Thread started 11 Jan 2018 (Thursday) 09:16
Need Really Good Batteries for Flash
FreeSoul1987
Gallery: 13 photos
Joined Jul 2012
Jan 11, 2018 09:16 |  #1
Alright, I've got a 430EX II Flash, and I've had it for 3-4 years and I normally just regular AA batteries like the Energizer brand.
Everything works for the first 5-10 shots, the flash goes off as quickly as I press the shutter... then after 5-10 shots the delays begin and sometimes it can take up to 45 seconds for the flash to power back up and flash again. I'll put in new fresh batteries and the flash is great for another 5-10 shots, then right back where I started.
Is it the batteries? And if so, what batteries do you guys prefer for your flashes?
*Do It For Yourself, Do It Because They Said It Was Impossible, Do It Because They Said You Were Incapable*
www.FreeSoulPhotograph​y.smugmug.com (external link)
Gear: Canon T2i, 430EX II flash, Tamron 18-270mm VC PZD II, Canon 18-55mm lens, Canon EF 50mm f/1.8 II lens
bobbyz
Jan 11, 2018 09:20 |  #2
Eneloops though now a days I would get a flash with lithium ion battery.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
drmaxx
Gallery: 12 photos
Post edited 3 months ago by drmaxx. (2 edits in all)
Jan 11, 2018 09:41 |  #3
Recycle time has a lot to do with the chemistry of the battery. Rechargeable batteries such as previously mentioned eneloops can provide consistently high currents (= low internal resistance) and therefore refresh the flash faster then non-recharchable (e.g. alkaline). If you don't want to invest into rechargeables then you also can go with 'Lithium' batteries (often labelled with nominal 1.7 V or now also 1.5 V; not to be confused with lithium ion). These work much better then alkalines. These perform very poorly in high drain conditions such as rapid flashes.
Donate if you love POTN
Wilt
Post edited 3 months ago by Wilt.
Jan 11, 2018 11:35 |  #4
About batteries: In general, the chemistry of a battery determines its output voltage!
  • There have been available 'lithium AA' 1.5V batteries for decades, but these are NOT RECHARGEABLES. (For example Energizer Ultimate Lithium is the #1 Longest-Lasting AA Battery, meaning that you can have them 'on the shelf' and pick them up 10 years later and know they will still work your emergency radio.
  • More recently that AA 'lithium' the CR123 battery form factor was launched, Non-Rechargeable Lithium battery Rated 3 Volt, capacity 1.55Ah
  • There are also C-size 'lithium' CR2 battery form factor, , Non-Rechargeable Lithium battery Rated 3 Volt, capacity
  • There are recently available 'lithium AA' rechargeable batteries that OUTPUT 3.7V, which is generally not suitable to replace alkaline AA batteries in your flash. (For example, Li-ion Lithium Battery Rechargeable Batteries, 2200 mAh, 3.7V)
  • There are special lithium 'battery packs' made to fit specific flash units, where the flash unit was designed to accept lithium battery packs as rechargeable units for rapid swap out of the pack, such as for professional uses requiring minimized downtime for battery swap during a job
For rechargeable AA in place of alkaline AA, use NiMH AA rechargeables
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
TeamSpeed
01010100 01010011
Gallery: 72 photos
Joined May 2002
Jan 11, 2018 12:01 |  #5
Those lithium battery packs (laptops, cameras, and even flashes) are just a molded case around one of a few very commonly used cylindrical lithium cells that look much like AA or AAA batteries (but different sizes).
The few new battery techs that have been in the news look very promising though!
Past Equipment | My Gallery (external link)
ksbal
Gallery: 256 photos
Best ofs: 9
Jan 11, 2018 12:22 |  #6
Duracell. Period... but now I have switched to lithium ion batterys that are rechargeable and love not having to lug around extra batteries. Yeah!
