss during a drive failure. I also have careful and extensive backups.
Jethr0
Gallery: 38 photos
Joined Aug 2012
Jan 10, 2018 05:46 |  #5
Raid 5 is great for capacity with a side benefit of some parity/redundancy. It’s “slower” than raid 10 though.
You can’t lose more than one drive in a raid 5 array, so if there’s spare functionality NAS you should use it.
Raid 10 is quick for sure but it really gobbles the gigs to accomplish what it accomplishes.
www.jefflowe.ca (external link)
Instagram: https://www.instagram.com/jeff​lowe.ca (external link)
drmaxx
Gallery: 11 photos
Post edited 3 months ago by drmaxx.
Jan 10, 2018 07:10 |  #6
^^^ This!
I regret going RAID 5 on my (personal) NAS. I have good local backups and for me it is not very important to have a high uptime reliability of the NAS. Now, I just have 25% less storage space for no real useful benefit. Additionally, the load on my NAS is not very taxing on the HD so that the probability of loosing one of them is fairly low (WD red). Your miles might vary - but RAID is not for data safety but only for uptime - and this is what you need to keep in mind for making your decision.
Donate if you love POTN
eelnoraa
Jan 12, 2018 11:39 |  #7
Is there any reason to use RAID10 over RAID6? I think RAID6 is even safer.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
CyberDyneSystems
Admin (type T-2000)
Gallery: 79 photos
Joined Apr 2003
Post edited 3 months ago by CyberDyneSystems. (2 edits in all)
Jan 12, 2018 11:43 |  #8
I'm not familiar with the Qnap from personal use.
My experience with RAID 5 is that unless you have a very high end high performance controller, it is significantly slower than RAID 10 (or 0+1) in use, and even more slow when a rebuild is required. Rebuilds taking 24 plus hours are possible (depending on TB and controller) Where as with RAID 10 a rebuild will be similar to the time it takes to simply copy one HDD to another.
So the decision comes down to capacity vs. speed.
I choose speed :)
*Note, in my case, the RAID is my WORKING active array. It is not a back up archive.
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 79 photos
Joined Apr 2003
Jan 12, 2018 11:44 |  #9
eelnoraa wrote in post #18539391 (external link)
Speed. Also, if only 4 drives are used, you gain no increase in capacity vs. RAID10
CDS' HOT LINKS
eelnoraa
Jan 12, 2018 11:48 |  #10
I think for most NAS, the speed is bottle neck by the LAN speed by far. Normal usage, I don't think the read speed matter much, right? I agree the speed for rebuilt, but this should be a rare event.
CyberDyneSystems
Admin (type T-2000)
Gallery: 79 photos
Joined Apr 2003
Jan 12, 2018 11:49 |  #11
eelnoraa wrote in post #18539406 (external link)
This is true, thus I edited to add my note about my own uses being non archival non-NAS.
CDS' HOT LINKS
eelnoraa
Jan 12, 2018 12:18 as a reply to  @ CyberDyneSystems's post |  #12
IC, understood.
My NAS is also acting as an centeral data repository at home, not for backup purpose. I have enough drive space and currently with RAID5. When I swapping the drives out, I kind of the added security of 10 or 6. I am leaning toward 6 because I can afford to lose any two of out 4 drives. With 10, it has to be 1 drive in each pair. However, I don't know if going to 10 will improve performance in my usage, if so, I think 10 is also a consideration
531 views & 0 likes for this thread
RAID 5 v RAID 10
version 2.0 /
Latest registered member is benbodey
815 guests, 415 members online
