Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 1st of September 2003 (Mon)   #1
Squeaky
Default Portable Storage for Flash Cards
I will shortly be going away on holiday and only have a limited supply of 'cards'.... What is the experience of forum members with the various forms of portable storage?
Squeaky is offline   Reply With Quote
Old 1st of September 2003 (Mon)   #2
henkbos
Default Re: Portable Storage for Flash Cards
Got an X-driveII with 30Gb hard disk. Performs great!
henkbos is offline   Reply With Quote
Old 1st of September 2003 (Mon)   #3
samdring
samdring's Avatar
Have Apacer DiscSteno (portable CD writer) which works really well and CDs are 10-a-penny.
Doesn't like some Lexar CF cards though - despite the firmware update which was meant to fix this issue.
Very fast - USB2 - compact and portable
Regards
Sam
Have a Care
Sam
samdring is offline   Reply With Quote
Old 1st of September 2003 (Mon)   #4
billfranklin
I took a Nixvue vista, model no.NV-010SA, with me to Alaska on my vacation. I had two 256 flash cards with me. As I used up one card, I would store it on athe Nixvue and keep on shooting. I had over 1200 raw files stored by the time I got home. The neat thing about the Nixvue is that you can view your files on the small screen and delete if they are no good.
Had thought about taking my laptop, but this little thing fits on my belt. It is not as fast as a laptop, but it gets the job done.
Bill F.
billfranklin is offline   Reply With Quote
Old 2nd of September 2003 (Tue)   #5
tony723
X-Drive II, Tripper and ImageBank G2 are all portable harddisk with USB 2.0.
The follow web site tested the portable drive mentioned but it is in Chinese:
http://vipweb.url.com.tw/chian/compare/TvsX2vsG2.html
tony723 is offline   Reply With Quote
Old 2nd of September 2003 (Tue)   #6
Ikinaa
Ikinaa's Avatar
Default Re: Re: Portable Storage for Flash Cards
Bill F.
You can view RAWs on the display of the Nixvue?
www.ikinaa.net
Ikinaa is offline   Reply With Quote
Old 2nd of September 2003 (Tue)   #7
Longwatcher
obsolete as of this post
Longwatcher's Avatar
I have the 30GB Delkin Picture Pad (similiar if not same as Nixvue).
Yes you can view Canon 10D Raw files if you have the latest firmware loaded. or at least I can with mine.
The ability to check files and see images is a great way to avoid carrying a laptop along on a trip. That way you are not tempted to start editing them, but can see if the images are worth saving before you get home.
Plus for added value, you can transfer files back to the CF card prior to returning home through security, so if the Picture Pad does not make it, maybe the CF cards will. Note: The files will not be readable by the camera.
I usually use this feature to store music for the airplane, but free up the cards for picture taking.
I have had the Picture Pad for over a year now with no problems other then I cursed the battery life. This problem has been solved with the AA battery external power pack for the picture pad. Note: the battery pack has one annoyance, you need a small flathead screwdriver (or equivilant) to change batteries.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher.com/photoequipment.htm
Longwatcher is offline   Reply With Quote
Old 2nd of September 2003 (Tue)   #8
billfranklin
Absolutely. Also, if the TV in your room has the right connections, you can view the files on the larger TV screen. It's just the regular Vidio input connetion, which I think is on almost all TV;s now.
Bill F
Old 2nd of September 2003 (Tue)   #9
Phil Hall
I usually take a laptop on trips. This allows me to shoot RAW then I cinvert, view and save to a CD. Some of the TAMRAC photo bags have slots for a laptop.
Phil Hall
Santa Ynez CA
Phil Hall
Santa Ynez CA
1D;1Ds;1D MkII;16-35:28-135:70-200;100-400;600;550EX;580EX
Phil Hall is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Portable Storage !! ned1 Accessories & Storage 44 13th of September 2006 (Wed) 12:57
portable storage to use in place of CF cards rklepper Accessories & Storage 16 23rd of August 2006 (Wed) 02:31
portable storage Krissypooh Accessories & Storage 2 4th of July 2005 (Mon) 17:26
Portable storage drive vs. additional compact flash cards? Jerry Vanderberg Small Compact Digitals by Canon 2 3rd of May 2004 (Mon) 21:20
