Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The Business of Photography
Reply
Thread Tools Display Modes
Old 7th of April 2006 (Fri)   #1
sugazo
sugazo's Avatar
Default concert photography
so there is going to be a free concert held outdoors on my campus this saturday, and id like to get some shots in. problem is, ive never done a concert before--but from what i gather, i need to shoot high iso, no flash, and shoot wide open. ill definately bring my 80-200 and 50, should i bring my 24 as well? it seems to me that 24 might be too wide since i probably wont be able to get extremely close.
in the past, all my handheld nightshots at iso 1600 have been sub-par. i could get decent results, but just could not bear the noise at that iso... any suggestions? iso 800 whenever possible?
also, should i shoot in M or Av? i've read that i probably wont want to shoot at 1.4, since DoF is too shallow. should i set myself at around 2.8 and hunt till the lighting allows me to shoot at 1/60-125, or just set it in manual?
and if you guys were wondering... pepper and slightly stoopid are playing, and the headlining band is surprise . thanks for your support guys.
in the bag:
1D | 1V
EF 24 f/1.4
, 50 f/1.4, EX 70-200 f/2.8 DG
430EX, sunpak 544, vivitar 285hv
sugazo is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #2
SuzyView
Ms Moderator and Grandma
SuzyView's Avatar
Default Re: concert photography
Depending on where you are sitting, don't bring it. You don't want a lot of equipment at a concert. I find that I am always looking through the viewfinder and not enjoying the concert. No flash is a killer, but you can experiment. Do both manual and Av. I usually take around 40-50 shots and then enjoy the concert. If you have a monopod, that is not intrusive. I put the monopod in front of me between my knees for support and then I shoot away. Make sure they allow it, but my monopod just looks like a short stick. If you can't bring that in, just brace yourself well. I assume you're either on the ground or in a lawn chair. Good luck. It's always fun to be at college and watch a concert with your friends for free.
5D2 7D & G12, the new iPad, iPhone 5 , 5 L's & 2 Primes 23 bags - 4 Domke, 3 Lowepro, 1 Crumpler, 2 Tamrac, 5 Kata, 3 Thinktanks, 1 Pelican, 1 Tenba bag, 1 Epiphanie Paris & 2 Coach Handbag! And no excuses.
My children are the reason, but it's the passion that drives me to get the perfect image of everything.
My Gear and Wishes
SuzyView is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #3
rlhphotos
rlhphotos's Avatar
Id probably just use the 50 unless they have really bright stage lights...of course thats if you can close enough to only use the 50..last concert I covered had plenty of stage lights and I could use whatever I want.
:: Call Me Rob ::
::Equipment List::
::Business Site :: Blog Site::
rlhphotos is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #4
Screamer
Screamer's Avatar
Are you just shooting for fun? Is the concert during the day or at night?
- Phil
Canon 1-Series Bodies, 5Dmk3 (for cinema), & XF305| L Glass & Zeiss Primes| Some lighting stuff from Sweden
|http://www.philmacino.com
Screamer is offline   Reply With Quote
Old 7th of April 2006 (Fri)   #5
sugazo
sugazo's Avatar
yeah, just for fun. theyre setting up the stage today, and looks like theres a big frame with lots of lights on it. and it looks like everyone will be standing or sitting on the grass. dont have a monopod... but i dont think space will be too much of a problem because the grassy area is the size of at least two football fields
so i guess ill just bring the 80-200, and put the 50 in my pocket, no flash. if anything i can just walk back to my dorm to get the 24 or flash, because its literally one minute away. i read on photo.net to set Tv to around 1/125 and just switch to that when lighting is good and consistent.
concert starts at 730pm, till whenever. idk if there will still be daylight, because lately it stays bright untill around 730, and then all of a sudden everything is pitch black by 8.
in the bag:
1D | 1V
EF 24 f/1.4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
New to concert photography Toogy Performing Arts 14 12th of February 2007 (Mon) 17:19
Concert Photography jkdphoto The Business of Photography 8 24th of September 2006 (Sun) 01:27
Concert Photography cargo123 Canon EOS Digital Cameras 22 9th of March 2005 (Wed) 04:20
Concert photography rockstar72 Canon EOS Digital Cameras 12 24th of July 2003 (Thu) 11:31
Concert photography? Griffin General Photography Talk 0 3rd of March 2002 (Sun) 20:35
