FORUMS Photo Sharing & Visual Enjoyment Wildlife
Thread started 15 May 2018 (Tuesday) 14:36
Camera Suggestion for Beginner going on South African Safari
jpat12
1 post
Joined May 2018
May 15, 2018 14:36 |  #1
Hi - I am looking for some advice on a camera to purchase to photograph large wildlife in South Africa. I have limited knowledge and experience in photography, and am looking for something that is relatively easy to operate/focus etc. My rough budget is $1,000 - $2,000 inclusive of all parts/lens etc. All suggestions and advice are welcome.
Thank you
Nogo
I could have been worse....
Gallery: 15 photos
Joined Dec 2013
Post edited 7 days ago by Nogo.
May 15, 2018 15:18 |  #2
For the amount you are willing to spend consider buying used.
Philip
Does the TF actually know about the soda cans and PVC pipe from 30 years ago?
wanyc
May 15, 2018 16:57 |  #3
If you want easy to use and are not that into photography then you are better off getting a superzoom/bridge camera. Where in South Africa are you going?
Ospi
Joined Jun 2005
Post edited 6 days ago by Ospi.
May 16, 2018 01:27 |  #4
I've done Kruger a few times, each time with different kit. My previous trip I only had a 70-200 with a 1.4extender and I really suffered on length for a lot of the shots. I now have a 150-600 sigma and for me it's ideal for the large open expanses that are very common at that park.
That being said, I think you'd be content the majority of the time with 400mm on a crop body so with your budget in mind my advice would be a 2nd hand 70D (~$500), a 2nd hand 70-200 f2.8 (non IS) (~$800), a Sigma 2x extender ($300) and possibly a 2nd hand 18-135mm or using the kit lens for shorter stuff which you should be able to get included in a 2nd hand 70D package. Throw in a spare battery and you'll probably be touching the $2000 mark.
The advantage to this setup is you'll get good range while still maintaining good performance and can remove the 2x tele if you need to drop back on reach and bathe in the glory of what is an inspiring lens which would serve you very well after this trip in whichever photography endeavours you take. The lack of IS shouldn't be a major issue as there is generally very good light the majority of the time. If it does get dark you can also run without the tele and have a very fast lens which will be as capable as any in lower light conditions.
Trips like these usually don't come often so if that's the case for you it's better to spend closer to your limit to ensure you are equipped with decent gear.
As mentioned above though, if you have no real intentions to do photography afterwards or it's not really a big interest then there's lots of cheaper and easier options.
Canon EOS 70D
Sigma 150-600mm f/5-6.3 Contemporary
157 views & 0 likes for this thread
Latest registered member is _strobe_
790 guests, 409 members online