YN622 English User Guide/Manual by Clive
https://drive.google.c​om …Ig0gMMzZFaDVlZ1​VNTE0/view (external link)
RMyers
Gallery: 12 photos
Jan 11, 2018 15:26 |  #7
I use the Amazon Basics High Capacity. Stay charged a long time when not in use and last a long time in use. https://www.amazon.com …Pre-charged/dp/B00HZV9WTM (external link)
Rusty
Austin, TX
soeren
Whoops Im not updated
Joined Nov 2017
Jan 14, 2018 23:53 |  #8
Eneloops
Angmo
looks like I picked a bad week to give up halucinagens
Gallery: 22 photos
Joined Dec 2015
Post edited 3 months ago by Angmo.
Jan 15, 2018 00:28 |  #9
Fujitsu. Japanese made in Japan not China like most others. Eneloop are made in China or Japan depending on where they are shipped. Eneloop pros are all made in Japan last I checked though.
Nikons, Rolleiflexes, Elinchroms, Billinghams
echelonphoto
Joined Apr 2001
Jan 15, 2018 11:39 as a reply to  @ soeren's post |  #10
Eneloop pros...the black ones are the best...use these constantly professionally...get faster recycle and more flashes per charge....never let me down yet and I own at least 20 of these.
msowsun
Gallery: 14 photos
Post edited 3 months ago by msowsun. (2 edits in all)
Jan 16, 2018 16:38 |  #11
I have searched around and can't find anyone who has tested these new AA USB Rechargable Lithium ion batteries in a flash unit or Yongnuo YN622 tranceiver.
This battery uses lithium-ion polymer cells, and changes the voltage of 3.7V to the constant output voltage of 1.5 V through voltage conversion technology. It completely replaces the disposable alkaline batteries and nickel-metal hydride batteries. Meanwhile, the stable output voltage of 1.5V of universal lithium batteries solves the problem that some electric appliances are unable to work because NI-MH rechargeable batteries' voltage is too low (1.2V). It has greatly improved the battery life. Battery has two outlet ends, the output of one end is 1.5V, the normal use of electrodes; the other end is 3.7V, used to charge the battery.
Has anyone thought about it besides me?
http://www.unbatteries​.com/ (external link)
https://www.amazon.com …sb+rechargeable​+li-ion+aa (external link)
Mike Sowsun / S110 / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 18-135mm STM / EF-S 18-135mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 1.4x II
drmaxx
Gallery: 12 photos
Jan 16, 2018 16:56 |  #12
msowsun wrote in post #18542485 (external link)
Not quite sure what you are hoping to gain from them? The first two have less capacity then ordinarily NiMH (eneloops) and I doubt that the internal electronics needed to reduce the 3.6 V of the li-ion to 1.5 V can sustain high currents = fast flash recycle. NiMH can handle easily 5 or 10 A for a short time. And they are not exactly cheap. Not sure what the third thing is? Maybe somebody else can chime in there.
msowsun
Gallery: 14 photos
Jan 16, 2018 17:01 |  #13
One application I thought of is for my Yongnuo YN-622 transceivers. They need close to 1.5V to operate and seem to run down quickly with my 1.2V NiMH batteries.
drmaxx
Gallery: 12 photos
Jan 16, 2018 17:42 |  #14
msowsun wrote in post #18542504 (external link)
This also would mean that the transceivers only utilize a fraction of the alkalines capacity. Quite sad actually.
msowsun
Gallery: 14 photos
Post edited 3 months ago by msowsun. (9 edits in all)
Jan 16, 2018 18:19 as a reply to  @ drmaxx's post |  #15
The YN-622s are designed for 3V(2x 1.5V) but will keep working until 2.2V. The YN-622C-TX has an LCD display with a battery charge indication and it doesn’t show full charge very long with 1.2V batteries.
The Other YN-622C User Guide II - v.5.12 https://drive.google.c​om …Ig0gMMzZFaDVlZ1​VNTE0/view (external link)
2,166 views & 12 likes for this thread
version 2.0 /
Latest registered member is Nidge
712 guests, 391 members online
