Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 16th of April 2006 (Sun)   #1
viodea
Default How do you crop without losing quality
Everytime I try to save a cropped image, it as me to select the compression ratio. I assum this will do the Jepg compress again which may effect the image quality. I want to crop this for print and want to keep it as good as possible.
I'm still a little confused on using Photoshop Element 3.
I know how to select the crop ratio, 6x4, 7x5, and so.
What do I do with the Resolution? I click the front image button and thought that would give me the resolution of my original image but it shows 72 pixels/inch. This look too low. Does it mean it's view on the monitor and that's the resolution I'm seeing?
How can I save a cropped image without the exra compression?
thanks
viodea is offline   Reply With Quote
Old 16th of April 2006 (Sun)   #2
jbkalla
jbkalla's Avatar
Default Re: How do you crop without losing quality
I never got used to the crop feature for the reason that I was unsure what it was doing to my resolution, so I always crop using the Rectangular Marquee tool, set to a 7x5 or 6x4 or whatever aspect ratio. That doesn't change the resolution.
Maybe someone else will have the more correct way to do this!
John
flickr | Google+ | 500px | Panoramio | InterfaceLift | deviantArt
Canon 5D III
| 16-35mm f/2.8L II | 70-200mm f/2.8L | 40mm f/28 STM | 300mm f/4L IS |  Core i7 iMac & MBP
jbkalla is offline   Reply With Quote
Old 16th of April 2006 (Sun)   #3
hemuni
hemuni's Avatar
If you want to use the crop tool just leave the resolution field empty, this will crop retaining original resolution.
If you want to save the image without loosing information you have to use a lossless format like PSD or TIFF.
Every time you save to jpeg the image will loose information, but if you leave the compression ratio at 10 the loss will be insignificant.
((¯`•.¸hemuni¸.•´¯)) 1000D • 85F1.8 • 50F1.4 • 28F2.8 • 18-55IS • YN565EX - POTN gallery
hemuni is offline   Reply With Quote
Old 16th of April 2006 (Sun)   #4
jbkalla
jbkalla's Avatar
So here's a question: What does setting jpg compression quality at 12 do? Does it add information to the original jpg? I assume the 10 setting is the normal-highest setting in other programs?
John
Canon 5D III
Old 16th of April 2006 (Sun)   #5
hemuni
hemuni's Avatar
Originally Posted by jbkalla
So here's a question: What does setting jpg compression quality at 12 do? Does it add information to the original jpeg? I assume the 10 setting is the normal-highest setting in other programs?
In photoshops help it says that for printing the best choice is maximum which is 10.
The option to go to 12 I'm not sure about, other that it almost doubles the size of the image file.
I personally cannot see any difference between 10 and 12 so i use 10.
Old 16th of April 2006 (Sun)   #6
viodea
great help!!! thanks
Old 17th of April 2006 (Mon)   #7
ScottE
If I was going to save, re-open and do some more work and save again several times I would switch to TIFF or some other lossless file format instead of JPEG.
ScottE is offline   Reply With Quote
Old 17th of April 2006 (Mon)   #8
DocFrankenstein
DocFrankenstein's Avatar
Shoot raw from the beginning. ACRAW allows you to crop without even resaving the file.
I have typed this from Ubuntu.
Vent: One lens, two lenses. Advice=what you seek; advise=what we do. Then="at that time" or "subsequently"; than="compared to". Aperture, not aperature. Their="owned by them"; there="at that place"; they're="they are". Its="owned by it"; it's="it is". Your="owned by you"; you're="you are"; ur="primitive".
DocFrankenstein is offline   Reply With Quote
Old 17th of April 2006 (Mon)   #9
viodea
RAW sounds a little to complicated to me. I don't want to post process everytime. Like the weekend shooting I've done for a soccer game, I took over 800 pics and I don't want to postprocess all those to just filter out those that I don't want.
Old 17th of April 2006 (Mon)   #10
hemuni
hemuni's Avatar
RAW means more work but it also means better images. It all depends what you want from your photography i guess.
I normally filter out the keepers using Zoombrowsers star rating and delete those i dont want and move those that im unsure of to a subfolder.
After that i do the pp work in DPP and only on the keepers.
You can choose to shoot RAW+JPEG this way you have both.
Old 17th of April 2006 (Mon)   #11
viodea
Maybe I need to play with RAW for a little and than decide where I want to draw the line between quality and convenience.
Old 17th of April 2006 (Mon)   #12
BillMarks
Most older computer screens have a resolution of 72 pixels per inch (ppi). I think now many are 96ppi. If you are only going to post the images on the net or send through email, using a resolution of 72 or 96 when you crop is fine. If you want to print your images, set ppi to somewhere between 200 and 300. I've printed very nice 11"x14" prints at slightly less than 200ppi--from a 5MP camera.
BillMarks is offline   Reply With Quote
Old 17th of April 2006 (Mon)   #13
jfrancho
jfrancho's Avatar
Since monitor resolution is variable, for the web, I crop and resize to pixel dimensions, not resolution. For printing I follow each print services recommendations for resize/ppi.
jfrancho is offline   Reply With Quote
Old 17th of April 2006 (Mon)   #14
Longwatcher
obsolete as of this post
Longwatcher's Avatar
a couple of notes:
1. PS has 12 levels of compression, most over programs have 10. 12 in PS equals 10 in other programs. In PS 10, 11 and 12 all say maximum.
2. I tend to use canvas size to get the desired crop without changing pixel values (or use trim in DPP).
3. As mentioned anytime you save a jpeg you lose some information, more with more compression (lower numbers in PS)
4. I highly recommend shooting in RAW unless there is a compelling reason to shoot in jpeg (such as card space or critical time needs). It takes very little extra time to see the results in DPP or even PS Bridge and then only convert the ones you want to keep. And it is way easier to correct exposure and white balance from a raw shot.
Just my opinion and experience,
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher.com/photoequipment.htm
Longwatcher is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Irvanview: How Save w/o Losing Quality? TomPhotog RAW, Post Processing and Printing 4 1st of May 2007 (Tue) 21:07
Losing Quality Editing JeremyLangford RAW, Post Processing and Printing 1 26th of April 2007 (Thu) 22:37
resizing without losing quality SaharaWizard RAW, Post Processing and Printing 25 20th of March 2007 (Tue) 11:39
Picture losing it's quality. HELP! hopkins RAW, Post Processing and Printing 3 26th of September 2006 (Tue) 17:24
The 1.6 crop factor and image quality curiousgeorge Canon EOS Digital Cameras 10 7th of May 2006 (Sun) 08:13
