FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 30 Jan 2018 (Tuesday) 13:53
need strap or adapter suggestion for a 300 2.8
mikeinctown
Joined May 2012
Jan 30, 2018 13:53 |  #1
I normally use my CPS strap outfitted with the OP/Tech sling strap adapter for all my camera gear as until now the heaviest combo I had was a 1Dx/ Sigma 150-600 and would just trust the camera mount to hold the lens. I now own a 300 2.8 IS and want one strap on the camera support and the other on the lens. Not sure what you all do in that situation.
As I like the Op/Tech system I had figured one of two methods.
1) Attach QR plate to base of lens and attach a strap to the little slot they give you to attach a camera strap to the plate. https://www.amazon.com …fRID=K64B7F16S1​XY3J0CTJNN (external link)
2) attach a 1/4 mounting ring to the bottom of the lens and then attach the strap to that. https://www.amazon.com …fRID=K64B7F16S1​XY3J0CTJNN (external link)
3) Is there another way to attach that would work with my sling strap?
I would often just mount the lens on a monopod but I'll be indoors and won't be able to use a monopod.
Thanks in advance.
Canon EOS 1D X | Canon EF 24-105mm f/4L IS USM EF 70-200mm f/2.8L IS II USM | Sigma 150-600mm F5-6.3 DG OS HSM | Contemporary
Snydremark
my very own Lightrules moment
Gallery: 44 photos
Jan 30, 2018 15:24 |  #2
mikeinctown wrote in post #18552631 (external link)
Thanks in advance.
I'd go with option 1 just so that the lens is still set for going onto a mono/tripod even when not using the sling. Otherwise, you'll wind up having to screw/unscrew the attachment for either sling OR tripod use.
- Eric S.: My Birds/Wildlife (external link) (7D MkII/5D IV, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS I/II)
imagesbybillmarlow
Joined Jan 2018
Mar 07, 2018 20:05 |  #3
Just out of curiosity and I am not being a smartass, but why can't you use a monopod indoors? I don't have a lot of experience with this stuff, just trying to learn.
bpalermini
Gallery: 67 photos
Joined Mar 2011
Mar 07, 2018 20:29 |  #4
For big whites, I just go with a strap on the lens on the strap mounts. I have easy to take off straps on my bodies.
Bob Palermini
1DX, 5DIV, 14 Rokinon, 16-35L II, 24-70L II, 100L, 70-200 IS 2.8L, 100-400L II, 400mm 2.8 IS II, 1.4xIII, 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, LRCC, Fuji X-E2, Fuji X30
My Web Site (external link) | My Sports Portfolio (external link)
pbrimages
Joined Apr 2013
Post edited 2 months ago by pbrimages. (2 edits in all)
Mar 07, 2018 21:00 |  #5
imagesbybillmarlow wrote in post #18579988 (external link)
No worries. Not a bad question. When someone wants to add a strap to the lens, it is usually not for purposes of handhold while shooting, but for purposes of carry while resting/moving, switching lenses, or even to other bodies. It makes it easier to deal with a large lens, especially when carrying some type of additional storage case for the lens is not possible. (e.g.: sports sideline photography or similar)
Welcome to the forum!
1DX, 1Ds MkIII IR (FSp), 1Ds MkII, 1Ds, 1D, 1V-HS, G1x II, 550D (Running ML), Elan 7e, 300D, WFT-E2A, WFT-E1A, 17-40 L, 70-200 2.8 L IS USM, 400 DO IS USM, 50 1.4, 50 1.8 Plastique Fantastique, and a host of other less-than-noteworthy detritus
Snydremark
Gallery: 44 photos
Mar 07, 2018 21:31 |  #6
Could be too crowded of a venue, may be management restriction, some petty minor functionary w/ a clipboard, etc.
imagesbybillmarlow
Joined Jan 2018
Mar 07, 2018 21:55 as a reply to  @ Snydremark's post |  #7
Thank you. Thanks for taking the time to answer.
renaissance_myth
Joined Nov 2012
Mar 08, 2018 02:44 |  #8
Personally I just use a black rapid RS7 mounted straight on the tripod collar of the lens when I am not using a tripod. I use a 1D4 with the 300.
Hope that helps!
"Dear God, please let me master light"
521 views & 0 likes for this thread
Latest registered member is cabvkam
659 guests, 263 members online
