#1 |
Any advantage using a clear filter of this type versus UV filter?
Protection of lens being the priority.
Ken Canon Rebel XT Canon: EF-S 18-55mm f/3.5-5.6 'Kit'; EF 50mm f/1.8; EF 55-200mm f/4.5-5.6 Bogen Tripod 3030;Gossen Luna-Pro |
| sponsored links |
#2 |
*sniffles*
Avoid Tiffen.
Stick with Heliopan, B+W or Hoya/Kenko Pro 1.
La Vida Leica! • LitPixel Galleries -- 1v-HS/1d Mk IIn w/E-1 & Op/Tech straps 15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L 16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II |
#3 | |
My life is like one big RAW file....way too much post processing needed. Sheldon Simpson | My Gallery | My Gear updated: 20JUL12 |
| sponsored links |
#4 |
*sniffles*
#5 |
An uncoated Tiffen filter causes excessive flare which can easily be seen through the viewfinder and in the image.
A protective filter is only necessary when shooting in inclimate conditions such as blowing rain, salt water or sand or near such problem sources as stove top frypan or BBQ splatter. Also some children have a habit of poking the front element with grungy fingers. |
#6 |
*sniffles*
I keep a UV on all my lenses, all the time. It complete the sealing on the L's, and where/what I shoot... I need one.
#7 | |
This space available
Or possibly you viewed this defect. If so, what are the specific conditions that produced the cited defect so I can recate the conditions. If it can be "can easily be seen through the viewfinder" I would like to see it. Enjoy! Lon Last edited by FlashZebra : 26th of April 2006 (Wed) at 16:12. |
#8 |
*sniffles*
Somebody posted an example of this a while back... Three candles in a dark environment, IIRC. The ghosting was pretty startling - and obvious.
#9 | |
So, if I was going to put a filter in place for mechanical protection of the lens, why not get a bit of UV protection also. But, protection filters are typically unnecessary. I seldom use one, but almost always have a hood it place. There are unusual circumstances when I fit a filter for mechanical protection (I use a UV then). I don’t think it all that big a deal if you use one or not. There seem to be zealots for both camps, but personally I think it is an issue that does not really make much of a difference which way you go (with a constant on UV or no UV at all). But, if you are intent on using one for protection, avail yourself to the upside of blocking UV also. Enjoy! Lon Last edited by FlashZebra : 26th of April 2006 (Wed) at 16:16. |
#10 |
Formerly known as Bluedog_XT
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS Canon PowerShot S95 MY PBASE GALLERY |
#11 |
*sniffles*
Good filters do not degrade the image nor flare much more than your lens already does - and if you're in this type of situation, sure... Remove the filter.
Stick with Heliopan, B+W or Hoya/Kenko Pro 1 filters that are multicoated and stay away from cheap filters, especially ones that aren't coated. There's no harm in having a UV on the front all the time.
#12 | |
Dave 6D, 14/2.8L II, Sigma 35/1.4 DG HSM, Tamron 70-200/2.8 DI VC, Tamron 24-70/2.8 DI VC, Tamron 2X TC, 600EX-RT/ST-E3-RT, Singh-Ray 82mm Vari-ND |
#13 | |
Some time ago I was having erratic focus with my 400 f/5.6 and found that removing a Hoya HMC Pro UV filter cured the problem. That spurred me to take a good look at the collection of UV filters that I have accumulated and what ill effects they may present. Looking towards a dark corner of our laundry room on a sunny day the sun reflected from our white garden shed can be seen through the window when not looking through the camera. With the camera pointed towards this dark corner with the shed's reflection not in the frame, I placed various UV filters on a couple of different focal lengths. Looking through the viewfinder, there was some minor flare visible without a filter in place but adding uncoated filters from Tiffen made a noticable difference with a large increase in flare. The Hoya and B+W filters increased the flare by only a very slight amount - hardly detectable. And yes, I used a lens hood. If I can see flare in the viewfinder, I know that the image will also be softened by it. If I get a chance in the next few days to duplicate this test with some images, I gladly post them for your scrutiny. Regards, Paul |
#14 |
I just recently saw a posting here or at FM pointing to a site that compared a Tiffen with a B+W MRC & it was quite eye opening. The Tiffen did not fare well to put it nicely. Unfortunately I don't recall the link.
20D/BG-E2/Katz Eye | Tokina 12-24/4 | 24-70/2.8L | 50/1.8 Mk I | 70-200/2.8L | PD70X |
#15 |
D60, because having the best doesn't mean you are... |
| Thread Tools | |
| Display Modes | |
| Ultra Clear | mdaddyrabbit | RAW, Post Processing and Printing | 6 | 25th of May 2005 (Wed) 17:25 |
| CCD's and Bad Pixels....Can anybody make that clear? | Downhill | The POTN Lounge | 3 | 13th of September 2004 (Mon) 10:10 |
| Canon G5 - Digital Optics lens - GOOD OR BAD ? :) | zakmckracken | Canon G-series Digital Cameras | 8 | 10th of June 2004 (Thu) 14:21 |
| Any bad comments on Tiffen MegaPlus? | Hink | Canon G-series Digital Cameras | 0 | 25th of November 2002 (Mon) 21:13 |
