Thread started 16 Apr 2018 (Monday) 13:35
Godox Experts I Need Your Help!
Josh ­ G
Apr 16, 2018 13:35 |  #1
I recently bought a Sony A7iii and a Godox V8600II-S Flash. The on-camera V860II works great as a master with my slave My Godox AD200 units, but I can't get my Godox AD360II-C strobe to work with the V860II as a slave unit in TTL mode. It will work in manual mode though.
I was under the impression that all 2.4ghz Godox flashes could fully communicate with each other regardless of their camera designation (canon, nikon, sony, etc..) Am I mistaken?
Do I need an X1R-S receiver on the AD360II-C to make it work in TTL with the V860II-S? Or do I need a X1T-C Transmitter on the A7iii body?
Thanks!
jlafferty
Joined Feb 2017
Apr 16, 2018 13:46 |  #2
You're mistaken. You can't mix and match TTL communication across brands. This is why it works in Manual only.
Josh G wrote in post #18607974 (external link)
Thanks!
Current Portfolio (external link)
jlafferty
Joined Feb 2017
Apr 16, 2018 13:48 |  #3
FWIW Godox stopped producing the 360-S or Adorama stopped selling it because the TTL metering was inconsistent.
You will likely have better luck working with the eVOLV / AD200s.
TeamSpeed
01010100 01010011
Gallery: 72 photos
Joined May 2002
Post edited 10 days ago by TeamSpeed. (2 edits in all)
Apr 16, 2018 14:14 |  #4
I am confused with the Xpro for Sony won't talk to all 3 flashes as slaves?
Is the 360IIC internally designed only to work with Canon?
I have the first gen AD360 and have to use the XTR16 as a receiver. Will that work if I had a Sony camera with an XPro?
Past Equipment | My Gallery (external link)
jlafferty
Joined Feb 2017
Apr 16, 2018 16:28 |  #5
There's two issues: triggering the flash; working with TTL. You can do the first. So can the OP. You cannot use Sony TTL to fire a Canon light in TTL mode.
TeamSpeed wrote in post #18608000 (external link)
Josh ­ G
Apr 16, 2018 16:41 as a reply to  @ jlafferty's post |  #6
But if I put a X1R-S on the AD360Ii-C will the TTL work with the V860II-S?
inkista
Post edited 10 days ago by inkista. (4 edits in all)
Apr 16, 2018 20:13 |  #7
What's the firmware version on the AD360II-C (it's at the top of the C.Fn menu)? The AD360II-C predates the -S triggers, and must be at v2.6 or later (current version is 2.8) to be compatible with the -S triggers, and v2.7 to be compatible with the -F/-O triggers. v2.6 was released in April 2016.
Well, the X1R receivers and the TT350 are not supposed to be able to do cross-brand TTL, but all the other TTL-capable lights should be able to be used the way you describe. That's the way it's supposed to work: remote power control, HSS with any of the Godox lights and TTL with any of the lights that are capable of TTL.
Whether it actually works that way can be a bit different. :) I'm having some seriously rotten luck with HSS/TTL and my TT685C from my GX-7 and XProO, and some rotten luck with HSS with my TT600 speedlights and my XPro-F, but that's another story.
No. You shouldn't need any of that and the hotshoe contacts wouldn't match the foot pins, and the gear would be manual-only (although with the MI hotshoe, it might not even work to sync). The built-in transceivers in the Godox speedlights and AD360II should be able to autoswitch between the five supported systems even in the same shoot.
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
dmward
Gallery: 28 photos
Apr 23, 2018 22:22 |  #8
As mentioned, the key is getting the latest firmware into the lights and the triggers.
I have 4 Canon version AD360II lights that I purchased specifically to use with Sony A7RII and X1Ts trigger.
Never had a problem with TTL. When I moved to Fuji they work as well.
It’s been awhile since I’ve used them. Mostly AD200 these days.
584 views & 1 like for this thread
version 2.0 /
Latest registered member is mason.snipes
324 guests, 271 members online
