FORUMS General Gear Talk Data Storage, Memory Cards & Backup
Thread started 25 Jan 2018 (Thursday) 17:34
help with my memory card
FreeSoul1987
Gallery: 14 photos
Joined Jul 2012
Jan 25, 2018 17:34 |  #1
The card was working fine two days ago, this afternoon I turn on my camera and I'm getting this message. any help?
*Do It For Yourself, Do It Because They Said It Was Impossible, Do It Because They Said You Were Incapable*
www.FreeSoulPhotograph​y.smugmug.com (external link)
Gear: Canon T2i, 430EX II flash, Tamron 18-270mm VC PZD II, Canon 18-55mm lens, Canon EF 50mm f/1.8 II lens
John ­ from ­ PA
Joined May 2003
Post edited 3 months ago by John from PA. (3 edits in all)
Jan 25, 2018 19:13 |  #2
I see in your equipment you have a T2i which was prone to issues with the SD card slot area. But start with checking the card then move to checking the camera.
Are there any valuable images on the card? If not do an in camera low level format and report back. Also, try a different card and see what behavior you get. Carefully check the plastic that borders the sliding contacts. It has been reported that some of the plastic may break off. Last thing would be to get a really bright light and look into the slot. You should see a switch that should line up with the notch on the side of the card near the lock switch. Do you see any damage on the switch? There are also some reports of people having issues that were fixed by filling the void adjacent to the lock switch and then applying scotch tape over the switch area. This enabled the camera to work.
MadMadge
Jan 25, 2018 19:16 |  #3
The card may possibly be corrupt. Do you have a memory card reader you could try it in?
FreeSoul1987
Gallery: 14 photos
Joined Jul 2012
Jan 26, 2018 09:20 |  #4
This is the first time my T2i has had an issue, and I've used many SD cards with it.
I've tried formatting it as I've already erased what was on there (or taken off) and I keep getting an error that Windows cannot format card. I've tried both the low level format and the other one (can't remember what it was but I am not home at that computer). And it came up with the error both times, I am having no issues with my other cards though, I've got 3 other working cards and I have no issues with them.
I went ahead last night and bought another 32 GB just like this one, just in case I have to trash this one.
FreeSoul1987
Gallery: 14 photos
Joined Jul 2012
Jan 26, 2018 09:22 |  #5
My cards.
The transcend one is damaged (thanks to my son) but I am unwilling to get rid of it.
John ­ from ­ PA
Joined May 2003
Jan 26, 2018 10:43 |  #6
FreeSoul1987 wrote in post #18549314 (external link)
Based on these various comments, and the fact that memory is cheap, I would trash the card that gave you the original issues. Even if you get it working, why risk a chance it would act up again and at a time when you might lose valuable images?
By the way I previously mentioned a low level format in camera meaning don't do it in a computer. It isn't super critical but done in camera a very specific directory structure is established.
FreeSoul1987
Gallery: 14 photos
Joined Jul 2012
Jan 26, 2018 11:33 |  #7
John from PA wrote in post #18549381 (external link)
Based on these various comments, and the fgact that memory is cheap, I would trash the card that gave you the original issues. Even if you get it working, why risk a chance it would act up again and at a time when you might lose valuable images.
I'll remember that. And yeah I'll go ahead and toss it.
eelnoraa
Jan 26, 2018 16:34 |  #8
If even Windows can't format with a card reader, the card is shot.
My question to OP, is there any reason you want a UHS-II card for a Ti2? It costs more and you won't have any benefit with Ti2.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
John ­ from ­ PA
Joined May 2003
Jan 27, 2018 08:30 |  #9
eelnoraa wrote in post #18549696 (external link)
Good point, just go to Best Buy and get the card below for $20 (MSRP $55).
tim
Light Bringer
Jan 29, 2018 12:21 |  #10
My experience is Lexar cards have more problems than other brands.
If a card ever plays up at all, either toss it out or have it replaced. It's not worth any risk. Test the cards each year, I use this (external link).
RPCrowe
Joined Nov 2005
Post edited 2 months ago by RPCrowe.
Mar 21, 2018 14:30 |  #11
What pieces of crap are SD cards in comparison to CF cards. I have had CF cards go through a washing machine and another chewed up by a puppy - they still worked (although I retired the CF card that was chewed up). I have never in over 15 years of shooting had a CF card go bad (although I did get two Kingston CF cards which were bad from the start). No more Kingston cards, no more problems:twisted:
People complain that the Canon 6D2 only has one SD card slot. That Is my complaint too. Although the complaint isn't about one slot, I would be happy if the single slot was for a CF card. In fact I have had my 7D2 for several years now. It has a CF and and an SD card slot. I have only inserted an SD card in the extra slot one time :rolleyes: to ensure that it was working.
Physically, the CF cards are a lot more robust. I cringe every time I put pressure on the SD card in my 6D2 and hope that the darn flimsy thing doesn't break...
John ­ from ­ PA
Joined May 2003
Post edited 2 months ago by John from PA.
Mar 21, 2018 19:38 |  #12
RPCrowe wrote in post #18591046 (external link)
I'm old enough that I don't buy green bananas, so I may not be around for the demise of CF cards. See https://www.imaging-resource.com …h-another-new-card-format (external link)
716 views & 4 likes for this thread
Latest registered member is eyecancu
753 guests, 356 members online
