Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 19th of April 2006 (Wed)   #1
LarrySilva
Default 580ex challenges
Im have the 580 ex with my 20d and for the life of me I cant get good exposures. I have it on ttl, manual etc... Ive tried everything and it just wont give me consistent exposure. PLEASE HELP!!!! What am I doing wrong.
LarrySilva is offline   Reply With Quote
Old 19th of April 2006 (Wed)   #2
jngo
Default Re: 580ex challenges
wow. that's a tuff question with numerous answers. it all depends on the situation. could you give some examples? pics, if you have them would be even better. i've had my 580 for about half a year now and still struggle with it at times. practice, practice and more practice.
jngo is offline   Reply With Quote
Old 19th of April 2006 (Wed)   #3
dengli
dengli's Avatar
Keep a lookout for bright or reflective objects in the frame. They really throw off ETTL as exposure takes these into account.
Dave
1DMkIII, some lenses, grey hair and a beard
dengli is offline   Reply With Quote
Old 19th of April 2006 (Wed)   #4
chris clements
chris clements's Avatar
Can't help unless you're more specific; post examples.
You've had the flash on various settings - but what about the camera?
You'll generally get better (and certainly more consistent) results with the camera on 'm' and just the flash on auto.
chris clements is offline   Reply With Quote
Old 19th of April 2006 (Wed)   #5
MDJAK
...the definition of a noob
MDJAK's Avatar
I don't disagree with that, but I have to wonder why. Why does the camera give better results on "m" when using the flash?
MDJAK is offline   Reply With Quote
Old 19th of April 2006 (Wed)   #6
Curtis N
Master Flasher
Curtis N's Avatar
Because you can control the DOF with the aperture, and control the amount of ambient light with the shutter speed.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 19th of April 2006 (Wed)   #7
René Damkot
Moderator
René Damkot's Avatar
You can do the same in Av with EC
Only difference is: In M the flash is considered main light IIRC, and NEVEC doesn't come in to play.
René Damkot is offline   Reply With Quote
Old 19th of April 2006 (Wed)   #8
Curtis N
Master Flasher
Curtis N's Avatar
Originally Posted by René Damkot
You can do the same in Av with EC.
It would take a heluva lot of EC to get your shutter speed to 1/250 at f/11 indoors.
Old 19th of April 2006 (Wed)   #9
René Damkot
Moderator
Aahh, but you were talking about 'controlling the amount of ambient light', not totally ignoring it
Old 20th of April 2006 (Thu)   #10
togger
I have tried my 580 EX both with a D20 and D30. I find ETTL unusable when the 580 is the main light source.
It apparently is a distance based fill in depending upon available light.
If it consistently underexposed it wouldn't be as bad, but it also varies with your ISO setting (which I guess is part of the available light calculation)
Canon try and explain their logic at:
http://photoworkshop.com/canon/
Worse of all if you set your flash to Manual and turn the dial past the green rectangle it sets the flash to ETTL automatically and doesn't put if back again when you return to your original setting.
5D & Grip, 30D; 24-105L, 50 F1.4, 10-22, 17-85, 28-135, 580EX.
Bowens Monolites.
Film Junk; Pentax 67; 45, 105, 165. Canon 300, A1 & Lenses
togger is offline   Reply With Quote
Old 20th of April 2006 (Thu)   #11
togger
To use Manual flash press the button in the middle of the dial on the flashgun and adjust the power using the dial. Or adjust the aperture on the camera.
Best to have the camera set to manual as well, but don't go over the sync speed.
Bowens Monolites.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
The Challenges of Glamour Photography OviV The Business of Photography 20 19th of July 2007 (Thu) 19:48
Skin color challenges HELP CatchingUp RAW, Post Processing and Printing 11 16th of June 2007 (Sat) 23:31
Why don't WE have speed challenges? august23 Competitions 11 13th of March 2007 (Tue) 15:22
Canon pBase Challenges. ccheever General Photography Talk 0 6th of September 2006 (Wed) 23:00
Pekka/Challenges Conk General Photography Talk 3 16th of February 2003 (Sun) 21:40
