Thread started 04 Feb 2018 (Sunday) 23:25
Prev/next
diff tool for raw photos
chapster
NY
Feb 04, 2018 23:25 |  #1
Anyone know of a diff tool for mac that can compare raw format files.
I have 2 hard drives with some mixed edits on some files and I need a tool that can compare both hard drives with each other and tell me which raw files have changed on each drive ?
kirkt
Philadelphia, PA USA
Post has been edited 20 days ago by kirkt.
Feb 04, 2018 23:31 |  #2
In most cases a raw file is not changed. You would need to look at the database, if you use an app like Lightroom that writes its edits in the database, or at the sidecar files that a raw converter would write as a text file next to the raw file that contain the editing settings.
DNG files will contain the edit instructions in the file itself. I did know how you might go about running a diff on two DNGs.
Kirk
Kirk
images: http://kirkt.smugmug.c​omexternal link
CyberDyneSystems
Admin (type T-2000)
CyberDyneSystems's Avatar
Gallery: 78 photos
Joined Apr 2003
Rhode Island USA
Post has been edited 20 days ago by CyberDyneSystems.
Feb 04, 2018 23:34 |  #3
I am a bit confused by your question, as RAW images never change.
An app, like lightroom or aperture can save edits to RAW files within the apps data base. Or you can "save as" or export as a jpeg or tiff, but the raw file never changes. So if you have multiple copies of a raw file on different drives, even if you've had one copy open in an editor, the two copies will still be identical.
If you are just looking to see if you have multiples, the filename should be the same.
CDS' HOT LINKS
chapster
NY
Post has been last edited 20 days ago by chapster. 2 edits done in total.
Feb 04, 2018 23:51 as a reply to kirkt's post |  #4
Kirkt If you can remember how to diff DNG files that would be great. As far as Lightroom goes how would I compare or look at the database ?
BigAl007
Repps cum Bastwick, Gt Yarmouth, Norfolk, UK.
Feb 05, 2018 06:07 |  #5
chapster wrote in post #18556563 (external link)
Just open the all images view and set order by date. I would probably filter for master copies, just to remove any virtual copies from view. Then all you have to do is scan the images visually for duplicates. If you know which folders the suspected duplicates are in then it is possible to select multiple folder locations, or even folder trees, if you have show sub folders enabled, simply by using Ctrl+Click. This then will reduce the number of images to be viewed to a minimum.
Since the edit instructions are held as text strings within the DNG file a simple binary diff tool will find any files with the same name and creation date that have differences. Of course with the DNG files initially what you really want to know is which files are identical binary copies, since getting rid of one of those will be a no brainer. Then you will need to compare the binary different files visually to see what the differences are. It may well be that the edits are the same, but the EXIF details are different, as this will also produce a binary difference in the file.
All of this presupposes you used either Lr, or worked using DNG files. If you used any other editing application working on native RAW formats then this won't show you any differences in edits between the different applications. Since this is still a Canon oriented forum one thing to note is that if you use DPP as your RAW editor that program, and that program alone, stores it's edits as metadata in the original CR2 file, just like with DNG files, not in a sidecar file.
Actually writing the edit information directly to the RAW file as metadata is a valid option for any RAW converter, since doing that won't actually change the image data of the file in any way. Each RAW editing program simply needs to create a new section within the "Private" area of the files metadata to store the information. As long as all programmers respect this you could have multiple edits from multiple programs, with all the data retained within the one file.
Alan
My Flickr (external link)
342 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00087 for 4 database queries.
PAGE COMPLETED IN 0.01s
Latest registered member is Valokuva
1006 guests, 508 members online
