Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 10th of April 2006 (Mon)   #1
Keiffer
Keiffer's Avatar
Default What focus points do you use
Hey guys, I was just curious do most of you use the 9 points or just primarily the center focus point. I have always used the center on my D60(it only had 3) and I still only use the center on the 30D because I'm concerned that AF will lock on something other that what I'm shooting for. If you use more than the center...why and under what circumstances? Thanks
http://kcschoeppler.fotopic.net
Keiffer is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #2
Tsmith
Formerly known as Bluedog_XT
Tsmith's Avatar
Default Re: What focus points do you use
Mine stays set on Center Point 99% of the time. Lock and recompose if necessary.
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS
Canon PowerShot S95
MY PBASE GALLERY
Tsmith is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #3
reewik
reewik's Avatar
I use all 45 points myself. In a pinck I will use only one point. When I had my 300D I used center also most of the time.
Eric: www.avianart.net
Canon 1D MKIII, 600 f4 IS, 85 1.2L
Canon 1D (Classic),50 2.5 Macro, 1x lifesize
reewik is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #4
Rumjungle
Rumjungle's Avatar
It depends on where I want to place my subject in the frame. If it benefits the overall composition to place my subject in the lower left, then I'll choose a focus point in the lower left.
Gear
Rumjungle is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #5
85lesabre
85lesabre's Avatar
it really depends....sometimes i use all 45 and then sometimes i use the center.
85lesabre is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #6
Jaymz
Ex-Lax_lacks
Jaymz's Avatar
I use the center point almost all the time, recompose as needed.
☣ Thats very "Rockwellian"
PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS OR SENDING PAYPAL GIFT IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED.
Jaymz is online now   Reply With Quote
Old 10th of April 2006 (Mon)   #7
Keiffer
Keiffer's Avatar
It depends on what? Can you please be more specific. Than again you guys are using the 1D, don't know if that matters compered to the 20/30D.
Old 10th of April 2006 (Mon)   #8
Jim_T
Jim_T's Avatar
I only use the center point 99% of the time. I don't find it difficult to lock the focus and exposure then quickly shift the camera to get the ideal framing.
I find this reduces the number of shots where the subject winds up out of focus because with one point, you KNOW where the camera is focusing.
Jim_T is online now   Reply With Quote
Old 10th of April 2006 (Mon)   #9
Mitcon
Mitcon's Avatar
I only ever use one active AF point at a time, 80% the center..really just depends on the situation.
Cheers Wayne
EOS 30D+350Dx2+BG-E2+BG-E3+18-55MkII+EF 70-300IS/USM+EF 75-300IIusm+Sigma 50-500DG+Tamron SP90 f2.8Di+Sigma 17-70+Kenco MC7 2x+580EX+430EX
POTN Aussie club
Feel free to visit my image galleries
www.mitconphotographics.com
Mitcon is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #10
Hermeto
Hermeto's Avatar
I use Haoda focusing screen and center point almost all the time..
For moving targets I feel just the same as Jim_T - focusing is much easier when you know exactly where you are.
Hermeto is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #11
mbze430
mbze430's Avatar
you mean there is more than ONE??!?! What non-sense!
My Hub to my personal work (just click on the banners)
mbze430 is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #12
denMAR
denMAR's Avatar
I will focus and recompose but sometimes I'm afraid that it will lead pictures that could be sharper. It has happened before so I try to select the AF points as much as I can.
366 iPhoneography Project: www.denmarblog.com
denMAR is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #13
tripletaker
20D: I use one point most of the time as well. I find if set on automatic, the focus is off 50% of the time.
tripletaker is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #14
4walls
4walls's Avatar
Right down the middle for me --- i.e. center 99% of the time.
4walls is offline   Reply With Quote
Old 10th of April 2006 (Mon)   #15
Raj
Raj's Avatar
Centre point of the time, but switch to others if centre point is asking for focus & recompose for a lot of shots repetedly in the same orientation....
1DX, 5D, 20D with BG E2, Sigma EX DG 8mm F3.5 Circular Fish Eye, EF 15 mm f2.8 fish eye, EFS 10-22 mm f3.5-4.5, EF 24-70 F2.8 L mark ii, EF 24-105 f4 L IS, EF 16-35 f2.8 L , Sigma 35mm f1.4 A, 50 f1.8 mkII, 50 mm F1.2 L, EF f85mm 1.8, EF 100 f2.8 macro, EF 135 F2 L, Sigma 70-200 f2.8 EX HSM, EF 70-200 f2.8 L, IS USM mark ii, EF 100-400 f4.5-5.6 L IS, Sigma 18-125 f3.5-5.6 DC, APO 1.4x, G3, Cheapy Velbon Sherpa 435, Slick Carbon Fiber, Speedlite 430EX and 580EX with stofen OM-EW
Raj is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1D MK II N - focus points? dawnrogers Canon EOS Digital Cameras 4 19th of March 2007 (Mon) 08:31
focus points britt777 Canon EOS Digital Cameras 4 14th of August 2006 (Mon) 11:54
Focus Points jtmorales The Business of Photography 4 12th of April 2006 (Wed) 17:54
Focus Points ! Marshy Canon EOS Digital Cameras 10 10th of April 2005 (Sun) 19:14
Focus Points ! Marshy Canon EOS Digital Cameras 5 4th of April 2005 (Mon) 16:38
