Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 27th of April 2006 (Thu)   #1
2005GLI
2005GLI's Avatar
Default CSX, first panning shot.
Took this tonight while waiting for the local 99 to go north. Actually was unexpected and came s/b pretty fast. First panning shot i took that came out pretty good.
Canon XT|BGE3|40D|BGE2|24-105 F4/L|70-200 F/2.8 APO|
|12-24 F/4|50 F/1.8|8mm F/4|kit lens|
|Other goodies that I can't fit in here|
2005GLI is offline   Reply With Quote
Old 27th of April 2006 (Thu)   #2
RocknE30
RocknE30's Avatar
Default Re: CSX, first panning shot.
I would have to agree, it turned out pretty damn good! And since it was just a spur of the moment thing, not bad. It pays to have your camera with you to practice things like that.
Canon 30D w/kit lens & 75-300mm.
RocknE30 is offline   Reply With Quote
Old 27th of April 2006 (Thu)   #3
2005GLI
2005GLI's Avatar
thanks. I've tried panning shots in the past and they've all come out blurred out completely. I did get lucky as i was orinally zoomed in at 135mm but the shutter was too slow beeing dusk so it was blurred out. Im going back down tomorrow after i get up to do some more.
Old 27th of April 2006 (Thu)   #4
Livinthalife
Livinthalife's Avatar
nice! Great first try! Im sure you will only get better! I have yet to try panning...the baby doesnt move one direction, shes like a cheetah, zigzaggin...cant pan a zig zag, at least not yet!
-Andy-
Canon 5DMKII 85 1.8 Rokinon 8 FE
24-105 F4 IS L 580EX 70-200 2.8 100 2.8 L
...:::My Website:::...
Livinthalife is offline   Reply With Quote
Old 28th of April 2006 (Fri)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
You got the important part sharp & I like the way it loses sharpness as you get toward the rear of the train.
From another thread: Shutter speed depends on the speed of the car AND your distance from the car AND the focal length of your lens.
Try this a few times & see if it helps:
Stand with your feet in a line parallel with the direction that the car is traveling. You want a line drawn perpendicular to your shoulders to intersect the point where you anticipate taking the pic. Turning at the waist, start your pan WAY early, snap the shot when it's in front of you, AND continue the pan WAY to the side. (If the people to the side don't get out of your way, then you aren't following through enough!) This insures that the pan is smooth & steady when you take the shot.
Go out & practice with traffic for awhile. It does help!
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Old 28th of April 2006 (Fri)   #6
ajbalazic
ajbalazic's Avatar
A successful attempt! Great advice Frank- thanks.
Alan
ajbalazic is offline   Reply With Quote
Old 28th of April 2006 (Fri)   #7
2005GLI
2005GLI's Avatar
Photosguy, thanks for the tips. I'll see if i can try it tonight. Here's the exif data.
Resolution: 900 x 600
Flash used: No
Focal length: 24.0mm (35mm equivalent: 149mm)
CCD width: 5.78mm
Exposure time: 0.033 s (1/30)
Aperture: f/8.0
ISO equiv.: 400
Whitebalance: Manual
Old 28th of April 2006 (Fri)   #8
DxHatchback
DxHatchback's Avatar
crop out the telephone pole
Andrew M. Revels, Jr. | 1D Mark II N | 28-75 | 70-200
Buy my Tamron 28-75 for cheap!
DxHatchback is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SHOW US YOUR BEST PANNING SHOT Richard Sneath Motorsports 5651 23 Hours Ago 10:26
My first panning shot attempt. robz Critique Corner 7 7th of July 2007 (Sat) 13:10
One panning shot from Joliet, IL Christopher.Sullivan Motorsports 2 19th of June 2007 (Tue) 04:51
Panning shot from dragstrip black_z Transportation 24 19th of January 2007 (Fri) 22:43
the old panning car shot RoB_m Critique Corner 4 14th of September 2006 (Thu) 17:51
