#1 |
Just wanted to let everyone know that if you are looking to color manage your images, and want to use an online service, www.ezprints.com has a way to do this. They advertise and will give you a profile they use for output. They reverse calibrated this profile so that we photographers can use this for soft proofing in Photoshop. You should check it out.
By the way, does anyone know what is the best monitor to use for soft proofing? Thanks for any input... |
| sponsored links |
#2 |
AS I understand it soft proofing is away to color adjust a print that you want to send out for printing.
Any CRT monitor will do that is a newer model. In order for you to get colors visually right your monitor has to be calibrated. Then I use MFG paper ICC profiles to print. They are giving you there profiles so when you send it your out put will print properly. I do not think you need to make a soft proof for that, I would ask them. If you use adobe 1998 and apply there Icc I think that will do. I use a Spyder/photcal set up and what I see on my monitor is almost exact when I print it out on my Epson 2200.
MKII N-Canon 20D - Tamron 90MM F2.8 Macro - Tamron 17-35 F 2.8-4 - Canon 70-200 F4 L Canon 100-400 F4.5-5.6 IS L - Kenko Pro 300 Ext 2 X - 420 EX |
| Thread Tools | |
| Display Modes | |
| Lightroom & ICC profiles for online printing | dbump | RAW, Post Processing and Printing | 0 | 25th of February 2007 (Sun) 12:19 |
| ICC profiles & Canon iP6000 printer - help! | Cathy Rondo | RAW, Post Processing and Printing | 4 | 4th of July 2006 (Tue) 14:06 |
| Photo Labs, Do they Need/Want your monitors ICC Profile? | StealthLude | RAW, Post Processing and Printing | 4 | 6th of April 2006 (Thu) 11:35 |
| ICC Profiles?? What are they?? | Feihung08 | RAW, Post Processing and Printing | 14 | 4th of March 2005 (Fri) 05:37 |
| Raw Image Conversion & ICC Profiles | mikedavid | Canon G-series Digital Cameras | 3 | 20th of August 2002 (Tue) 12:30 |
