FORUMS Canon Cameras, Lenses & Accessories Small Compact Digitals by Canon
Thread started 26 Mar 2006 (Sunday) 08:49
Prev/next
Help .. Camera won't turn on
malteseluv
1 post
Mar 26, 2006 08:49 |  #1
I have a Canon Powershot S30. I have fully charged the battery, tried brand new batteries too but the camera won't turn on when I slide the front lens cover open. No matter what I have tried it will not turn on. Can anyone help me out?
avdlaan
Ontario, Canada
Mar 26, 2006 10:31 |  #2
Malteseluv,
I'm not sure what you've tried up to this point, but below is what Canon suggests to troubleshoot the issue. If none of the suggested causes helps resolve the issue, then I suggest you bring it in for repair.
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
Adrian
Canon Rebel EOS T1i | 18-55mm f/3.5-5.6 IS | 55-250mm f/4-5.6 IS
24,624 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00177 for 4 database queries.
PAGE COMPLETED IN 0.01s
893 guests, 409 members online
