Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Photography Industry News > Rumors > Lens Rumors and Predictions
Reply
Thread Tools Display Modes
Old 13th of April 2006 (Thu)   #1
Double Negative
*sniffles*
Double Negative's Avatar
Default 200-400mm f/4.0 & 500mm f/2.8 DO IS USM?
While doing some research into the long-end of things, I came across a mention (or leak, rather) from back in December of 2001... About two lenses Canon was developing. The 200-400mm f/4.0 DO IS USM & 500mm f/2.8 DO IS USM.
So here we are, some five plus years later... Whazzup? Any more rumblings?
The original info can be seen here: http://www.pitkajarvi.net/dolenses.htm
If Canon came out with that 200-400mm, I'd be on it like stink on poo. Right now I'm looking at either the 100-400mm f/4.5-5.6L IS or 300mm f/4L.
La Vida Leica!LitPixel Galleries -- 1v-HS/1d Mk IIn w/E-1 & Op/Tech straps
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Double Negative is offline   Reply With Quote
Old 13th of April 2006 (Thu)   #2
CyberDyneSystems
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
CyberDyneSystems's Avatar
Default Re: 200-400mm f/4.0 & 500mm f/2.8 DO IS USM?
It's just a rumor,. that proved to be wrong.. lots of those happen.
FYI A 500mm f/2.8 would be nearly as large as the 1200mm f/5.6 which costs about $100,000.00 ... (give or take 10K yes those zeros mean one hundred thousand dollars.)
SO I don't imagine a very long line at the register for that item.
The 200-400mm f/4 is an awesome idea that Nikon has succesfully feilded (with "VR" ) and it's a peach. Please don't confuse this with a portable hand held lens like the 100-400mm,. it's about the same size as a 500mm 4.5 prime.
CyberDyneSystems is offline   Reply With Quote
Old 13th of April 2006 (Thu)   #3
CyberDyneSystems
I beg your pardon,. did not check link,. did not realize "DO" was involved,.
This makes weights more plauseable.. but I've still never heard these rumors.
Canon needs to do a LOT of work with DO before it's ready for prime time.
Old 13th of April 2006 (Thu)   #4
Double Negative
*sniffles*
Oh, I know about the 1200mm, heh. SI has a couple of the very, very few in circulation. Quite impressive, that one.
DO would cut down on the size and weight a lot... But like you, I'm not totally convinced on the DO technology. That "leak" was from when the 400mm DO came out... Canon may have been more gung-ho about DO back then - because no others have come out since.
I'm mostly leaning towards the ol' standby 100-400mm... But it's not terribly bright and lacks weathersealing. This wouldn't stop me, but one can dream, right? It's either that or the 300mm f/4.0L.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
400mm & 500mm Choices grinchy Canon EF and EF-S Lenses 17 5th of March 2007 (Mon) 17:20
Sigma 80-400mm OS & Tamron 200-500mm fWord Canon EF and EF-S Lenses 28 10th of December 2006 (Sun) 21:58
Canon EF 100-400mm f/4.5-5.6L IS USm, sigma 50-500mm orTamron 200-500mm f/5-6.3 Di LD yagobrf29 Canon EF and EF-S Lenses 8 19th of March 2006 (Sun) 11:32
Canon EF 100-400mm f/4.5-5.6L IS USm vs sigma 50-500mm yagobrf29 Canon EF and EF-S Lenses 7 16th of March 2006 (Thu) 21:43
Why are there no 200-400mm or 200-500mm lenses? EricKonieczny Canon EF and EF-S Lenses 7 21st of May 2005 (Sat) 16:02
