Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 27th of March 2006 (Mon)   #1
long jetty
Default Skateboard Shots.
Hey, Could someone please edit these to make them look better? I'm not very skilled at editing and would like to see what someone can do with them.
Anyway, tell me what you think of these unedited shots.
long jetty is offline   Reply With Quote
Old 27th of March 2006 (Mon)   #2
SurfKahakai
SurfKahakai's Avatar
Default Re: Skateboard Shots.
What were you using for flash and what settings?
#1 has the best timing for the kickflip.
California Photographer
www.benquesinberry.com
SurfKahakai is offline   Reply With Quote
Old 27th of March 2006 (Mon)   #3
dshootist
dshootist's Avatar
Talking Re: Skateboard Shots.
i agree with surf... #1 and #2 have the best timing. i'd bump up the ISO a bit to get some more speed from your lens, though. also check ahead of time with a test shot of the area to make sure that you're not getting any glare/reflection from the background signage glass. you could also use an additional flash w/ a slave trigger to get more all-over lighting (and even more speed to boot!) maybe try from an angle a little ahead of the skater and shooting up some? if you're new to shooting skaters, practice some during the daylight hours to get the timing down and then go for the low-light shots. (of course, always be on the lookout for stray boards!) post some more when you get the chance!
dshootist is offline   Reply With Quote
Old 28th of March 2006 (Tue)   #4
long jetty
These were the settings:
Old 28th of March 2006 (Tue)   #5
corterlifecrisis
corterlifecrisis's Avatar
it's a start, i like how you shot these a lot! heres some advice. i'm by no means a pro and don't get to shoot a lot of riding, but these are tips i've picked up:
try a vertical composition with those. you got the right idea with getting low, but using vertical comp would get rid of some of the unneeded space. the most important things when shooting skateboarding/bmx are:
timing (which you have): some guys like to get the photo when the boards back under the skater's feet, and let the caption do the explaining. i like it when you can see the flip.
composition: you always want to be able to see 2 things in these kinds of photos (transworld skateboarding/ride bmx). you want to see the persons face (preferably lit up) and the obstacle they are riding. if it's a rail, you wanna see the whole rail. if it's a ramp, you wanna at least see the coping, preferably the whole ramp to the ground. if you notice most of the compositions are pretty wide to get in the surroundings, and keep the subject out of the middle!! (whick you have done)
lighting: dshootist and surf are right, use flash to pop the skater (even in daytime). i wouldn't suggest the onboard flash, using an external with a sync sord works well, then you can put other flashes on optical slaves. i've used up to 4 flashes when shooting.
for shooting bmx (which i do from time to time) i use vivitar 285's, the 283 and 285 are widely available for pretty cheap, i suggest em. look into radio slaves as well if you want to get serious.
you're off to a great start though. it's less about pp as it is initial setup and shooting, but keep working at it!
try www.skateboardphotography.com for more tips, it helped me out a lot.
"Doesn't mother nature make a war look silly?"
corterlifecrisis is offline   Reply With Quote
Old 28th of March 2006 (Tue)   #6
brivett
brivett's Avatar
My recipe
1000 ISO or higher - get fast shutter speed to freeze action and reasonable DOF
Manual mode
550EX or 580EX set to high speed sync
The aim, get ambient ligt, but fill with flash. this shot was taken under cover at MK bus station on Sunday. It or one of it's friends should be in an MK local paper tommorow.
I love the high speed sync... but I like your angles if you can get the light right...
Barry Rivett
http://www.studioflash.co.uk
http://www.hotshots.me.uk
Canon digital bodies, lenses, flashes.
Bowens Esprits and Monolites
Elinchrom Style and Classics
Interfit and Portaflash
brivett is offline   Reply With Quote
Old 28th of March 2006 (Tue)   #7
SurfKahakai
Hey, what camera are you shooting with?
Old 28th of March 2006 (Tue)   #8
dave h
First pic, the writing over the glass doorway, is that appropriate for the scateboarder?
dave h is offline   Reply With Quote
Old 28th of March 2006 (Tue)   #9
tbfoto
quick edit
tbfoto is offline   Reply With Quote
Old 28th of March 2006 (Tue)   #10
tbfoto
I really like the shots. I have shot skateboarding before and it can be tough.
Nice job on the timing!
Tom
Old 28th of March 2006 (Tue)   #11
rgaya
rgaya's Avatar
the biggest mistake that got me was the harsh shadows on the wall... you never want shadows.... never.. but goods shots and good idea to get low on the ground
Rodrigo Gaya rodrigo.gaya@gmail.com
The Michigan Daily - Associate Photo Editor
www.michigandaily.com
Portfolio:www.rodrigogaya.com
SportsShooter_Link:www.sportsshooter.com/members.html?id=6419
rgaya is offline   Reply With Quote
Old 28th of March 2006 (Tue)   #12
corterlifecrisis
hey brivet- what body are you shooting with? cause at a high iso you'd need crazy flash sync in most day shots, and i thought the highest canon goes is 1/500. since i only sync at 180/250 i have to stay at 100 so i don't blow things out. how do you do it? nice shot, by the way.
Old 29th of March 2006 (Wed)   #13
brivett
brivett's Avatar
Shooting with a 1DMkIIn, but could be a 10D or 20D to get same pictures no problem...
They will sync at 1/2000 with the high speed sync option.... selected on the speedlites...
Barry Rivett
Old 29th of March 2006 (Wed)   #14
dave h
1D Mk2 will sync at it's top shutter speed of 1/8000th in high speed flash mode.
It's range is drastically cut though
Old 29th of March 2006 (Wed)   #15
coryjohnson
and just remember....the High speed is not for stop action...just for fill...you have to get stop action with shutter speeds....high speed sync is not like a normal flash...it's a curtain-following burst of very very high speed pulses...hence the cut range
Cory Johnson: sportsshooter page
Summer Photo Editor, The Crimson White-- University of Alabama Student Newspaper
cw.ua.edu
Student Sports Photographer, University of Alabama Athletics
rolltide.com
coryjohnson is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
skateboard shots memkoty Sports 15 24th of November 2010 (Wed) 17:35
My Skateboard crayfish13 Still Life, B/W & Experimental 2 15th of June 2007 (Fri) 06:39
8 skateboard Ditch and park shots cronu Urban Life & Travel 12 27th of April 2007 (Fri) 00:08
Some skateboard shots SurfKahakai Sports 8 13th of August 2006 (Sun) 18:50
Skateboard Shots at Mile High Madness kenyc Sports 3 20th of September 2005 (Tue) 07:03
