#1 |
I have just purchased a Manfrotto 322RC2 Grip action Ball Head. On releasing the ball, tilting forward and back is stiff and jerky at first. Once the initial stiffness is overcome movement is free. This happens each time the ball is released. Is this a fault or are all such heads the same?
Canon 20D Canon, EFS 17-85 IS USM Canon EF 100-300 4.5-5.6 Canon EF 100mm f 2.8 Macro USM Manfrotto 055MF4 tripod, Manfrotto 701RC2 Head Manfrotto 322RC2 Head, Canon Speedlite 550EX Last edited by Jonathan19610 : 9th of April 2006 (Sun) at 16:08. |
| sponsored links |
#2 |
Sliced Bread
Mine also seemed that way at first. After adjusting the tension it is better. I haven't used mine that much but I think you have "to break it in".
Canon 1D MKIV, 5D MKII, 16-35/2.8L II, 24-105/4L, 70-200/2.8L IS II, IS, 500/4 L IS II, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, & 2X MKIII, (2) 550EXs, ST-E2. Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880 |
#3 |
You need to adjust the tension, my friend has one.
| sponsored links |
#4 |
Thanks for the replies. I have adjusted the tension wheel down to the lightest setting and it is much improved. I think I will keep it now.
Canon 20D Canon, EFS 17-85 IS USM Canon EF 100-300 4.5-5.6 Canon EF 100mm f 2.8 Macro USM Manfrotto 055MF4 tripod, Manfrotto 701RC2 Head Manfrotto 322RC2 Head, Canon Speedlite 550EX |
#5 |
I had the same problem with mine. I finally sent it to Manfrotto via my dealer and in 2 weeks they sent me a new one that works great. Seems the 1st one was bad internally all along and just kept getting worse. Send it in !!
"If you're not living on the edge. You're taking up too much room !" My Gear Arizona's POTN Flickr Gallery |
| Thread Tools | |
| Display Modes | |
| Manfrotto 322RC2 Grip Action Ball Head | Jaime | Classifieds: Buy | 0 | 2nd of April 2007 (Mon) 19:04 |
| Grip Action Ball Head | Roy C | Accessories & Storage | 5 | 6th of July 2006 (Thu) 22:19 |
| Grip action ball head | Mitcon | Accessories & Storage | 7 | 20th of June 2005 (Mon) 03:19 |
| Manfrotto: cool GRIP ACTION BALL HEAD... | pn.md | General Photography Talk | 8 | 9th of April 2004 (Fri) 13:56 |
