Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 10th of August 2003 (Sun)   #1
thomasb
Default Help!! Fractured/broken LCD screen.
Hello. Can anyone give me some advice on getting the LCD replaced or repaired?? I just bought the camrera in May, and I don't know when it happened, but there is a "crack" inside (horizontal) through the LCD. Bummer. It still takes pictures, but I can't see anything, and it does not respond to the control buttons. Should I send it to Cannon? or find a local shop to replace/repair it? as it is very unlikely to be covered on the 'warranty'? And if anyone has experience with this, (and I see it's been a topic before), how much did it cost
Thanks for any and all help.
Sincerely,
tfb
slc, ut
thomasb is offline   Reply With Quote
Old 11th of August 2003 (Mon)   #2
stopbath
Default Re: Help!! Fractured/broken LCD screen.
It is likely that the camera got squished which broke the LCD cover, and possibly caused a cut in a circuit board, or damaged some buttons.
Is the LCD partially or entirely black? If not then the LCD glass is still intact.
This *might* be repairable locally, but your likely best to send it to Canon itself. Often what happens is a local shop will send it to Canon (particularly with new technology cameras), and charge you a fee on top of Canons cost. Takes longer and costs more...
stopbath is offline   Reply With Quote
Old 7th of September 2003 (Sun)   #3
yngline
I found my Canon S40 LCD broken this evening. I bought the camera about 9-10 months back and it was working fine till now. I still can take the pictures but cannot operate controls . There seems like a small crack on the top but the lcd is not completely blank.
Can I ask how much did it cost and where did you get it fixed from?
Thanks in advance.
yngline is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Spot in lcd screen! Dust or in focusing screen? Kelv2888 Canon EOS Digital Cameras 8 25th of August 2009 (Tue) 19:53
lcd broken? screen not working... canonixusi7broken Small Compact Digitals by Canon 1 9th of April 2007 (Mon) 10:24
Broken screen on my G3 - help! ruksak Canon G-series Digital Cameras 5 16th of April 2006 (Sun) 21:04
Screen-Shade eliminate glare on LCD screen! trbrogan Canon G-series Digital Cameras 2 23rd of June 2003 (Mon) 14:12
