Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 6th of April 2006 (Thu)   #1
Ridezlow
Ridezlow's Avatar
Default What could I have done differently?
Took this from about 20 feet away. She was behind a fence and I was approx 5 feet from the fense. Is this a job for the Digital Darkroom or could I have done anything differently from behind the lense. This was my first shot of a live subject and at the time, all I had was my camera without and additional lenses.
__________
Mitch
Canon Rebel ATI (400D)
Ridezlow is offline   Reply With Quote
Old 6th of April 2006 (Thu)   #2
jbkalla
jbkalla's Avatar
Default Re: What could I have done differently?
Oh, crap. I forgot to ask if it's ok to edit your image!
Is it? If so, you can change the setting under User CP (control panel)
John
flickr | Google+ | 500px | Panoramio | InterfaceLift | deviantArt
Canon 5D III
| 16-35mm f/2.8L II | 70-200mm f/2.8L | 40mm f/28 STM | 300mm f/4L IS |  Core i7 iMac & MBP
jbkalla is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #3
Radtech1
Everlasting Gobstopper
Radtech1's Avatar
You could have helped yourself very much behind the lens. If it were me taking the shot, I would done a couple things:
1) I almost always shoot manual and RAW. This way multiple shots are always the same technique. If you shoot with an automatic exposure, successive shots will likely have different technique depending on the brightness of the item in front of the light meter.
2) For this shot, I would have selected a tighter aperture. This increases your depth of focus, which would have resulted in the fence being more in focus therefor less "smear" on the image.
3) I would have shot multiple shots from moving slightly up and down and side to side. Just an inch or two either direction would take care of it. These steps would have provided at least some workable material.
4) In photo-shop, I would have copied and pasted all the areas that do NOT have a fence into one shot. For example, in your shot, the fence runs through the area between the snout and mouth. If you had another shot taken from an inch below, that shot would have the fence covering the cat's eyes. You could copy and paste the snout/mouth are from that shot into the one here.
5) Yes, all this assumes the animal stays still. With practice, you can fire of 4+ shots in a quick second or two.
6) I have done this with great results on countless shots that were obscured by fences, posts, wires, and all types of obscuring items.
Rad
"I long to accomplish a great and noble task, but it is my chief duty to accomplish small tasks as if they were great and noble." – Helen Keller
Radtech1 is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #4
Titus213
Titus213's Avatar
I would probably have moved up closer to the fence and positioned the wire outside the image I really wanted. What is that thing anyway?
Dave
Perspiring photographer.
Titus213 is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #5
Ridezlow
Ridezlow's Avatar
Sorry John, it's been changed. Thanks for the advise guys. I'm not sure what it is. It was on the fense but I forgot to use my recording feature to make a note of it? Oops
__________
Mitch
Old 7th of April 2006 (Fri)   #6
jbkalla
jbkalla's Avatar
Yeah. I originally put that post up after an edited pic, but I deleted the edit post, cuz I didn't want to overstep and the edit didn't turn out very well anyway.
John
Canon 5D III
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Help! What would you have done differently? lvthebroncos Critique Corner 7 15th of February 2007 (Thu) 10:59
What would you do differently? SaharaWizard Critique Corner 3 5th of November 2006 (Sun) 07:26
What Could I Do Differently? am_pitbull_terrier Weddings and Other Family Events 10 13th of July 2006 (Thu) 21:36
Ok what can I do differently? ladybelle2k Critique Corner 11 7th of September 2005 (Wed) 18:38
What would you have done differently (Final) who10 Critique Corner 8 4th of September 2004 (Sat) 11:37
