Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 31st of March 2006 (Fri)   #1
EOSimages
EOSimages's Avatar
Cool Experimenting in Photoshop
I hope this is the place for this shot. I was experimenting with Photoshop on a train photograph that I posted in Transportation. I wanted it to look as though it was a sketch. What do you think? Thanks!
Bo.
Bo
Canon S5 IS / Canon i9900 Printer / Photoshop CS2
EOSimages is offline   Reply With Quote
Old 31st of March 2006 (Fri)   #2
Rockandgrohl4
Default Re: Experimenting in Photoshop
I like it a lot! There are so many things you can do with Photoshop it's almost rediculous. I think this makes it look like sketch for sure! Maybe try and have it black though? Great work!
Colby
Starting Block Photography
Check out some of my work! Comments welcomed!
http://startingblockphotography.blogspot.com
Rockandgrohl4 is offline   Reply With Quote
Old 31st of March 2006 (Fri)   #3
Photodawg1
Photodawg1's Avatar
Very nice...That would be an interesting thread...what's your favorite filter in cs2...mine is the polarizd...as if I didn't spend enough time looking at and playing with my pictures!
______________
http://www.lindasiadys.com
Photodawg1 is offline   Reply With Quote
Old 31st of March 2006 (Fri)   #4
AV Mode
AV Mode's Avatar
Good job,
I would also like to see it converted in B&W and with a little level tweaking.
AV Mode is offline   Reply With Quote
Old 31st of March 2006 (Fri)   #5
Dchemist
Hi Bo, Intersting image and result. Would you mind sharing your technique for doing this? Thanks, Dennis
POTN Book Vol4 Astronomy Image Manager and BC Member
20D, 5DMkII, 50F1.4, 100F2.8 macro, 135F2, 17-40F4, 70-200F2.8, 24-105F4, 580EX
Dchemist is offline   Reply With Quote
Old 31st of March 2006 (Fri)   #6
karusel
karusel's Avatar
Looks like you made it. Also joining the share-the-technique train.
Photodawg1: my favourite filter is USM. I almost exclusively use USM and gaussian blur from the filters section...
5D and holy trinity of primes. Now the 90mm TS-E TS-E fly bit me. I hate these forums.
karusel is offline   Reply With Quote
Old 31st of March 2006 (Fri)   #7
EOSimages
EOSimages's Avatar
Originally Posted by AV Mode
Good job,
I'm not sure I know how to do the B&W thing and the level tweaking....
I am real new at this digital stuff & I'm not even sure I can explain how I did this? I'll see if I can go back into it & find exactly what I did. Please feel free to tweak it & do whatever you like to the photo. It would be great to see other ideas.
Bo.
Bo
Old 31st of March 2006 (Fri)   #8
EOSimages
EOSimages's Avatar
OK, I managed to get it B&W but, I couldn't locate in my software anything that said leveling? Sorry. As I said, I am real NEW at this stuff!
Thanks, Bo.
Bo
Old 31st of March 2006 (Fri)   #9
EOSimages
EOSimages's Avatar
I think all I really did was place the photo in Photoshop & chose the charcoal filter & then lightened it up a bit?
Bo.
Bo
Old 31st of March 2006 (Fri)   #10
Double Negative
*sniffles*
Double Negative's Avatar
On that first picture, if you invert the colors (blue->white, white->blue) and crank up the contrast a notch... It'd look like an isometrically drawn blueprint or something. Very cool.
La Vida Leica!LitPixel Galleries -- 1v-HS/1d Mk IIn w/E-1 & Op/Tech straps
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Double Negative is offline   Reply With Quote
Old 31st of March 2006 (Fri)   #11
EOSimages
EOSimages's Avatar
That was the first thing I thought when I saw the first image!
Bo.
Bo
Old 31st of March 2006 (Fri)   #12
EOSimages
EOSimages's Avatar
How's this?
Bo.
Bo
Old 31st of March 2006 (Fri)   #13
Double Negative
*sniffles*
Doesn't quite seem to work with white on black as much. Out of the three, I'd still go with the first.
Old 31st of March 2006 (Fri)   #14
EOSimages
EOSimages's Avatar
Yeah, I couldn't get it to do the blue & white reversal thing?
Bo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Experimenting. Action_Man Macro 8 5th of July 2007 (Thu) 14:58
Experimenting..... what do you think? elise1030 Still Life, B/W & Experimental 13 11th of January 2007 (Thu) 19:27
Experimenting Action_Man Still Life, B/W & Experimental 7 18th of September 2006 (Mon) 23:40
experimenting 2 khennion Macro 3 22nd of November 2005 (Tue) 18:26
