Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 30th of August 2003 (Sat)   #1
Retiredtrader
Default Canon 500D 67mm
I have a Canon 70-200 F/4L Canon lens and want to use the Canon 500D on the lens. It's a 67 mm lens. The Canon lens site says they make them. Has anyone found a store that carries them yet? If so, where? Many thanks.
Retiredtrader is offline   Reply With Quote
Old 30th of August 2003 (Sat)   #2
CyberDyneSystems
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
CyberDyneSystems's Avatar
Default Re: Canon 500D 67mm
500D?
Are we talking about a camera?
There is a 300D or "Digitsal Rebel" that will be on the shelves soon,. ( I don't think that it is really available yet)
But you mention 67mm twice?
So I don't see the connection to the Digital Rebel there,...
Could you clarify what product you are referring to?
CyberDyneSystems is offline   Reply With Quote
Old 31st of August 2003 (Sun)   #3
Retiredtrader
I don't see where I said anything about 67mm twice. However, the lens is 67mm. Canon makes a close-up lens attachment called either 250/500 D which in effect provides a shorter minimum focusing distance with no loss of light.
According to Canon's website they make them in 52mm, 58mm, 67mm, 72mm and 77mm. I can't find the 67mm at any websites.
Old 31st of August 2003 (Sun)   #4
toddb
toddb's Avatar
I got my 500D at B&H
Do a search for "500D Close-up Lens".
I don't see one for 67mm, maybe you can get a step ring for the 72mm (that's the one I have). I've ordered the cheep 50mm f/1.8 and it's threads are 52mm. I got a 52mm-72mm step ring so I can use my other 72mm filters on it. I'll try my 72mm 500D close up on it when I get it.
10D, EF17-40L, EF50F1.4, EF28-135IS, 550EX [AlienBees 2xB800 and 1xB400 with large softbox and reversible umbrella] Sekonic L-358
toddb is offline   Reply With Quote
Old 31st of August 2003 (Sun)   #5
Sketcher
I've searched for the 67mm version for my 70-200 just as you did. I contacted Canon and they apologized for the mis-information and recommended I choose a different filter size and use stepping rings to accomodate. I haven't yet decided on which combination of 500D filter size and stepping rings to settle on.
Currently intend to use with 500D:
70-200 f4L (67mm)
Tamron 24-135 (72mm)
Planned:
28-135 IS USM (72mm)
100-400 f4L (77mm)
*Would using a 72mm 500D restrict FOV on a 77MM thread size lense?
**Are there any issues with using a 77mm 500D on my 67mm thread size 70-200?
Any thoughts or questions on the matter?
It is what it is...
Sketcher is offline   Reply With Quote
Old 3rd of September 2003 (Wed)   #6
Sketcher
Bump - for the view.
Retiredtrader, What did you decide for your setup? Still looking?
Thanks!
-Skethcer
It is what it is...
Old 3rd of September 2003 (Wed)   #7
Retiredtrader
For Sketcher and others. Thanks for the comments. I decided to buy an Adorama step-up-ring 67mm - 72mm and the 500D at 72mm. I haven't received them in the mail yet. When I get them, I'll shoot some pics and see how they work together. I'll have to look up how to post some pics here and then post for you to see.
Adorama was the only place I found a 67mm - 72mm step-up-ring. Anybody know of others, as I don't know the quality of the ring yet. How good can it be for $7.95?
Old 4th of September 2003 (Thu)   #8
cowman345
So what is the 500D? It seems like a diopter, but what would be the equivalent in other brands (i.e. +1, +2, +4??)
-dave
cowman345 is offline   Reply With Quote
Old 4th of September 2003 (Thu)   #9
Retiredtrader
Dave
I think the Nikon 5T and 6T are Nikon equivalents.
Old 4th of September 2003 (Thu)   #10
DonCoon
Default Re: Re: Canon 500D 67mm
-dave
500D = +2 250D = +4
As in: 1000/2 = 500, 1000/4=250
DonCoon is offline   Reply With Quote
Old 4th of September 2003 (Thu)   #11
Retiredtrader
The 250D and 500D are close up attachments used with an EF lense to provide a shorter minimum distance with no loss of light. The 250D/500D series incorporates double-element achromatic design for maximum optical performance while the 500 (no 'D') series features single-element construction for maximum economy. The 250D is optimized for lenses between 50-135mm, while the 500D works best with telephoto lense from 70-300 mm. Manual focusing is recommended.
Think of them as dual element diopters.
Michael
Old 5th of September 2003 (Fri)   #12
toddb
toddb's Avatar
I just got my new $65 50mm f/1.8 and it's got 52mm threads. My 72mm 500D works great on it with the 52mm-72mm step up ring.
Side note, that 50mm f/1.8 is great. I wanted to get a faster lens then my 28mm-135 USM IS so I can see how much I would shoot at that speed so if I can ever afford the 70-200 IS f/2.8 I'll know I'd use it that much.
Old 5th of September 2003 (Fri)   #13
scottbergerphoto
scottbergerphoto's Avatar
Michael
Great explanation! Thank you. Is there any loss of sharpness or image quality when one of these is used?
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography
scottbergerphoto is offline   Reply With Quote
Old 5th of September 2003 (Fri)   #14
cowman345
Well, you're shooting through more glass, so there's always the risk of some loss of quality. However, it's Canon glass, and the 250D and 500D have two achromatic elements to correct any fuzziness that might normally appear when using a non-D close-up lens.
So to answer your question - probably not a heck of a lot, if you can even detect any at all I'd be mildly surprised.
-dave-
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon 500D review phangcht Canon EF and EF-S Lenses 9 24th of June 2007 (Sun) 23:56
First day with Canon 500D Needsnow Macro 3 2nd of March 2007 (Fri) 22:49
