FORUMS Canon Cameras, Lenses & Accessories Canon G-series Digital Cameras
Thread started 17 Aug 2003 (Sunday) 02:05
4x6 Costco Prints are cropped!
rkamlesh
Joined Jun 2003
Aug 17, 2003 02:05 |  #1
Hi,
I got 4x6 prints from Costco and the quality is good but all the pictures were cropped on width side. I understand that I'll have to crop the picture before I give for prints, but if I do that I loose some part of the frame and I might not be able to do this for all the pics.
What is the solution for this and which software can do it best?
I have Photoshop 5.0, LE that came with G3. All my pictures are Highest Resolution and Fine Compression.
While clicking the pics do I have to keep in mind to leave some extra space in the frame so that even it gets cropped the print will be okay.
Any help is appreciated.
Thanks.
Kams.
PacAce
Joined Feb 2003
Aug 17, 2003 08:54 |  #2
rkamlesh wrote:
Hi,
Thanks.
Kams.
I'm afraid that the G3 uses the old video standard aspect ratio of 4:3 so you're always going to lose some parts of your picture if you print in any other formats such as 4x6, 5x7, 8x10, 8x12, etc. The only print you'll be able to make without any unwanted cropping is a 3x4 or a 6x8 (or any others with a 4:3 ratio).
If you don't want the printers to arbitrarily crop your pictures to fit the format, you should edit the picture yourself and crop it to the correct aspect ratio for the print format you want before taking it to the printers.
...Leo
Calboy
Joined Sep 2003
Sep 30, 2003 11:35 |  #3
I had the same thing happen to me and almost all of the heads were cut off of my pictures. I am glad you posted this
Cal
freakboy
Joined Aug 2002
Sep 30, 2003 13:30 |  #4
how do you crop them to the correct aspect ratio? Is this just done by croping the image or do you have to change anything else?
freakboy
msvadi
Joined Jul 2003
Sep 30, 2003 14:43 |  #5
freakboy
There are many ways to do that. I use the crop tool in Photoshop with preset values 2272 x 1515 or 1515 x 2272 pixels. This way it's easy to choose what parts of the image should be cropped.
vatey
Joined Sep 2003
Sep 30, 2003 17:29 |  #6
to avoid this crop
use your edit photo software
first make a new format by select 8 inch X 12 inch
and DPI 213 per inch ,second open your photo and move it to install on a new format ,with this format (8x12 DPI 213 ) it can fix exactly with photo 2272 X1704 pixel
and save it for print at any Lab who print at 4x6 ratio
VATEY
civis
Joined Sep 2003
Sep 30, 2003 17:29 |  #7
JPEGCrops works pretty well (and it's free). Just do a search for:
JPEGCrops
msvadi
Joined Jul 2003
Sep 30, 2003 18:45 |  #8
vatey wrote:
to avoid this crop
VATEY
I'm not sure what you mean, because 2272 x 1704 image cannot fit EXACTLY into 3:2 ratio "frame". But yes, there is an alternative to cropping: increase the image width to 2556 pixels, for example, by adding white borders on the left and on the right of the original picture.
Man-Fai ­ Wong
Joined Sep 2003
Sep 30, 2003 19:38 |  #9
Go w/ Civis' suggestion of JPEGCrops here:
http://ekot.dk/program​mer/JPEGCrops/ (external link)
It's a fast, easy way to crop lots of JPEGs w/out losing quality due to recompression, if you don't need to do any touch up. If you use Photoshop (or most other standard image editors), they will probably recompress your JPEGs and lose some quality.
Another alternative, but less elegant, freeware cropper is JPEGCrop. You can find it here:
http://sylvana.net/jpe​gcrop/ (external link) (for original version)
http://www.enotes.de …n/view.pl/Notes​/JpegTools (external link) (for easier 4x6 cropping)
_Man_
WallyBeavis
Joined Mar 2003
Oct 21, 2003 15:32 |  #10
FYI:
I've noticed that sam's club does this too. For quickie/gotta have it now, prints I rotate my images 90 deg (laying them on their side), and the prints usually come out decent enough. Of course this only works for a few images, unless you want stand there are their kiosk for a few hours :-)
cheers,
Wally
Man-Fai ­ Wong
Joined Sep 2003
Oct 21, 2003 20:45 |  #11
Just reread and noticed this suggestion. It's a good way to go if you really don't want to crop, and you could also choose something other than white to suit the image (or eventual frame). For borderless prints, I'd go for something dark, eg. black or the dominant color around the outer parts of the image or that faded into black, but that would require a bit more work though.
Personally, I do often try to shoot for the wider 4x6 ratio because I often prefer the wider scope for my style (and would crop for wider compositions). To see what I mean, check out the new gallery I recently set up on PBase (finally!): http://www.pbase.com/m​andnwong (external link). Many images were shot for wider composition although a couple were not, but still ended up cropped that way.
_Man_
Elliott
Joined Jul 2003
Oct 26, 2003 06:09 |  #12
I have used a couple of web photo services to make some 4 X 6 prints of some of my digital photos taken with my G3. I noticed that Wal Mart cropped my photos slightly from top to bottom. Yes, I tried Wal~Mart's online digital photo processing against my better judgement, knowing how I have often disliked their quality of photo processing in the past. The photo print quality was "OK", but I didn't expect the crop, and don't remember seeing an option to adjust for it on their upload page. Now, I also uploaded a handful of digital photos to be processed into 4 X 6 prints by Shutterfly, and their upload screen has the option to adjust the crop of each photo that I uploaded. At least with Shutterfly I could be sure that what I wanted in the print was actually going to be in the print. No cutting off the tops of someone's head or that sort of thing. I don't know how many online photo processing sites offer the ability to make this kind of adjustment when you send them work, but I think it's a good thing if they do.
yallcome
Joined Jun 2003
Oct 28, 2003 00:00 |  #13
Here's a place that offers 4xD prints with paper cut to match the digital dimensions:
http://www.clubphoto.c​om/popups/what_is_4xd.​php (external link)
walkien
Joined Sep 2003
Oct 28, 2003 15:54 |  #14
Open PS7
1. Select "Crop" tool
2. In the "crop" tool option bar, enter the size (width and height) you like 6X4,4X5, 5x7.....etc
3. open a picture you like to crop.
4. Click within your photo with the crop tool and drag out a cropping border.
Hope this will help.
ps. You can also preset different sizes in the crop tool, so you don't have to change it all the time.
Canon 1D Mark II N, Canon 5D Mark II with grip, Canon 7D II with grip, Canon 10D with grip, broken Canon G2. 28-135 mm IS, 50 mm F1.8 II, 24-70 f2.8L, 70-200 f2.8L IS, 70-200 f4 L, 85 f1.8, 100 macro 2.8 IS
420 EX/580 EX/580EXII, 2 600 EX-RT, Bogen 3321 tripod
Sekonic L-358 Flash Meter, 2 Alien Bees b800, 60" umbrella, large octogon softboxes LightSphere II, Omnibounce. Tronix Explorer 1200, pocket wizard
Default9
Joined Jul 2003
Oct 28, 2003 16:46 |  #15
In photoshop, my way: select
>rectangular marquee tool.
>style: fixed aspect ratio. 2:3
>select the area you want to crop.
>image>crop
greetz.
10,534 views & 0 likes for this thread
version 2.0 /
Latest registered member is Nidge
705 guests, 390 members online
