Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 5th of April 2006 (Wed)   #1
Joe Cyr
Joe Cyr's Avatar
Default Battery lifespan
Hey guys, roughly how long does your charge last with one fully-charged battery? I have a couple of BP-511 batteries. One of them had been in the charger all day, I took it out and it lasted 10 minutes before completely shutting off. I have a second one that lasts longer, but am noticing it too is starting to drain quickly. Any thoughts? Suggestions? Are there better batteries to get other than the Canon one that comes with the camera? A camera grip with two batteries is really not a preferred option for me.
Thanks in advance.
Joe Cyr is offline   Reply With Quote
Old 5th of April 2006 (Wed)   #2
DMacIntyre
Default Re: Battery lifespan
Something is definitely wrong. I have a BP511A. I charged it for just over an hour. So far, I have taken well over 300 pictures (approx 100 w/flash) all with AF and Image Stabilization on and no word of a lie, the battery life indicator on the cam has not dropped a bar yet. If it's happening with both batteries suddenly, could the charger be toast?
Canon EOS 5D Mark II
Canon EOS 30D
(1) EF 24-70mm f/2.8L (2) EF 50mm f/1.8 (3) Sigma 70-200mm f/2.8 EX APO DG (4) Sigma 10-20mm f/4-5.6 EX (5) EF 135mm f/2.0L (6) Sigma 1.4x TC EX APO
DMacIntyre is offline   Reply With Quote
Old 5th of April 2006 (Wed)   #3
Zepher
Zepher's Avatar
3 years is the average life of Li-ion batteries. doesn't matter how many charges I believe, it's just that the chemical reaction inside starts to degrade as soon as they are manufactured.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶______________________________________
Zepher is offline   Reply With Quote
Old 5th of April 2006 (Wed)   #4
René Damkot
Moderator
René Damkot's Avatar
The batteries of my 10D were getting worse when I traded it in. Battery life was getting shorter. That was after 1 year (say, 20.000 exposures). Get some new batteries....
René Damkot is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #5
Joe Cyr
Joe Cyr's Avatar
Which brand do you guys reccommend, or more importantly not reccommend?
Old 7th of April 2006 (Fri)   #6
MagentaJoe
psycho clown
MagentaJoe's Avatar
Location: Having breakfast at the circus, with the lions and the clowns.
Lithium Ion batteries typically will give you 350-500 charge cycles. This can be lower or higher depending on conditions in which they are used and charged.
The charge cycle means fully discharged and then fully charged. So if you use 50% of the charge and then fully charge it that would be one half of a charge cycle. If you discharge the battery only 50% and then recharge fully every time you should be able to do this 700-1000 times before the battery is exhausted.
Lithium Ion batteries as, stated above, do have a sort of best before date but this depends on the temperature in which they are stored. Cooler is better and even in your freezer is good as long as you allow them to warm up before using them.
Arguing with a psycho clown can be harmful to your funny bone.
5D-Grip, 40D, 35f2, 50f1.4, 85f1.8,100f2.8macro, 135f2.8sf, 17-40f4L, 24-70f2.8L, 100-400f4.5-5.6isL, 580ex, 420ex, 430ex, 430ez
MagentaJoe is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #7
Zepher
Zepher's Avatar
I recommend the Sterlingtek batteries. I bought a pair for under $30 shipped.
Manny Desantos
Old 7th of April 2006 (Fri)   #8
mrclark321
Noinker
mrclark321's Avatar
I have taken over 600 photos since I got my 30D on March 24th and the camera still shows a full charge......WOW
Dan
A crap pile of various gear!
mrclark321 is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #9
foxbat
foxbat's Avatar
Your batteries are showing end-of-life symptoms, throw them away and buy some more. Canon don't make batteries, they badge cells made by someone else. I picked up some generic BP511's from an HK ebay seller and they last about 50% longer than the Canon-badged items that came with the camera.
Andy Brown; South-east England. Canon, Sigma, Leica, Zeiss all on Canon DSLRs. My Gallery. Gear here.
foxbat is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #10
Mowman
http://www.photography-on-the.net/fo...ad.php?t=79584
This is the link to the sticky in the accessories forum. I bought 6 (3 pairs) of sterlingtek batteries for my 20D for $67 dollars shipped. With no flash, I have taken 800-900 shots with battery left over. In addition, I am using the Canon charger to charge them.
Mowman is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #11
DMacIntyre
Dan
789 shots and counting....no battery bar loss!!!
Canon EOS 30D
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lifespan of my 300D..... embdude Canon EOS Digital Cameras 3 27th of March 2007 (Tue) 15:33
lifespan of BP-511A jonny_neptune Accessories & Storage 5 6th of February 2007 (Tue) 10:58
What's the average lifespan... tornerito Small Compact Digitals by Canon 7 24th of September 2006 (Sun) 16:07
BP-511 Lifespan? daniell Canon EOS Digital Cameras 13 18th of February 2005 (Fri) 06:14
G2 battery lifespan skynett Canon G-series Digital Cameras 0 13th of December 2002 (Fri) 22:12
