FORUMS Photography Talk by Genre Macro Talk
Thread started 24 Jan 2018 (Wednesday) 11:04
Prev/next
canon 100 or sigma 150?
disneydork06
disneydork06's Avatar
Phoenix, Arizona
Jan 24, 2018 11:04 |  #1
I already have a 50mm sigma macro and I like it but not when I try and shoot at 1:1 ratio. It's not fun getting close to bumping into my subjects. :oops:
I'd like to really get into it more and have the variations of using for portraits as well. I saw the canon 180 and sigma 180. Note: I'm buying used to help me save money...
I'm thinking 100mm is good overall but, would it be better, if I wanted to dive more into it, to get the 150 or one of the 180s?
Ryan
~AZ POTN Planned Activitiesexternal link
let me know how I can improve, cause we all know I need it :): Flickrexternal link
myspaceexternal link facebookexternal link The Greatest online forum known on Earthtwitterexternal link[URL="http://www.500px​.com/RDimal"]500xp follow me! in something^ you know you want to
Dalantech
Dalantech's Avatar
Bacoli, Italy
Post has been edited 29 days ago by Dalantech.
Jan 25, 2018 02:13 |  #2
disneydork06 wrote in post #18548018 (external link)
...I'm thinking 100mm is good overall but, would it be better, if I wanted to dive more into it, to get the 150 or one of the 180s?
If you're using natural light as the primary light source then get a long focal length lens -the longer the better.
If you're using a flash as the primary light source then get a short focal length lens. You'll want to get the flash as close to the subject as possible to get good diffusion and to keep the flash duration as short as possible (to freeze motion and get sharper images). You already have the Sigma 50mm. Does the lens extend when you turn the focus ring?
A 100mm macro lens is a poor choice. It's 6" working distance is only 2" more than Canon's EF-S 60mm so not much of a gain when using natural light, and the working distance will work against you when using a flash.
If you want to shoot macro then buy a macro lens. If you want to shoot portraits then buy a portrait lens. Don't buy something that might not work really well for either discipline.
My Gallery (external link)
My Blog (external link)
Macro Tutorials (external link)
disneydork06
Phoenix, Arizona
Jan 25, 2018 15:07 as a reply to Dalantech's post |  #3
Well I can't use any ef-s lenses. I'm hoping it would work well with macro and yet side benefit as a portrait type lens as well. With my 50 sigma, I an mere milimeters from a subject when focused in at the closest focal point. It does extend when focusing in.
Ryan
Wilt
Wilt's Avatar
Belmont, CA
Post has been edited 28 days ago by Wilt.
Jan 25, 2018 18:18 |  #4
Generally speaking, the distance between subject and focal plane is 4*FL to achieve 1:1. So 200mm distance with 50mm FL vs. 720mm for 180mm FL
In AF lenses, the above generalization breaks down simply because the optics CHANGE FL when shooting at macro magnifications in order to reduce the distance that optics have to be moved to focus at macro distances. For example, so-called '100mm macro' lens at 1:1 magnification truly is a 77.5mm FL!
The Canon 180mm macro focuses to 430mm (rather than to 720mm) yet achieves 1:1 at that distance, compared to the 100mm macro achieving 1:1 at the 310mm (rather than 400mm).
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
Tom ­ Reichner
"I am a little creepy"
Tom Reichner's Avatar
Omak, in north-central Washington state, USA
Jan 25, 2018 22:34 |  #5
Wilt wrote in post #18548935 (external link)
Does the focal length itself actually change?
Or is it just the field of view that changes?
Although many people think that these two things are synonymous, they are not.
Dalantech
Dalantech's Avatar
Bacoli, Italy
Post has been edited 28 days ago by Dalantech.
Jan 26, 2018 01:14 |  #6
Tom Reichner wrote in post #18549080 (external link)
I'm going to say that the actual focal length changes, because it only takes 37mm of extension tubes to get the EF-S 60mm to 2x.
Edit: Also want to add that the focal length drop only seems to work with macro lenses that do not change shape when you turn the focus ring. If the focusing is internal then the focal length will drop. I've often referred to the EF-S 60mm as the "poor man's MPE-65mm" due to it's ability to hit 3x with a full set of tubes. Granted not as good as the MP-E's 5x but if I'm being honest I don't do a lot of shooting above 3x. You can even use the EF-S 60mm on a non APS-C camera as long as you use at least a 12mm extension tube. The tube keeps the mirror from hitting the back of the lens.
707 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00083 for 4 database queries.
PAGE COMPLETED IN 0.05s
Latest registered member is Bevo
455 guests, 298 members online
