Thread started 02 Mar 2018 (Friday) 08:10
16-35 f/4 IS filters for landscape
Gallery: 90 photos
Mar 02, 2018 08:10 |  #1
Can someone reccommend a good filter set for doing landscape with this lens? I know of the Lee filter system, but I really do not want to spend that much right now.
While another system similar to Lee that is cheaper would be great, I don't really need something that would work with several different lenses. I only plan on taking the 16-35 with me when I go hiking. One thing I am not sure of though, is if there is any difference in using multiple screw on filters (CPL and ND at the same time) vs something like Lee where you can add a CPL, ND, and GND all at once.
Flickr (external link) | Web Page (external link)
Joined Mar 2002
Post edited 11 days ago by puttick. (3 edits in all)
Mar 07, 2018 06:29 |  #2
I have that lens and many filters. If using a screw in ND or CPL it's best to use just one, as if you stack them you will get actual physical vignetting (not light fall-off which is often called "vignetting" but isn't!) with hard dark corners that you cannot recover. One filter is fine at any focal length on that lens.
If you have a 100mm filter system, such as Lee, you must buy the wide angle adapter ring, not the standard one. This has less projection, to avoid hard vignetting. If you have a UV filter, take this off first. The 100mm width of the filters is much less of a problem, though you will probably find you can't use more than two filters (say a 10-stop ND, an ND grad, plus a polariser. I only use my Lee system in this way, so my filter holder is usually set up with just two slots plus the ring for the polariser.
There's no escaping the cost, there are even more expensive filters than Lee! Buying used is an option, but remember they will last a long time if cared for. Though there 100mm Cokin which are less expensive, and cheap ebay knockoffs (best avoided). Of course ND grads have to be slid up/down, so you need the 100x150mm size (which also means you can use just part of the filter as a non-grad!).
Screw-in ND grads are useless unless your scene demands a gradient in the exact centre...!
Polarisers are not great on very wide angle lenses as you tend to get a difference in density across the sky, this is unavoidable as the angle of polarisation changes, and at 16-24mm will be very noticeable so perhaps best avoided, except for controlling water reflections. If you want a bluer sky, do it in software.
To save money, if ND grads are your thing, you can do a lot of that in Lightroom (etc). For very long exposures, a much less expensive screw-in 77mm 10-stop ND filter will work very well, I paid £20 for mine.
Or buy a Lee holder and just one ND grad - to be honest an 0.6 hard grad is my most used filter.
Hope that helps. If you're in the UK try to get to the Photo Show at NEC, lots to see there, try the SRB stand.
Nigel Puttick
North Yorkshire, UK
fondling the 5D4
Gallery: 65 photos
Joined Sep 2013
Mar 07, 2018 08:33 |  #3
Go Lee. Buy once, cry once. You won’t regret it.
Getting better at this - Fuji Xt-2 - Fuji X-Pro2 - 18-55 - 23/35/50 f2 WR - 50-140 - flickr (external link) -​m
Mar 09, 2018 07:18 |  #4
I was in the same boat as you not too long ago. I would highly recommend buying the filter holder kit from, you can get the wide angle adapter ring, filter holder, and 105mm ring for a polarizer for $80 which is what you pay for just the Lee holder. Then you can piece together filters as needed or desired.
1,444 views & 1 like for this thread
version 2.0 /
Latest registered member is AllysaCarberry
818 guests, 480 members online
Simultaneous users record so far is 6430, that happened on Dec 03, 2017 Digital Photography Forums is the website for photographers and all who love great photos, camera and post processing techniques, gear talk, discussion and sharing. Professionals, hobbyists, newbies and those who don't even own a camera -- all are welcome regardless of skill, favourite brand, gear, gender or age. Registering and usage is free.
